Question about RCA Universal Remote Control
How to watch a DVD
How to I switch my TV so I can watch a DVD. On previous remotes there was a button. The only one I have seen that is similar to my last remote is the input button and that does not do anything except show what channel I am watching. The input button does the same thing as the input button
  • 2,071 Answers
Http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): How to watch a DVD - clip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 25, 2008
I can't get the function to switch from TV to DVD
Hi Gary,
Previously Tech Support here of ATT Uverse. For your issue you may want to try this steps by changing the input: click number 7(same as input) on your att remote you should have input lists on your tv screen. If not doing anything use your TV remote and find there input,source or tv/video and you should have input lists on your tv screen. For the input you should choose HDMI 1 or 2 if you are using HDMI cable. If not try to choose anything on the input lists and you should get the right input in order for you to watch on your DVD and going back to TV. Hope it helps
Dec 22, 2013 | AT&T UVerse
How do I switch tv to did to watch a movie
Plug your cables from the DVD player into the back of your TV, into AV in, then set your TV to AV. Or use HDMI and do the same ,plug into DVD player TV then set TV to HDMI. On your remote it should say Mode or something similar.
Dec 16, 2013 | Televison & Video
I just got my DVD-VR375. I want to watch a rented movie. The TV is about 5 years old and cable is connected directly to the TV. I connected the red white and yellow from the dvd av out to the video in on...
If you have the original remote for the TV there should be a button that says Input or I Select or something similar. You need to change your "Input" to L1 or L2 or AV, or something similar.
Dec 05, 2009 | Samsung DVD-VR357
No video signal
You need To cut The Wire and Put Them Again In ur DVD or Num
Apr 15, 2009 | Philips 32PT6441/37 32" TV
TVS2740B, how do I switch from TV to Video Input manually?
going to have to get a universal remote with input button on it, or tv/vcr button, had same problem!!
Jan 04, 2009 | Sansui TVS2750 27"
Connect tv vcr and dvd player to digital converter box
Yes you can first connect the converter box to the antenna first. Next hook the tv out on converter box to vcr in on vcr. Next hook the vcr out to the tv in and watch vcr and converter box on channel 3 sometimes channel 4.on the actual tv and of course change channels with converter box remote. For dvd player hook it straight to tv with red,white,and yellow cables that come with your dvd player. Then to watch dvd player if it's hooked up that way you have to put your tv on a input like video 1 or input 1. This can be done by using the tv remote and looking for a button that says tv/video or input or source button. This is some common names for that button on tv remotes.
Nov 02, 2008 | Insignia Digital-to-Analog Converter for...
Programming a remote
You should have instructions that came with your new remote that show you how to program specific buttons to specific functions. In general there is a similar button on universal remotes, it may be called input or some other button that implies changing the video source.
Good Luck
May 14, 2008 | Sanyo DS31590 31" TV
Programming rca universal remote for my toshiba tv
I can't exactly help you, but can you tell me how you programmed the remote to your TV, because I cannot get mine to work...
Apr 03, 2008 | Toshiba 42H81 42" Rear Projection...
Lost remote to 27in rca tv, how can i switch my tv to input/output mode so i can watch movies on my dvd playter? i have a rca univeral remote, but it will not change my tv to input or output.
using the menu button on the t.v. set an alarm for 1 min in the future. have the t.v change to channel 00 or the input channel @ that time. turn off the t.v and wait until the alarm turns the t.v on.
Aug 11, 2007 | RCA 27F534T TV
Televison & Video Logo
61 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
