Question about Refrigerators
I have a brand new kitchenaid ice maker for my outdoor bar. My contractor installed the water line and drain hose, but it just pours water out of the bottom of the unit and will not produce ice. It's been pouring out at five minute intervals for two hours.
  • karencoco Jul 19, 2008
    I can't seem to find out why my Kitchenaid outdoor icemaker is gushing water at five minute intrvals from the bottom with no ice.
    This is the second one that Loews has delivered and I must be doing something wrong with installation. The water line is not kinked, my plumber hooked it up and we checked that. It's been pouring water out for several hours now.
    This is just an icemaker, not a refridg.
    Genius:
  • 3,422 Answers
HI,
hen it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Posted on Jul 19, 2008
  • Priya darshan Jul 19, 2008
    Water
    coming from the back of the refrigerator usually comes from either the
    ice maker water valve or line (if there is an ice maker), or from the
    defrost drain pan.
    Here's what to do:
  • If
    the water is coming from the ice maker water valve, check to make sure
    the water tubes are attached properly and are fastened tightly.
  • If the water seems to be coming from any part of the valve itself, replace the valve.
    If you need anymore help let me know.
    Please don't forget to rate or accept the solution.
    • Refrigerators Master
    • 19,396 Answers
    Check that the water line is not boken at some point
    • Ginko
      Ginko Jul 19, 2008
      Check first if ice cubes are stuck inside, but I dont think there is water getting to icemaker either.
      If water does not get up there , then either the line is broken at some point or water freezes inside the line, check it out.
    • Ginko
      Ginko Jul 19, 2008
      The water line is broken, disconnect the water from the fridge and call back Kitchenaid
    Kitchenaid refrigerator model KBFS20ETSS01. New H2O heater installed. Ice maker has not worked since. Checked for stuck ice. Has an arm mechanism. Do not hear tray filling. Could water line clogged?
    The water line could have ice blocking its path to the ice maker but not as likely as a defective dual water control valve.
    Try replacing the dual water control valve first=> Water Inlet Valve WP67006531
    APPLIANCE 911
    Dec 03, 2016 | KitchenAid Refrigerators
    Ice maker kitchen aid kuic18nnts won't pump water over chill plate. Replaced circulating pump still no water.
    Does the circulating pump- pump water? Remove the hose that goes to the spreader bar and run the unit again, if it moves water as a new pump should check for blockages in that hose and spreader tube. Get back to me if this doesn't work please. Personal email address kidlmo@gmail.com...
    Jul 21, 2014 | KitchenAid KUIS18NNT 18" Automatic Ice...
    Why doesn't our new icemaker in a whirlpool ed5 fridge work?
    Make sure water line valve is turned on where it taps in to water line,and that ice shut off is down not up, check to see if water is in ice tray or if it is dry if no water or ice is present then water is not getting to it if water tap valve is open then water valve in ice maker is off or ice shut off arm is up instead of down. Try pouring warm water in ice tray see if that will get it started.
    Jul 21, 2014 | U-Line Icemaker
    Danby icemaker DIM3225BLSST, having drainage issues and trying to troubleshoot. Is the drain pump switch on if the "O" is selected, or the "----" ?
    Thank you for being very descriptive. I would get the installer back out since it is new and probably still under warranty and instruct them to say with it until it has satisfactorily run a couple of cycles. They can easily troubleshoot this machine while they are on the job.
    Mar 06, 2013 | Danby Ice Maker Dim3225blsst
    MSD2356 side by side, we just hooked the water hoses up and there is no water coming through lines?
    Here is a link that explains how to test the ice maker
    Ice Maker Test
    Here is a link that explains how to check the water in the door.
    Water through door test
    If you require further assistance you can always post in our forums
    Forum
    Feb 26, 2011 | Maytag MSD2756G Side by Side Refrigerator
    Icemaker water not shutting off
    I believe that your drain hose is either kinked or stopped up. Pull the bottom cover off and see if you can view where the line is kinked. These have specific installation instructions that must be followed or they will not drain.
    Apr 10, 2009 | KitchenAid Superba Architect KSCS25INSS...
    Ice maker
    My wife installed a new filter and didn't purge (AKA flush) it enough. As a result, my ice maker quit. Since there was air in the line, the water feed into the ice maker froze. You should check your water feed. In your freezer, look to the top right part of your ice maker. You will see a short (2 inches or so) black tube that feeds water into a piece a plastic on your ice maker that looks like a small cup. Squeeze the tube to see if frozen. If it is, there is probably also a frozen pool of water in the 'ice maker' cup. You can use a hairdryer but be very careful as you can melt the plastic. My service guy took out the ice maker and ran it under hot water. He used a small screw driver to get the ice out of the black hose. Removing the ice maker looked pretty easy. You can remove the ice maker door (it justs snaps out). the ice maker also just slides out. If you are not comfortable removing the wire connection, there's enough plat in the wire to allow you access to the frozen cup of water. You could pour hot water over the ice maker while it remains connected. When done, cut power to the entire frig for about a minute. This will reset the ice maker. Note that you may have a wait a few minutes to actually hear the ice maker fill with water since it has a timer mechanism.
    Aug 03, 2008 | KitchenAid Superba Architect KSCS25INSS...
    Ice maker pouring water
    there must be something wrong with the solenoid valve that controls the water flow to the ice maker
    Jun 14, 2008 | Refrigerators
    Ice maker won't fill
    leaky solenoid? could cause ice build up
    Jul 08, 2007 | KitchenAid Superba Architect KSCS25INSS...
    Refrigerators Logo
    Top Refrigerators Experts
    John Tripp
    John Tripp
    Brian Coughlan
