Question about LG LMV1630ST Microwave Oven
Nothing works, displays numbers 1 thru 4.
Nothing works except inside light when you open the door. When you push any button, display sequentially displays numbers 1 thru 4.
Any suggestions.
  • 2 more comments
  • gbshah1 Jul 19, 2008
    Tried doing hard reset. When unit is plugged in again. Same issue. Let me know if we can try anything else.
    We tried that. When unit is plugged back in, same issue.
  • evelynbella Feb 04, 2009
    We have the same problem, the only difference is my husband went to ise the auto cook setting, and now it is stuckon stupid. The only button that works is the auto cook, but it won't run or cook anything.
  • William Miller
    William Miller May 11, 2010
    The first thing to try
    is a "hard reset". Unplug it from the power line for a minute, plug it
    back in, set the clock, then try again.
    Let us know if the hard reset doesn't fix it.
    We have the service manual for this model, so we can probably help you.
  • LG Master
  • 9,098 Answers
What you're describing sounds like a corrupted controller, or maybe there is some grease, etc. on the controller, maybe where the keypad plugs into the controller.
Can you post a video demonstrating what happens?
This sounds really odd!
Posted on Jul 20, 2008
  • N56whiskey Sep 07, 2011
    I have the same problem did you ever get it fixed?
Hi, my Smeg MI20X microwave does not work anymore. The display works but if I push a button nothing happens. Can someone help me with this? Thank you.
Does the light come on when you open the door? If it does, I would venture to guess that the keyboard is bad.
Oct 29, 2017 | Smeg Microwave Ovens
Microwave will not run a cook cycle. Touchpad functions until door is opened or start button is pressed. When door is opened display goes dark. When door shuts display lights all characters and then says...
BEFORE DOING ANYTHING DISCONNECT OVEN FROM POWER. I do NOT recommend doing repair by yourself, if you NOT are really very familiar with electric repair, or have at least basic training in electric device repair and maintenance.
"When door is opened display goes dark. When door shuts display lights all characters and then says "touch clock"."
Obviously, by opening door, oven gets disconnected form power line.
This is mostly caused by loose connections on wiring socket, and can be anywhere inside. Check security micro switch on door latch. This switch normally disables only running the oven when door is open, for security reasons. In your case, it seems that opening door disconnects oven from input power. Sometimes the switch is loose, or wires are not firmly pushed in the socket. If the power line wiring is loose, and by opening door looses contact with socket, it can touch metal housing inside, cause short, electric shock, serious even mortal injury and fire. This is dangerous high voltage switch, and to access it one must open oven from the back and take off the cover. I do not recommend doing it by your self.
Rem: Replacement micro switch is couple dollars.
Oct 24, 2014 | Microwave Ovens
Why does light comes on turntable turns when door opens nothing lights on display or nothing works ?
Normally faulty micro switch which needs replacing: Caution: hight voltage may be present so best left to service person
Jul 23, 2014 | Oster Microwave Ovens
Sharp Microwave diplay light not working
We regularly repair these display / control units nationwide by mail for $39.95 postpaid with a one year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jul 07, 2010 | Sharp Microwave Ovens
When microwave finishes light doesn't come on when door open; display keeps reading "food ready" after food is taken out--have to push the "clear/off" button to make "food ready" display go away; counter...
Shorted switch in the door latch assembly.wihout the full model number I can't tell how to get to it, but usually one needs to remove top grille, remove screw holding the control panel, remove control panel. Good luck.
Nov 26, 2009 | GE Profile Spacemaker II PEM31 Microwave...
Hinari microwave doesn't cook
hello mam
i am having the solution for this problem check the lock terminals for loose connection and if its working and check the magnetron which produses the heat inside the microwave.
Sep 25, 2009 | Microwave Ovens
Microwave won't operate
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order one from us for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Sep 09, 2008 | Microwave Ovens
No fan noise, just a click when push button
Did the display count down?
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts for most brands by entering your full model number here: http://tinyurl.com/gv383
Please write back with your brand and model number if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
prototech@usa.net
May 19, 2008 | Microwave Ovens
Kenmore elite microwave oven displays "Locked" and will not respond
My Kenmore Elite microwave (don't have the model number in front of me) also mysteriously locked its own keypad (we were sitting in an adjacent room, heard a strange beep, and got up to find the LED reading "Locked."). I pressed and held down the Stop/Clear button for ~10 seconds and it returned to normal.
Mar 01, 2008 | Kenmore 62622 Microwave Oven
The unit loses power.
check control circuit may be dry solder at conrol circuit, check door switches also , check all wiring connectors and circuit.
Nov 12, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
LG LMV1630ST Microwave Oven Logo
105 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
