If you are referring to the water coming out of the top of the drain pipe that the washer drain hose hangs in, then you don't washing machine problem. The problem is a "slow drain", which is a partially clogged sewer line. This was a constant call when I used to repair ( and still is according to some of my friends still in the repair field). Snaking out the drain or using a safe drain cleaner down the pipe is the best solution.
Hope this helps
