Question about Kenmore 75944 Gas Dryer
Kenmore dryer not spinning---how do i disassemble to see if belt or motor is bad?
Kenmore dryer mod. 110.74632300 ser. mp 4604802 type DWJR NAT1206006 FM22 is what reads on the inside lip of door. The dryer portion still works but it will not spin. I disassembled damn near the entire dryer trying to see if it is a belt or motor or what and i cannot figure out what the problem is. Reason being, I cannot get to the "guts" of the dryer to see these parts. I need a manual or assistance rapidly!. I have a 1 year old, one on the way and an angry wife. PLEASE HELP! 4073458472. Jimmy
  • 1 more comment
  • Anonymous Feb 01, 2009
    what do I do if the bottom belt is broken?
  • Anonymous Apr 16, 2009
    Cannot find the pulley to replace belt
  • FoxyTarte 1 Apr 22, 2009
    THANKS IT WAS HELPFUL, HOWEVER, MY IDLER PULLEY FELL OFF AND I DO NOT KNOW WHERE IT GOES BACK, DOES THE NEW BELT GO AROUND THE PULLEY
    Champion:
  • 210 Answers
Kenmore dryers are the easiest dryers to work on. unplug! remove 2 screws @lint screen top. insert screrwdriver under top @ each end and pop top up. disconect wires to door panel. remove 2 5/16 screws at each end inside. lift front door panel up and out.( the bottom of the panel is held by spring clips. replace belt if broke. remove drum if not and check rollers. note: belt route at idler pulley.
Posted on Jul 19, 2008
I just bought an older whirlpool dyer (MOD wed5300sq0 type dwjr-ele-2406026-fm54) and it spins counterclockwise. Is that an issue? The heat is blowing out of the house in the correct direction but I didn't...
The drum on the dryer is powered by an ac motor. You cannot change its direction of rotation by changing lead connections. AC has no positive or negative leads. It must be OK as is
Oct 29, 2014 | Dryers
Motor wouldn't start replaced the motor and it still won't start?
Did you replace the thermal limiter fuse inside the cabinet near the motor? It is likely burned out. Contact the repairclinic.com for the part or Sears.
Jan 19, 2012 | Whirlpool Dryers
Have a Kenmore Elite Dryer that won't start. Mod 110.65962401 Ser MS0303258 Type DDOT-ELE-2406028-CV54
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 22, 2011 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore dryer, mod 110 60956990, ser MJ4102370, type DDOT-ELE-2406028-EH54. When I push the button to start the dryer, nothing. If you wait several minutes, it sounds like it is trying to come on...
heatman101
Oct 28, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
I have a Whirlpool dryer...Mod nu# WED5800SQ0,
Sounds like your capacitor has stopped functioning. Most dryers have capacitors ranging from 8 to 10 ohms which store energy and give the drum the initial energy boost to start it turning. Unplug the machine and take off the side that contains the motor. in there you will find a small cylindrical object with two connections, thats your capacitor, replace it
May 24, 2010 | Whirlpool Dryers
My dryer won't turn on
Make sure that the problem is not a broken belt, or a belt that has slipped off of the motor pulley or idle arm pulley.
Look to see if the motor is running first, sometimes you cannot hear the motor running but it is.
Also you can check your breakers to see if one is kicked out.
This problem can also be caused by a faulty start switch.
If this is not the problem than it may be time to call the repairman
Sep 26, 2009 | Kenmore Dryers
Kenmore washer wontt spin or empty. i laid machine on its side
Adjust the motor mount so the pulleys are aligned.
Brute force may be necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 10, 2009 | Kenmore 24032\24036 Top Load Washer
Dryer runs no heat
Sounds to me you either blew the fuse or tripped the circuit for the heating element. Try replacing the fuse or resetting the breaker before trying any repairs.
Jan 09, 2009 | Kenmore 64602 Electric Dryer
Kenmore 75944 Gas Dryer Logo
2,130 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
