Question about Compaq Presario Notebook
Compaq laptop my laptop was working perfectly then the battery died while i was using it. i hooked the charger up to it then all of the sudden it would not turn on and the charge light flashes. Occasionally the charge light as well as the power light will flash repeatedly very fast. Also On rare occasions the computer will seem like it is starting up for about 3 sec.(you can see all lights and hear the fan) then it turns off. The battery will not charge either. Where do i Start?
  • 2 more comments
  • tailintide Jul 19, 2008
    i tried that and still no different result
    i tried that as wel...plus i dont see how it would just change itself after a year of use
  • suzanne armour Dec 12, 2008
    my laptop was working fine then screen went blank the battery light is flashing and cant get my cd drive to open when i power up u can hear the fan then nothing the power light is on
    i have an rm cl51 it will not power up u can hear the fan for a few seconds but thats it the power light is on but the battery light keeps flashing and also can not get the cd drive to open please can someone help
  • 383 Answers
Check your FN keys. Laptops sometimes have it set up on the fn key instead of a manual switch.
Hope this works for ya/Please dont for get to Vote.
Posted on Jul 19, 2008
    Genius:
  • 2,028 Answers
Try removing the battery and starting on AC only.
My acer laptop suddenly shutdown then it didn't turn on,the led of the charger is blinking,what is the problem?
you may have had a surge on your charger, i'd unplug it and try a different outlet. After you unplug it, remove the battery for about a minute, then when at the new location plug the battery back in and then the charger. see if that works. if it doesn't it's possible that your charger just died. Did you happen to look and see how much battery you had available when it died?
May 14, 2012 | Computers & Internet
Hi i have some problem to my laptop battery it wont charging, but laptop charger is working fine, my laptop brand is compaq presario C700. i tried to charge my laptop in 2 hours after that i tried to turn...
Did ur laptop works or turn on when u plug the adaptor charger?
If ur laptop turns on when the charger is pluged in, u got problem with ur DYiNG BATTERY!
Better buy a brand new battery!
Nov 08, 2010 | Compaq Presario 700 470024-192 Notebook
I have compaq notebook pc...using vista... my battery was working perfectly fine. suddenly, now when i plug in. it says, 0% available , plugged in not charging. i have tried uninstalling and then...
how old is the laptop?
either your battery has developed a fault or the laptop connectors have developed a fault therefore not registering the battery output.
also check the ac adapter.
Jul 09, 2010 | Compaq Presario Notebook
PC suddenly lost power will not restart
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Dec 05, 2009 | HP Compaq nx9010
My Compaq Pres V2000 laptop does not get on with power on switch
Take out the battery and only hook up the AC Adapter to see if the laptop turns on. If it does then you know the battery is shorting out the laptop and either has very little power to turn on the laptop or is shorting out the laptop cause its bad.
If you don't get the laptop to turn on, make sure your using a well known working wall outlet to plug the laptop to and only use the AC Adapter. If you AC Adapter is hooked up and the Green Led turns on then you know the adapter is good.
After those two steps, you can also try taking out the dvd drive and the hard drive. Then try turning on the laptop and if the laptop still doesn't turn on then the motherboard is bad in the laptop.
Aug 29, 2009 | HP Compaq Presario V2000 Notebook
Compaq R3000
r u mention for battery light?if is it true,then the light is blinking because of your laptop want to make sure the power supply charge that battery.if it is in charging condition,the light on.but if the light goes off,that mean, the battery is already full.
But when u use adaptor without battery, the light will goes off because no charging session is in progress which has same behaviour with battery full(during battery full,no charging session occur)
May 12, 2009 | Compaq Presario R3000 Notebook
System failure in my laptop ??
Remove the battery from the computer and plug in the correct charger and see if it will power on. without the battery. if so turn off and put battery back in with power connected see if it powers up.
Oct 29, 2007 | HP Compaq Presario 730US Notebook
Compaq Presario Notebook Logo
157 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
