Question about Xerox Phaser 7760/YDX Laser Printer
Part # Trying to obtain Part # for the metal C shaped guide that the Cyan Drum cartridge slides on going into the machine. Can you help?
    President:
  • 2,072 Answers
Https://www.partsdrop.com/store/ Go to this site. Call and ask for Britt, I don't work there, but have bought from them for years, He will fix you up with what you need for a fair price.
Posted on Jul 19, 2008
Since i install a new drum, i have smudges on my copies how do i fix
    Sir/Madam
    If you have Brother Printer print quality problems, Then I suggest You clean the Your Brother printer drum unit as follows:
    Small Spots on the printed pages:
    If your printed document has any small white or colored spots, follow the steps below.
    1.Open the manual feed slot cover.
    2. Using both hands, slide the manual feed slot paper guides to the width of the paper that you are going to use.
    3.Using both hands, put one blank sheet of paper in the manual feed slot until the front edge of the paper touches the paper feed roller. Wait until the machine automatically feeds the paper. When you feel the machine pull in the paper, let go.
    Note
    • Make sure that the paper is straight and in the correct position on the manual feed slot. If it is not, the paper may not be fed properly, resulting in a skewed printout or a paper jam.
    • Do not put more than one piece of paper in the manual feed slot at any one time, as it may cause a jam.
    • Do not put paper in the manual feed slot before the printer is in the Ready state. An error may occur and the printer will stop printing.
    4.Make sure that the printer is in the Ready state. Press + or - to choose "Color Correction". Press OK.
    5.Press + or - to choose "Drum Cleaning".
    6.Press Go. The printer will pull in the piece of paper and start cleaning the drum unit.
    7.When the printer has finished cleaning, "Completed" appears on the LCD.
    Press Cancel so that the printer returns to the Ready state.
    8.Repeat steps 3 to 7 two more times using a new blank sheet of paper each time. Upon completion, please discard the used paper. If the print problem still remains, please go to the Step 9.
    Large spots on the printed pages:
    Hint If your printed page has colored spots at 94mm (3.7 in) intervals, please follow the step below.
    1. 9.Turn off the printer power switch.
    10. Fully open the top cover by lifting up on the handle (1).
    11. See the print sample to identify the color causing the problem. The color of the spots is the color of the drum you should clean. For example, if the spots are cyan, you should clean the drum for cyan. Take out the drum unit and toner cartridge assembly of the color causing the problem.
    Caution
    • We recommend that you place the drum unit and toner cartridge assembly on a clean, flat surface with a sheet of disposable paper or cloth underneath it in case you accidentally spill or scatter toner.
    • To prevent damage to the printer from static electricity, DO NOT touch the electrodes shown in the illustration.
    12.Push down the green-labeled lock lever (1) and take the toner cartridge out of the drum unit.
    Caution
    1. Handle the toner cartridge carefully. If toner scatters on your hands or clothes, wipe or wash it off with cold water at once.
13.Put the print sample in front of the drum unit, and find the exact position of the poor print.
14.Turn the drum unit gear by hand while looking at the surface of the OPC drum (1).
15.When you have found the mark on the drum that matches the print sample, wipe the surface of the OPC drum with a dry cotton swab until the dust or glue on the surface comes off.
DO NOT clean the surface of the photosensitive drum with a sharp object.
Note Make sure that you put in the toner cartridge properly or it may separate from the drum unit.
17.Slide each drum unit and toner cartridge assembly into the printer. Make sure that you match the toner cartridge color to the same color label on the printer.
C- Cyan, M- magenta, Y- Yellow, K- Black
18.Close the top cover of the printer.
19.Turn the printer power switch back on.
If your question was not answered, please check...
Clean the drum unit Brother
Or
If You still need Brother Printer Help I suggest You follow Us On for :
Brother Printer Support
Nov 07, 2012 | Brother Dr420 Black Drum Unit Cartridge
Mechine is showing drum error and couldnt fix that error .. wht i have to do for fix this error
Sometimes the little metal connectors on the end of the drum make poor contact with wire looking connectors they should line up with inside the machine. with the drum out these connectors should be visable inside on the right. with the machine off, and with a rag lightly dampened with metho give these connectors a bit of a scrub, then make sure the little exposed bits of metal on the end of the drum cartridge are clean of toner and dust, most importantly make sure you are inserting the drum cartridge correctly. also on the drum cartridge there should be a little plastic tab ( its blue i think) that slides side to side, slide this back and forth a few times (it is a cleaning device) make sure you reset it to the side correctly when you are finished.
If that doesnt work, the drum may be faulty or at end of life (25k pages officially, though they usually go a fair bit longer thant that) Maybe its the wrong drum depending on where you are in the world it should be a dr-520 or dr-3100 or dr-3115.
Thats all i can think of right now, but sometimes things occur to me when im not thinking about it, if im able i will add more if it occurs to me. Regards, Andrew.
Jan 20, 2011 | Brother MFC-8860DN All-In-One Laser...
Help with taking out ink from xerox phaser 8560DN
Power down the printer and raise the upper cover. Beneath, you will find four slides with differently shaped cutouts: yellow, cyan, magenta and black (this is DIFFERENT from usual sequence which is cyan, yellow, magenta and black. Don't ask me why).
Open the ink bags and put the waxy inky shapes in the slides. Each shape can only go in its slide, without forcing.
Once done, close the cover and turn on the printer - wait a couple of minutes for it to stabilize and warm up, then try printing a sample page.
Oct 27, 2009 | Xerox Phaser 8560DN Laser Printer
Toner Sensor Error for Cyan and Toner Out for Black
First, I wouldn't worry about the "K toner out", it might finally disappear once you get rid of the Cyan problem, if indeed you replaced the black toner for a new and healthy one.
Make sure that the cyan toner cartridge is securely fitted in it's drum unit, and the "knob" that opens the toner cartridge is in fully open position. Sometimes when manipulating inside the printer the "knob" might get moved a bit.
Generally, the toner cartridge sensor is connected via the drum unit, so usually the problem is with proper seating of the drum unit and good electrical contact between the metal fields on the sides of the drum unit and contacts protruding inside the printer. Cleaning both of any residue might help.
Once I had a defective toner cartridge, that caused such problem, but it was the contact between the toner cartridge and the drum that was broken. You have to experiment a bit.
I'm pretty sure in this model it is possible to swap two units - if you swap for example cyan with magenta, and observe if the error moves from cyan to magenta or not, you can draw conclusions if the problem is with the toner/drum, or with the printer not seeing the cartridge for some reason (sensor inputs killed by static electricity for example).
Oct 26, 2009 | Office Equipment & Supplies
Large Toner Streak... Bad Imaging Unit?
Check to see if you waste toner recycling for the cyan is working or being blocked. Check the transfer bias roller next to the cyan drum. Return you cyan imaging unit for a warranty replacement. Check for obstructions to the cyan developing unit. Check that the cyan IU was put into the machine properly. Check for toner leaking from the entrance to the developing unit or from the toner cartridge.
or, call a qualified KonicaMinolta tech to check out and service your machine.
Sep 12, 2009 | Konica Minolta Office Equipment & Supplies
My 15 year old Maytag Dryer is starting to squeal from the drum rubbing metal to metal up front. The Belt is in good shape. What else could be problem?
Time for a new one I think, but here goes.
The drum guide rollers at the rear or the guide pads at the front will be worn out, due to the age parts may be difficult.
To inspect:
Electrically Isolate the machine, at the joint between the front panel and top panel insert a flat blade 4" from each side to release the top catches and tilt the lid back to open, remove the front panel internal screws and remove the front panel.
The drum and machine internals can be seen.
Remove the drum belt - note the belt path direction around the motor and belt tensioner.
The drum removes by rotating and easing forward, there will be pads or rollers that support the drum, check these as they are the most probable cause.
Jun 29, 2009 | Maytag Dryers
Have the canon d880 having hard time changing the toner cartridge
The main reason for cartridge replacement problems is the locking mechinasim not fully retracting. When you slide the platen to the left and open the door on the right make sure you open it all the way. It should go to a little mor them a 90 degree angle. You should be able to remove easily at this point when putting cartridge back in if you look at the back wall in betwwen the cartridge guides you will see a white plastic circle with a triangle in the center make sure it is flush with the metal if not push the door a little more to the left.
Jan 09, 2009 | Canon imageCLASS D880 All-In-One Laser...
Our xerox M118 showing an error"replace drum cartridge'can any one help me?Plizzz
Hello, Your Xerox has two cartridges - one is the drum cartridge and the other is a toner cartridge. Please check the following I've researched from your user guide:
Replacing the Drum Cartridge
The drum cartridge is a customer replaceable unit. After approximately 55,000 copies/
prints, the machine will display a warning message before the drum reaches the end of
life. Order a replacement cartridge now to insure continuous operation.
Country Part Number for the drum cartridge replacement
All countries 13R589
Removing the Old Drum Cartridge
1. Pull the front cover towards you to open it.
2. Open Tray 5 (bypass tray) if necessary, and then open Cover A while lifting up
the release lever.
3. Lift up the colored lever, and slide the drum cartridge out until you can lift the
handle on top of the cartridge.
4. Hold the handle and remove the cartridge from the machine.
NOTE: When replacing the drum cartridge, make sure that the new cartridge is the
correct one specified for the machine.
Recycling the Drum Cartridge
The drum cartridge is designed to be re-manufactured. To recycle used drum
cartridges, return them to Xerox in the original packaging. Return labels are included
with each new cartridge.
Inserting the New Drum Cartridge
1. Remove the new drum cartridge from the box.
2. Undo the sealing tape and carefully pull out in the direction of the arrow to
remove the black protective sheet from the cartridge.
3. Place the cartridge in position and, using the handle, slide it into the
machine until it clicks.
4. Pull out the cartridge tape completely without breaking it.
5. Push the cartridge again so that it is correctly placed.
6. Close Cover A until it latches and then close Tray 5 (bypass tray).
7. Close the front cover.
Hope this helps. Good luck.
Dec 11, 2008 | Xerox WorkCentre M118 Black and White...
Shart AR BC 260
please clean the mirrors and drum unit
Oct 05, 2007 | Sharp AR-BC260 Color Copier
Xerox Phaser 7760/YDX Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
