Question about Mitsubishi WT-46809 46" Rear Projection Television
T.v i just need to know how to set the color right on my t.v. can you tell me how so the color would be even
    Problem Solver:
  • 7 Answers
The first thing you need to do is to take away the color completely, then you adjust the hue until you get the picture looking like a black & white tv, like the old shows that were broadcast in black & white.
Then you can gradually add the color. And thats it your done!
Posted on Jul 19, 2008
What if color right have the blue frame paint i
IT WOULD BE PERFECT BLUE IS THE BEST COLOR I LOVE BLUE HOW ABOUT YOU.................. HOW OLD ARE YOU I CAN TELL YOU SOMETHING YOU KNOW ABOUT YOUR SELF.............
Oct 05, 2013 | Yamaha 2007 YFZ 450 SE
I need to know what color wire go to the other color wires when connecting the light to the fan
It sounds like we are wiring a ceiling light, with a ceiling fan?--
Or am I way off base?
Do you have a wall switch, sending the power up to the ceiling light,--
Or is the power coming into the ceiling, and the wall switch is not the source of power?
This will make a big difference in how we tell you what color wires goes where--
(We are not talking a 3-way wall switch set-up are we!-- that will be much more complicated!)
So-- Tell us where the power is coming from-- Wall or ceiling.
I'll be here a few minutes, if you want to get right back to me-
Mack B
Jan 16, 2011 | Heating & Cooling
While replacing the caps on on the LCT32HA36 power supply i noticed a corroded solder joint the Z3 diode. When i attempted to re-solder it the trace came off the circuit board and I lost the R3XX surface...
The resistors are color coded.There should be 3 bands which are slightly separate from the 4th band.The 4th band is usually gold,silver,or i forget the third color which is actaually a %.The top 3 bands can tell me the value of the resistor.If you tell me all 4 colors I should be able to tell you the value,with the gold/silver/whatever as the fourth.The first one should be right near the end or top.The only 1 problem will be trying to determine the wattage rating but is usually very small within a circuit.Greg
Dec 17, 2010 | iLO LCT32HA36 Television
I have a ultrascan hd the convergance is off i dont have an owners manuel it tells me to use a curser what do i do to get the red blue right ?
The cursor probably is just a cross in the center of your TV screen whichever color your setting will be a color cross that you want to move by using the up, down, left, right, buttons on your remote. You want to move your color cross over the top of the center cross until it looks like one cross. Generalized setting instructions can be found here.http://www.ehow.com/how_2034880_perform-convergence--tv.html
If this helps let me know with a vote.
Mar 04, 2010 | Televison & Video
Color is off, bue will not line up,yellow and
OK, I know this set very well--if convergence in the customer menu is skewed and red or blue will not adjust in some direction, you have a convergence problem.
I can give you (post here) START TO FINISH STEP BY STEP INSTRUCTIONS FOR THIS REPAIR IN THIS MODEL.
It requires that you are able to solder etc---not real hard even if you have never done it before.
Considering you can buy the parts on Ebay for about 20 dollars if you can do it yourself or know someone who can do it for you--you can save the set and a lot of money......most shops get 300 or more for this kind of trouble.
If you want the instructions let me know and I will post them.
I can tell you the best place to get the chips--this set uses two STK-392-110 CHIPS.
Usually just both chips need to be replaced and the set adjusted.
The instructions tell you everything you will need and how to do the fix.
I composed them from my own experience and because many people here ask the same thing you did.
If you have questions etc, let me know. I am here to help people.
If this has helped you, rate this solution as I do this here for free.
Thank you for using Fixya.
SD TECH
Nov 24, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Tv color is dark, and there is lots of green in the picture
sounds like the coolant needs replacement. You can tell by looking into the lens of the CRts while the set is playing. The green and blue are usually the ones that are affected first. If you need to know where to get the coolant kit which contains the coolane and the instructions let me know and I will post the link.
May 17, 2009 | Philips 50P8341 50" Rear Projection...
I have a konica Minolta Magicolor 2530DL and I just refilled the toner and now I cant get the new chips to read. I want to know if there is a way of disabling the chip so I can print. I know I have enough...
You need the chips to tell the printer which color is installed. You can put your old chips on the toners and set the engine menu to continue on errors to print even when the counters show that it should be out..
Apr 07, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Blue color gone
This sound like the color wheel needs to be replaced!
That should fix ya!
Dec 17, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
42' plasma daewoo tv with vertical color lines.
the way how you described it looks like the screen is cracked but problem can also be in VPB (video process board).But without the model name its very hard to tell you more
Feb 05, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Resetting TV Color Settings.
Generally 50 is the middle setting. try setting the color bars all to 50 and see what happens.
Bill
Jan 21, 2008 | RCA T19408 19 in. TV/VCR Combo
Mitsubishi WT-46809 46" Rear Projection Television Logo
57 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
