Question about Whirlpool GU2400XTP Built-in Dishwasher
WHIRLPOOL QUITE PARTNER ii
IT JUST QUIT. NO LIGHTS NOTHING. CHECKED THE CIRCUIT BREAKER IT'S FINE; PLUGGED THE UNIT ON ANOTHER OUTLET (THAT I KNOW WORKS ) THROUGH AN EXTENTSION AND NOTHING. IS THERE SOME KIND OF A SHUT OFF MECHINIS OR FUSE IN THE UNIT THAT NEEDS TO BE CEHCKED? PLEASE ADVICE
  • 125 Answers
There is a thermal fuse attached to the main control, check for continuity if none replace fuse.
Posted on Aug 24, 2008
I have a Frigidaire air conditioner. I've never had a problem with it,at all until a few minutes ago. It all of a sudden quit working. I pushed the reset button and tried to push power, but nothing....
First check the outlet the unit is plugged into. It may be dead, due to a circuit breaker being tripped. Also, the interior of the outlet may be damaged or has a loose wire.
If a circuit breaker was tripped, unplug the unit before resetting the circuit breaker. Then plug the unit back in and turn it ON. If the breaker trips again, there may be a short in the AC wiring or there is another electric appliance on that same circuit, that may be causing an overload, when the AC unit is ON.
Hope this helps you to start troubleshooting the problem. Thanks for choosing FixYa.
Aug 10, 2011 | Frigidaire Heating & Cooling
The hottub keeps kicking the circuit breaker off.
Either the breaker is bad or you have an electrical problem. Unless you know how to work with electrical problems call for service. If you unplug the hot tub and plug a lamp or hair dryer into the outlet does the breaker trip? If yes, call an electrician. If the outlet is fine call for service on the hot tub.
May 01, 2010 | Home
Whirlpool Quiet Partner II. Does nothing at all when you try to start it. Seems latched tightly and I double-checked and reset the circuit breaker. Thoughts?
CHECK THAT THERE IS VOLTAGE AT THE CONNECTION TO THE D/W. CHECK WALL SWITCHES, GFI OUTLETS FOR TRIPPED, THAT THE WATER TO D/W US ON. IF IT TRIPPED CIRCUIT BREAKER. MAY BE SHORTED INTERNALLY.
Mar 10, 2010 | Dishwashers
I have a Whirlpool Quite Partner II dishwasher that does not seem to have electricity. The 20 Amp breaker is OK. What else can I check?
you need to also check the main power line to the dishwasher.there is a bigger chance that the control board has gone bad,also need to check the thermistor on the bottom of the machine this could also give you a power failure problem
Feb 22, 2010 | Dishwashers
While air fluffing some shirts the dryer quit and will not start. is there a breaker or fuse internal to the unit?
Check the breaker in your home's breaker box. The dryer will be the only thing that is on it. It will be a double breaker and looking might not tell you if it has tripped. If it isn't marked just grab the swich and see if it's "wiggly" on each double breaker. If you find a wiggler, flip it all the way over to "off" then back to "on". If the breakers are all fine, the next place to check is the wall outlet itself. If you have a volt meter, first check the slots in the outlet. If you get nothing, pull the wall plate off of the outlet and check the wires leading to the outlet. If they have power, replace the outlet. To the best of my somewhat experienced knowledge, there is no fuse in dryer and I know there is no breaker in it.
Nov 29, 2009 | Maytag MEDC500V Dryer
My microwave just quit workin. It has absolutely no power.
Make sure breaker isnt tripped. If breaker isnt tripped just for the sake of knowing plug a fan or something you know that works in the outlet. If it works, you have probably blown fuses in the microwave you'll have to take microwave apart to get to them.
Aug 25, 2009 | Whirlpool MT4110SP 1100 Watts Microwave...
Quiet partner ii just stopped
Most likely it has an internal fuse or relay gone bad. Check the curcuit w/ a "glow stick" power identifier available at Lowes or Home Depot.
Aug 20, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Washer stopped mid-cycle, water in the bottom of the tub. Circuit breaker popped due to over-load. Reset breaker and it immediately popped again. Could this be cause by a jam in the grinder assembly?
My dishwasher just quit mid cycle. (still has water in it) It is a whirlpool partner 1. I checked the breaker and it wasn't tripped... but i reset it anyways. When I tried the dishwasher again it worked for a second and turned off. I have done reading about the thermo fuse but can't find it. Not sure how big of a problem this is.
Dishwasher is 5 years old.
Thanks,
Dale
Jul 02, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
See below
have you tryed leaving the power cord out of the socket for an hour or so
sometimes they don't lose the memory until they have been left disconnected for a while
Jun 12, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Old whirlpool washing machine won't run.
if no lights suspect main control bd remove rear screws in top panle remove top by sliding towar back control is along rear
Jun 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GU2400XTP Built-in Dishwasher Logo
145 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
