Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Picture appears out of focus
Picture appears blurry , out of focus blu and red are fixed, but grenn keep moving to the left and right
  • creisinger Jul 27, 2008
    Our tv started doing the same thing yesterday morning. Colors are not matching up and the appearance of what's on tv looks concave. Any suggestions?
  • 125 Answers
Convergence problems I just fixed one for 225 there are 2 stk to be replaced you willhave to call a tech
Posted on Aug 08, 2008
When I take a picture it always comes out blurry. How do I correct this?
Search Results
    The Top 4 Causes of Blurry Photos, And How To Fix Them ...
    www.digital-photo-secrets.com/.../the-top-4-causes-of-blurry-photos-and...
    Out of focus An image that is out of focus will appear blurry. ... The first is to increase the shutter speed as explained above, The second is to hold your camera steady whileyou take the shot. .... It's always very helpful, and I enjoyed the video.
    Why Do My Pictures Come Out So Blurry? « Samsung Galaxy S3
Nov 30, 2015 | Cameras
Blurry picture, focus
Can't you rotate the ring around the lens to focus it.
If it does move sometimes you have to rotate it quite a few times left or right.
Feb 15, 2012 | GE MiniCam Pro HO98756 Webcam
Some of my pictures are blurry using a cannon rebel 3. how can i fix this problem?
There are several possible causes for blurry pictures.
1) Camera motion. If everything is blurry, it's most likely because the camera moved while the picture was being taken. Make sure your shutter speed is fast enough if you're handholding the camera (longer lenses require faster shutter speed). Alternatively, put your camera on a stable surface, such as a tripod or a tabletop.
2) Subject motion. If the subject is blurry but the background is sharper, then the subject may have moved while the picture was being taken. Use a faster shutter speed. Raise the ISO if needed. There are limits, of course. If you're trying to photograph a fast-moving object in the dark, you probably won't be able to.
3) Improper focus. If the subject is blurry but something else in the picture is sharp, then the camera probably focused on the wrong object. Move the focus selector to the subject you want in focus. Alternatively, center the viewfinder on the subject, press the shutter button halfway to lock focus, then reframe and shoot.
Without any more specific information as to what and how your pictures are blurry, I'm afraid the above is all I can give you.
Jan 13, 2012 | Canon Cameras
My 60" Phillips tv has a blurry picture at the bottom and the top
The convergence output IC's need to be changed. A very common problem with all projection tvs.
Jun 04, 2009 | Philips 60PP9352 60" Rear Projection...
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Jul 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Blurry
Right off hand I'd check the focus . By turning the camera lens left or right may cure the problem. Sound likely to be the focus. Hope this is of some help. Bud
Feb 22, 2008 | Philips SPC700NC Webcam
Blurry Image problem with Mitsubishi WS-55805
Hello, if you want I can supply you with the service manual, please leave your email. Best regards, Arpi
Aug 14, 2007 | Mitsubishi WS-55805 55" Rear Projection...
My picture is blurry or out of focus.
ake sure your subject is within the camera's range. You should be at least 20 inches away to take a picture without the flash, and 20 inches to 8 feet away to take a picture with the flash. You can take a picture as close as 8 inches in macro mode. When you take macro close-ups, make sure you have adequate lighting (with the flash disabled). Using a tripod will help you capture sharp pictures. Make sure you hold the camera steady after you press the shutter button (until the red light starts to flash), and your subject isn't moving. If you are shaking the camera when you lock the focus, a warning icon appears in the right corner of the LCD. If you want to photograph a moving subject, you can change the shutter speed while the camera is connected to your computer. Try increasing the shutter speed. See Chapter 4 for more information about how to change the shutter speed from the LCD menus. Make sure your flash is not set to flash off. When you focus on a nearby object, your picture's background may appear blurry. Try changing your focus.
Sep 13, 2005 | Epson PhotoPC 800 Digital Camera
Picture blurry or out of focus.
Make sure your subject is within the camera's range. You should be at least 31 inches away to take a picture without the flash, and 31 inches to 8 feet away to take a picture with the flash. You can take a picture as close as 8 inches in macro mode. When you take macro close- ups, make sure you have adequate lighting (with the flash disabled). Using a tripod will help you capture sharp pictures. Make sure you hold the camera steady after you press the shutter button (until the red light starts to flash), and your subject isn't moving. If you are shaking the camera when you lock the focus, a warning icon appears in the right corner of the LCD. If you want to photograph a moving subject, you can change the shutter speed while the camera is connected to your computer. Try increasing the shutter speed. For more information, see Chapter 6. Make sure your flash is not set to flash off. When you focus on a nearby object, your picture's background may appear blurry. Try changing your focus.
Sep 13, 2005 | Epson PhotoPC 750Z Digital Camera
What should I do if the picture is blurry or out of focus?
Make sure your subject is within the camera's range. You should be at least 20 inches away to take a picture without the flash, and 20 inches to 8 feet away to take a picture with the flash. You can take a picture as close as 8 inches in macro mode (2.3" zoomed to wide). When you take macro close-ups, make sure you have adequate lighting (with the flash disabled). Using a tripod will help you capture sharp pictures. Make sure you hold the camera steady after you press the shutter button (until the red light starts to flash), and your subject isn't moving. If you are shaking the camera when you lock the focus, a warning icon appears in the right corner of the LCD. If you want to photograph a moving subject, you can change the shutter speed while the camera is connected to your computer. On the PhotoPC 3000z you can also use Program (Sports Mode) or Manual (Shutter Priority) to increase the shutter speed. Make sure your flash is not set to flash off. When you focus on a nearby object, your picture's background may appear blurry. Try changing your focus.
Sep 12, 2005 | Epson PhotoPC 3000Z Digital Camera
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
48 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
