My IBM thinkpad a20m wont turn on
I bought it at an auction went out and got a brand new power cord but and the green battery light turned on but when i press the power button nothing happens. I need some help with this.
    Genius:
  • 2,028 Answers
A couple of minor things that could cause this is the battery and memory. Try starting without the battery. Then remove the memory and try it with one chip in, then change them out and try. If these don't work, then the problem will lie with the motherboard, and will need professional diagnosing in order to locate the problem board component.
Posted on Jul 19, 2008
How do I turn on the wireless on an IBM ThinkPad 2628 A20m Thanks in advance
To turn on the wireless on IBM Think Pad 2628 A20m you can try the below options
IBM
IBM General - Some models have the wireless slide button on the side of the laptop.
IBM DV series - use the antenna-like button found on the upper section of your keyboard.
IBM R40 - Use the Fn+F5 key-combo.
IBM Thinkpad (General) - Most have software switch or button on Left hand side.
IBM Thinkpad (model not further identified) wireless switch on Front edge of case.
IBM T43/X32 - Fn+F5 -Click "Turn On"
IBM ZD series use the antenna-like button just below the “Lock” key.
Let me know fi this will help
Dec 04, 2009 | IBM ThinkPad A21m 2628 Notebook
When i turn my laptop on it shows a lock on it and wont do anything else.
THE BEST WAY TO REMOVE A BOOT UP PASSWORD IS TO CONTACT IBM AND SET UP A SHIPPING SENARIO WITH THEM AND LET THEM REMOVE IT. MAKE SURE YOU ARE THE REGISTERED OWNER!
May 28, 2009 | IBM (08K3261) for ThinkPad A20P, A20M,...
Ibm thinkpad a20m wont turn on
Here's a great article that may help you work your way through the difficulties: click here.
Also google troubleshoot power supply or power suppply problem and follow the instructions...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 13, 2009 | IBM (08K3261) for ThinkPad A20P, A20M,...
Battery light flashes all the time (when powered by mains)
Yes, it means, it cant charge the battery anymore. Get a new battery, or work without it
Mar 15, 2009 | IBM (08K3261) for ThinkPad A20P, A20M,...
Getting hot underneth
Both batteries could be dead. But if you bought a new battery, it's unlikely. I don't know what green light you see, but if it's on the power adapter, it just means it's turned on--not that it is charging.
Two possibilities: Your power adapter is bad or the motherboard is bad. Because you say the computer works if plugged in, then you have ruled out the adapter.
You should be checking/cleaning the battery contacts and if all else fails, going for a new motherboard.
Jan 16, 2009 | IBM ThinkPad T22 2647 Notebook
Ibm thinkpad power supply problem ???
it actually sounds like something may be shorting out the system, remove the cd-rom and try it then, ive had an a20m do the same thing and it turned out to be the ram, so always check for the simplest, remove each 1 at a time and try to power it on again
Dec 11, 2008 | IBM LENOVO VIDEO CARD 760E 39H6226 Graphic...
Ibm thinkpad a20m
Does the battery charge AT ALL
Before buying a new battery go to my computer hardware device manager you may just need a new driver.Update restart see what happens
If not then you do need a new battery.That should solve your problem.
Nov 25, 2008 | IBM ThinkPad T30 2366 Notebook
IBM Thinkpad T22 Battery
pls first check your adapter may be problem with your adapter.
thank you
Sep 28, 2008 | IBM ThinkPad T22 2647 Notebook
Ethernet driver does not work for IBM Thinkpad A20m
hi good day to you I have problem in my laptop thinkpad A20m PIII 700mhz 256 ram running in widows XP,, and everytime I install the driver of Lan the massage appear error in code 10, and the lan is not working,,can you help me in this problem?
Jan 12, 2008 | IBM ThinkPad A20M Notebook
IBM R32- battery light problem
usually when the charging light blinks and wont change to solid green it means the battery is dead.
solution is to buy a new battery
Dec 07, 2007 | IBM ThinkPad R32 2658 Notebook
Computers & Internet Logo
156 people viewed this question
David Payne
David Payne
