Question about JVC SR-VS20 Mini DV/S-VHS VCR
Firewire not recognized
Hi I am running a Macbook Pro and in the past have been running a Dual processor G4. In both cases my machine cannot see the deck. I am able to digitize firm my camera, so the culprit is neither the cable nor the Mac.
Please assist,
Thanks!
Lisa K
liskaplan@gmail.com
  • liskaplan Jul 24, 2008
    Hi, this worked temporarily, thank you! If I fast forwarded a tape manually control would slip, which does not happen when I am using the camera. Having said that, if I did the power off, plug out on both ends, it would work again. Any idea why this is that a hard resetting like that works?
    Thanks,
    LK
  • JVC Master
  • 19,396 Answers
Check that the firewire is not burnt because you plugged the camera while it was on, it is very easy to blow.
Posted on Jul 22, 2008
  • Ginko
    Ginko Jul 22, 2008
    Remove battery from mac and umplug from power also unplug the VCR ,
    Keeping VCR off, connect firewire, then turn on first mac and after computer, if it doesnt work you may have burnt the firewire, did you connect it with VCR on?
  • Ginko
    Ginko Jul 24, 2008
    Firewire and USB connections may have problems from electrostatic charges, by removing all sources of power you can often fix them, probably this was the case
MacBook Pro 17 inch thermal paste
you can use any standard thermal paste on the macbook pro, however the processor is soldered to the board.
Jan 27, 2014 | Apple 17" MacBook Pro Laptop Computer...
Macbook pro doesnt recognize the panosonic pv-gs9 when connected with firewire
I take it that your macbook pro has imovie on it. If you open up imovie and plug in your camcorder it should recognise the camcorder and give you access to putting the movie onto your mac. Have a look at http://www.apple.com/support/imovie/ it should help.
Mar 03, 2012 | Panasonic Palmcorder PV-GS9 Mini DV...
What is the best motherboard and system configuration for adobe premiere 6.5 and pinnacle pro on rtdv ? I need the configuration in details please..... Please, thanks, Mack
TECH SPECS for ADOBE PREMIERE 6.5
Minimum System Requirements
Windows
  • Windows 98SE, Me, 2000 (SP2), or XP
  • Intel PIII 500MHz
  • 128MB RAM (256MB or more recommended)
  • 600MB HDD space for installation
  • CD-ROM drive
  • QuickTime 5.0 recommended
  • Microsoft DirectX certified FireWire
  • dedicated large-capacity 7200RPM HDD
  • For Real-Time Preview:
    Pentium III 800MHz processor (Pentium 4 dual processors recommended)
    Macintosh
  • Mac OS 9.2.2 or Mac OS X v.10.1.3
  • PowerPC G3 (G4 or G4 dual recommended)
  • 64MB RAM (128MB or more recommended)
  • CD-ROM drive
  • QuickTime 5.0.2
  • QuickTime compatible FireWire
  • large-capacity HDD capable of sustaining 5MB/sec
  • For third-party capture cards:
    Adobe Premiere certified capture card
  • For Real-Time Preview: G4 processor (G4 dual recommended)
  • Jun 27, 2011 | Pinnacle Pro-ONE RTDV Video Capture
    Cannot install final cut pro.....the software says my macbook pro(macbook3,1) does not have minimum system requirements. my mac.... 2.2 ghz 800mhz core 2 duo 4gb ram 2x2gb @ 667mhz GeForce 5600m gt 128mb...
    yes it seems that your laptop dose not meet the minimum requirements to install final cut pro software.you will need to purchase a laptop with the correct requirements,sorry.
    ken
    Apr 04, 2010 | Apple MacBook Pro Laptop Computer with...
    MacBook won't recognize my Lacie Rugged Hard Disk. Disk utility will see it but won't verify it nor will it repair it. says it needs to be reformatted yet it won't even let me initialize it. it is brand...
    Is your MacBook as fast as the Lacie Rugged Hard Disk is?
    Because solid state drive wasn't available on MacBook Pro at the initial time when it launched. Hard drives on all current Apple laptops are equipped with Sudden Motion Sensor technology. In fact, the Apple laptops that came with Sudden Motion Sensor are: All Intel-based Apple portables such as the MacBook, MacBook Pro, MacBook Air, PowerBook G4 computers starting with PowerBook G4 (12-inch 1.5GHz), PowerBook G4 (15-inch 1.67/1.5GHz), PowerBook G4 (17-inch 1.67GHz), and iBook G4 computers starting with iBook G4 (Mid 2005) have Sudden Motion Sensor technology. You MacBook may not have come with that technology that could be the reason you are unable to connect it.
    Sorry mate... too many limitations on
    Feb 24, 2010 | LaCie Rugged All-Terrain (301017) Hard...
    Cannot detect LaCie mini hub HD.
    Try a new power supply. $19.99 at Lacie. It worked for me.
    Dec 20, 2009 | LaCie Computers & Internet
    I have a Umax PowerLook 2100 XL, since I upgraded to a dual processor MacBook pro with OS 10.5.8 I have not been able to use the scanner. Error message comes up stating no scanner found. I connect to the...
    Hi Try using the software called Vuescan by Hamrick Software.. www.hamrick.com I think.
    It will recognize the scanner and work with OS 10.4 and UP. Although I am not sure about 10.6 Snow Leopard.
    Nov 06, 2009 | Umax PowerLook 2100XL Flatbed Scanner
    Firewire problem
    this sounds like you could have blown the firewire port on the mac, this can happen if you plug in and out, even though it is supposed to be hot swappable. if nothing shows up on the firewire port but does show up on other ports on other computers then that could be the problem. its back to base with apple for a repair.
    Apr 01, 2009 | Digidesign Digi 002 Rack FireWire Pro...
    Macbook pro does not detect digi 002 rack
    yeah i have an intel imac and had the same problem. I upgraded to pt le 7.4 and now pro tools recognizes the 002 rack and it works fine, but still the core audio manager does not recognize the hardware. It says in "use" when I first turn on the 002 rack, then it says not connected after about 20 seconds. I don't think this really matters though because I have beeen able to do everything fine without having the core audio managr recognizing the 002 rack. I hope that helps
    Dec 04, 2008 | Computers & Internet
    No firewire 800 or 400 functions in Leopard for SIIG FireWire 800 + Hi-Speed USB Combo PCI Adapter
    Unistall and reinstall through control panel. use the drivers it came with. Make sure the drivers are for ur OS. If not, check with manufacturer for proper drivers.
    Mar 14, 2008 | Computers & Internet
    JVC SR-VS20 Mini DV/S-VHS VCR Logo
    123 people viewed this question
    Top JVC Televison & Video Experts
    Jaime Hernandez
    Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
