Question about Refrigerators
Outdoor ice maker
Yes, the water line is fine
  • Refrigerators Master
  • 19,396 Answers
Check if the water is freezing inside the ducts. Double check the water supply connection.. If there is a valve or a tap in the connection check that it is fully opened.
If water is getting to the ice maker check that ice is not stuck inside, if ice is there then evaporator ( device to release ice) is not working.
If water is not released it can also be a problem with solenoid valve.
Checking for this faults involves taking apart fridge parts, and this can invalidate the guaranty.
Being the fridge new I suggest calling back vendor or factory for assistance, setting (hose connections etc), and eventual replacement (how know what kind of pain it is , particularly when it is the second time.
Posted on Jul 19, 2008
If you pore water in basin it works fine but when connected to water line no water comes in
The ice maker is calling for water but ain't getting any because the water valve is bad OR the contacts inside the ice maker are bad.
Jan 24, 2011 | U-Line Icemaker
Do i have to hook the water line up in my 561 or will it run just fine with out the ice maker
Good day,
Yes it will work fine, however, make sure the ice maker is turned off. Otherwise it will dry cycle causing it undue wear and eventually fail.
Apr 30, 2010 | Sub-Zero 561 / F
U-line combo not making ice. Have cleaned
bad water valve, thermostat, freezer not cold enough, make sure the ice maker metal rod is at down position or on back of the ice maker plastic water line is frozen. also depends what year combo you have, there operation is a little different.
Nov 15, 2009 | U-Line Refrigerator Ice Maker
Hooked up water line and ice maker, water working notice maker. Any ideas?
Make sure wire loop extending out from the ice maker over the ice bin is pushed down. Up turns the ice maker off.
Without more info, I can't diagnose further.
Stick finger in ice tray where ice freezes. Is there water in there. No, check solenoid valve and water line to ice maker (kinks). Is there ice cubes in ice tray? Is ice maker pushed fully in? All wires to ice maker on back and underneath connected?
If this information was useful, please select YES to the first two rating questions. Good Luck and thank you!
Oct 24, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag MSD 2432GR Water not feeding into Ice Maker
one possible solution is that the ice maker water valve has failed (solenoid). I would try switching the wires on the water valves and see if water goes into the ice maker when you push the water dispenser button, if it does the valve is ok. If you go this far go ahead and fill the ice maker with water ( about half to two thirds full) switch wiring back as first found and see if maker will freeze and dump ice, if it does ok, if not the problem is probably in the ice maker.
Jul 06, 2008 | Maytag MSD2436GR Side by Side Refrigerator
ICE MAKER NOT WORKING
Yes, the ice maker controls the water valve. First check that there is water in the ice maker trays. If there is your valve is not the problem. If not, loosen the fitting on the water line that leads to the water solenoid valve. If you do not find water, check your manual valve that taps into the main water line. If you do have water, it may be that the water inlet above and behind your ice maker is frozen. You can thaw it out with a hair dryer and see if that is the problem. If this model dispenses water through the door, you can find the water solenoid valve behind the unit near the floor and reverse the two plugs on the solenoids. Place a paper towel in the water inlet tube that channels the water into your ice maker. Close the coor and press the water dispenser for 3 seconds. Open the door and see if the paper towel is wet. If it is, the water solenoid is fine. You can also remove the front of the ice maker and put an insulated jumper wire between the T and H test points to see if the unit ice maker will go through its cycle.
Dec 31, 2007 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
66 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
