Question about KitchenAid KSCS25FKSS Side by Side Refrigerator
Hotpoint CSX22GR water dispenser not working
I have Hotpoint CSX22GR sisde buy side Frig, Water Dispenser stoped working, But ice maker is still working.
  • 1 more comment
  • moe1966 Aug 25, 2008
    Filter was already changed. Besides it is not related. Ice maker works fine and it also gets water thru filter too.
  • johnsont1106 Jan 25, 2009
    I have the same problem. Water won't dispense..changed filter and nothing. But ice maker works fine...hmmm
  • mooretbbd Jan 27, 2009
    Water will not come on but ice maker works
The residule water in the line freezes, you need to unthaw the freezer door. Then you constantly need to use the water from the dispenser to keep it from refreezing.
Posted on Apr 12, 2009
Sounds like to me your filter needs replaced...how long ago have you changed them?
Posted on Aug 23, 2008
  • tom cesarano Sep 21, 2012
    i dont know wher the filter is
I have a maytag side by side frig model # msd2578vemoo the ice machine works but the water dispenser does not work
You will need to replace the water inlet valve on the back of the refrigerator. One line is for the water dispenser and the other is for the ice maker. The side for the ice maker is not energizing the solenoid to let the water thru to the ice maker. Here is the part you need to order.
Nov 10, 2012 | Refrigerators
Ice maker does not work on my Hotpoint sise by side. the water dispenser works, i've replaced the filter, the green light is on, but nothing happens with the icemaker, no running water sound, no ice
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Jul 01, 2009 | Hotpoint HSS25GFP Side by Side...
Ice maker and water dispenser not working
well there is two things it could be low water pressure or ur ice maker is defective try replaceing the ice maker this should work if not u need to get a frig repair man out to help u because if the problem is in the frezzer door it is not easy to fix on ur own
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water dispenser will not work when lever is pressed. we had an intermittent problem with it before it stopped working altogather.I was going to look at it but was afraid to pop off the trim on the outside...
This could be a bad water valve in the frig. This frig has a double water valves. One for the ice maker and one for the water dispenser. It should be in the lower back. Where the water line goes in. You can check this valve easily. Find the double water valve on the frig. Turn off water supply to frig first. Swap the plastic water lines going from the water valve into the frig. Turn water supply on. Then see if the water dispenser works. Sometimes you will have to operate the water dispenser for a little while to get the air out of the line. If it works now then the problem is in the water valve solenoid and needs to be replaced.
Nov 08, 2008 | Kenmore 53642 / 53644 Side by Side...
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Icemaker and water dispenser
Mine did the same thing.  Other web sites said it was the motherboard.  I replaced it and now it works great.  The part number is: Hotpoint Refrigerator Main Control Board Assembly WR55X10552best deal was at http://midwestapplianceparts.com
Sep 10, 2007 | Hotpoint HSS25GFP Side by Side...
KitchenAid KSCS25FKSS Side by Side Refrigerator Logo
751 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
