Question about Jenn-Air Kitchen Ranges
How do I replace the heating element on a jenn air model FCE30500A stove
How do I change the light on my oven
Technika T888M6X
Posted on Jul 19, 2008
THE COOKTOP WONT HEAT UP. BUT THE LIGHT ON THE CONTROL KNOB LIGHTS.
My first guess would be to check for proper connection at the wires from the stove body to that specific heating element.
Perhaps, lift-off or open the cook-top cover, and check the hook-up to the heating element itself.
How old is your stove, and is it fitted with the common "coil type" elements? Unless it's a very late, high-tech model, capable of checking its own wiring, the indicator light will illuminate regardless of an open circuit to the heating element because older models can't "see" or "know" whether something has come loose, so the indicator light will come on, and just sit there, cold and clueless.
Bon Apetit!!
Sep 20, 2016 | Jenn-Air JES9860 Electric Kitchen Range
Tip
I'm wondering if my Jenn-Air Model JER8885QCS needs a new probe or not. It's a...
As oven probes age, they can sometimes generate error codes on kitchen ranges and render them inoperative. The error code varies between models, but can be found with the technical documentation that comes with your range. Most manufacturers place a tech sheet somewhere along the back of the range, or inside the console for qualified technicians to use as a troubleshooting aid. Refer to this if an “F” code is displayed on your operator console. The probe may also exhibit other symptoms without generating an error code. You could have undesired heating results (too hot or too cold), or slow preheat times.
The location of the oven probe can vary on different models as well. It will be mounted on the back or side of the oven wall (usually in the upper right or upper left corner). If you suspect you have a bad oven probe, a resistance check can be performed to determine if the probe is good. To accomplish this, unplug the range and remove the back panel. There are still dangerous voltages present even when the oven is not on. There will be two heat insulated wires coming from the oven probe behind the oven. Disconnect the wires and perform a resistance reading across both wires at room temperature. If the probe is good, it should read around 1100-1200 ohms*. If the reading is too low (shorted) or too high (open), replace it. However, I would take a good look at the interconnecting wiring FIRST. If you have a connector plug on the oven probe, often the plug pins will oxidize and not make good contact. This gives false readings and can lead to erroneous error codes. Some manufacturers recommend cutting the connector plug off completely and hardwiring the leads together by using heat resistant ceramic wire lugs. This provides a more permanent and reliable connection. The lugs can be purchased at most hardware stores. A new oven probe roughly costs about $35 - $45 and can be found on line at several appliance parts websites. Higher end model prices may be more.
To replace the oven probe, simply remove the mounting screw from inside the oven cavity, disconnect the wires and pull the probe out. Insert the new probe by feeding the wires through the opening in the back of the oven first and out the back through the insulation (a long screwdriver can assist you in making a visible hole through the heat insulation to feed the wires easier). Once you have the wires through the back of the oven, reinsert the mounting screw and connect the wires leads together. Reinstall back panel.
*NOTE: Keep in mind resistance readings will be higher if the probe is hot. Make sure you check the temperature at room temperature.
I hope this information is helpful..
on Mar 31, 2010 | Maytag MER6772 Gemini Electric Kitchen...
I have a Jenn-Air JES9900 range and the right front burner is not working but the hot indicator light remains on. Is this just a switch that needs to be replaced?
make this test and fix it. God bless you
Surface Element Switch
If the surface element won't work, and there is another element of the same size on the stove, try switching the elements. If it still won't work, the surface element switch is probably defective. The surface element switch can't be tested or repaired, it will have to be replaced.
Enter your model number to see parts for your range/stove/oven.
Help me find my model number
Surface Element Board
If a surface element won't work the surface element board might be defective. Each burner is switched on and off with the help of a relay on the surface element board. If one or more relays has failed the surface element won't work. If two or more burners fail at the same time, this is likely the problem. If only one surface element won't work and the element itself checks out to be good, the surface element board might be defective.
Coil Surface Element
If the surface element won't work, the coil surface element might be burned out. Most coil surface elements can be pulled out of their socket and checked with an Ohm meter for continuity. If the surface element won't work, check to see if there is any visible damage to the coils. Also, check to be sure the element is pushed all the way into the socket.
Radiant Surface Element
The most common cause when the surface element won't work is the radiant surface element itself. The radiant surface element - or heating element - can burn out similar to a light bulb. If the surface element won't work and it doesn't have continuity, it will need to be replaced. The radiant surface element is not repairable.
Solid Surface Element
If the surface element won't work, and the stove has the solid surface element type of heat, it's likely that the solid surface element itself has burned out. The solid surface element works very similarly to other surface elements - inside there is a heating element that glows when electricity is applied to it. As it gets hotter, the heat is transferred to the solid surface element
Element Receptacle and Wire Kit
If a surface element won't work, there may be a problem in the element receptacle. The surface element plugs onto a terminal block type receptacle. Over time the terminals in the receptacle can have a bad connection and overheat. Look at the receptacle contacts with a flashlight. If the terminals look burnt you will need to replace the element receptacle. also make sure the element prongs are clean and not burnt. If the prongs are burnt bad the element will need to be replaced also.
Loose or Burnt Wire Connection
If surface element won't work, there might be a burnt wire supplying power to the surface element. Sometimes the wire supplying power to the element burns out right near the element itself. Check for this by just looking at the wires leading to the element. If they're burned out it is usually easy to spot.
Incoming Power Problem
Although not as common, if the surface element won't work it is possible that the appliance is not receiving proper voltage. Electric ranges require 220 volts of alternating current. If for some reason the appliance is receiving significantly less, the surface element won't work. Check for proper voltage using a volt meter at the socket where the appliance plugs in.
Nov 04, 2013 | Kitchen Ranges
My stove SVE47100C the elements in the oven do not heat.I have replaced the computer panel a year ago as well as the element
If both of the oven elements stopped working at the same time, and the stove top elements work then the problem is most likely in the high limit fuse. It is the common component to both oven elements.
The control could be bad, but I would have someone test the high limit first. It should read 0 resistance if it is good.
May 17, 2010 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air SVE47100 Oven Won't Heat
are you still getting power to the oven? breaker ok? there may also be a fusible link somewhere on the circuit
Nov 21, 2009 | Jenn-Air SVE47100 Slide-In Electric...
My Jenn air SVD48600P heating element dose not heat
Hi. I believe this info. may assist you in getting your bake and broil up and running:
When your heating element burns out, you have to replace it because they are not repairable. If, when the heating element burns out, the infinite switch that controls it also fails, you have to replace it too.
May 31, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Heat element shorted out saw arching from element itself
An Easy Task.  Unplug stove. Remove old element by disconnecting the wires. Purchase new element and install. Plug stove back in.
Dec 20, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
How to remove stove top to replace element on JES8850BAS
i would imagine you would not have to remove te front control paenl eitherfew screw around sidesand back
heres a complete service manual for the model number, loos asif its adowndraft cartridge model not a glasstop , removing main top pg 26
http://www.servicematters.com/maytag_library/docs/16026926.pdf
Nov 23, 2008 | Jenn-Air JES9860 Electric Kitchen Range
I have an old model electric Jenn-Air D-120. Last night my oven bottom burner cought on fire and burned up. Can this be fixed or is the stove shot.
Usually the bake elements are relatively cheap and easy to replace. Use your model # and click on one of the links to the right and search for your part to make sure that it is still available. It would be worth repair.
May 15, 2008 | Jenn-Air Kitchen Ranges
Kitchen Ranges Logo
176 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
