Question about Belkin Computers & Internet
I hooked my Belkin-G-Plus-Mimo-39000 to my laptop. Got it working, now I wanted to get it on my Desktop. its installed, but its asking for a NETWORK KEY. What to do from here.
  • 120 Answers
The Network Key is the method for encrypting a transmission on a wireless network. If you originally setup your wireless router you should know this key. Otherwise, contact whomever setup your wireless router and ask what the key may be. You will want to ask whether it is WEP or WPA as well.
To reset, you can clear the key if you can login to the router, otherwise holding the reset button while the router is unplugged will clear the key (and all the other settings so this might be dangerous). To clear it, hold the button for at least ten seconds.
After a clear, you will need to setup the router again. Consult your documentation if you have it. If it is a netgear or linksys, use IP 192.168.1.1 User=Admin password=Administrator, if you have a D-Link, try IP 192.168.0.1 and User=Admin password=Admin. If it is something else, try either of the previous combos. (unless it is a Cisco, then it is 10.0.0.2 User=Administrator password=Cisco).
Hope this helps, even a little.
Posted on Jul 19, 2008
I have a belkin wireless g plus mimo router and im trying to hook up my new laptop for the wireless access..my other computers are on this currently but i cant find my box to get my access code to hook up...
check network connections on other pc`s.......... ware the code is entered ...
some pc`s allow you to "show code" rather than just the stars
but also check the router as some times the code is on a lable underneath....
might help....good luck..............
cheers
Mar 22, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Printer connection on my Belkin G Plus Mimo
You have to make sure you go to Control Panel/Printers, right click on the printer in the list and click 'Properties' - go to the sharing tab, select 'Share this printer', give it a name, and click OK. Then go to Printers on each of the laptops, select 'Add a printer', then 'Network printer', then 'Browse for printers'. You should be able to see the printer. If all the computers use the same operating system, you're good, otherwise, when you first share the printer, you may want to install additional drivers from the cd to support the different operating systems - alternately, you'll have to install the drivers for the printer on each computer.
Please rate if this helps :)
Mar 06, 2009 | Belkin Wireless-G Plus MIMO Router with...
Hi. I have a Belkin Wireless G Plus MIMO Router, which has been fine to connect my laptop to the internet (although seems slow sometimes). I just got a Wii, but this wont connect to the internet. The Wii...
Check for the wireless encryption settings associated with this. If you're trying to join a network with "Open" settings to a encrypted network it won't work very well.
Nov 17, 2017 | Belkin Wireless-G Plus MIMO Router with...
Belkin wireless g plus mimo router
YOu may have configured static ip address in your desktop computer...
CHange IP setings to obtain Ip address automaticaly.....
or follow
  1. Open Windows Start menu.
  2. Open Control Panel.
  3. Classic view: Open Network Connections
    Category view: Select Network and Internet Connections, and then Network Connections.
  4. Double-click on your active LAN or Internet connection.
  5. Click Properties.
This opens the Local Area Connections Properties window.
  • In the General tab, highlight the Internet Protocol (TCP/IP) item, and click Properties.
  • In the General tab, click
    Obtain IP address automatically....
    and click ok...
    and try to conect it now...
    Let me know it this helps.... GOod luck...
    rate me..
    Regards,
    Dec 03, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    MY LAPTOP IT IS STUCK ON ONE PAGE
    What address are you typing in, what message are you getting?
    Bobby
    Nov 11, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    Setting up port forwarding: belkin wireless g plus mimo router
    candice,
    you can go to this links click here. Select the model of your belkin router and it will give you a guide on how to enalbe port for warding.
    Aug 01, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    Difficult to Establish Connection
    Do one thing at first you configure your dsl and after same configuration in the wireless g,
    then configure the laptops to installed the card driver.and destops also where you want to installed
    the card.
    Jul 01, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    hello!
    normally, if you configure the wireless security settings wirelessly, it will automatically disconnect you from the network. you have to input the security key on the laptop first before it connects you back to the network.
    i suggest, if you really like to configure the settings of your router, get an ethernet cable, connect it directly to the laptop so you can access and configure the router settings and to avoid from being disconnected
    May 25, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    Computers & Internet Logo
    82 people viewed this question
    Top Belkin Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
