Sharp 1631 when I close the side door where the rollers are the machine want to start but only for a split second. I found some pcs. of black plastic that appears to be like a trigger or something Is there any help Thanks
  • Jim Keysor May 11, 2010
    Do you get a code, One thing on this machine that breaks is the end of the drum that turns in the machine. The points break off and then the drum does not turn.. Good luck
    Problem Solver:
  • 7 Answers
Does the "Misfeed" Light go on?
If yes the photocoupler flag on the fuser (long gate with green sticker on the left) is broken. Fuser is what you called "rollers". If that's the case you will need a new fuser.
Posted on Dec 21, 2008
I am getting a ch message on my sharp al-1631 copier and can not find the manual. Do you know what this means?
CH stands for close hatch check that the front and side doors are closed. (open both then close again)
Jun 21, 2011 | Sharp AL 1631 Copier
I do I remove the old drum in a sharp AL 1631 copier?
You have to open the door on the right side of the machine first, then you can open the front door. Remove the toner cartridge and then you can remove the drum unit.
Jun 02, 2011 | Sharp AL 1631 Copier
Sharp al 1631 need drum roller reset code
enter code 42 start 1 start.
(press C auto C auto 42 copy1 copy)
Apr 28, 2010 | Sharp AL 1631 Copier
The "Paper Jam" light on my Sharp AL-1631 copier stays on
The paper detector on the fixing units have a history of going bad. The fixing unit is the hot roller above the drum inside the right door on the top. As the copy comes thru the rollers the paper hits a plastic lever that is spring loaded and located in the middle of the fixing unit. The sensor is all the way to the right side of the fixing assembly. If you move the lever in the middle you'll see a piece of plastic moving on the right, that piece comes out of the sensor and if can't reset the jam, that piece may not be resetting itself back inside the sensor. This is difficult to try to explain.
Good luck
Bob
Apr 23, 2009 | Sharp AL 1631 Copier
Solution for "CH" code given by the copier Sharp SF2022
Hello sir; CH code means somewhere the door open , it seems like right hand side door did not close right.
Feb 13, 2009 | Sharp AL 1631 Copier
Green blinking light CH
That is no problem .CH is for that side door is open .just close it or check side door sensor it is dirty clean it .MIAN AKHLAQ
Dec 24, 2008 | Sharp AL 1631 Copier
Could not pick up papers from paper tray.
1- either the tray is not lifting the paper to meet the rollers ( which may indicate a motor problem) or the rollers are not coming down to meet hte paper (clutch problem)
Aug 30, 2008 | Sharp AL 1631 Copier
Woodpecker noise II
A technician should look at this. There could be a gear going bad on it. Ive see a fee cases where the drum gets bad and cant turn any more.
Are there error codes on the screen?
Make sure the right door where the bypass tray is closed all the way.
Jun 16, 2008 | Sharp AL 1631 Copier
Sharp ar5316 blank pages printed and copied.
while standing in front of the copier open the Right door and then then flip down the Front door. Are the levers in place ? usually the front door will not close properly if not.
Second take out the toner and look for a loosely hanging piece of plastic on it, give it a tug, does it seem to be a long peice of clear plastic? if yes yank it all the way out. It is a protective piece sent for shipping. It will be on ALL the toners you get.
If not look at the right side door there is a back assembly there with either a black cylinder type roller or some strings.
Are the strings broken , is the roller in place?
Oct 25, 2007 | Sharp AR-5316 Advanced Digital Imager...
37 people viewed this question
k24674
jasbo
jasbo
