Question about Toshiba TP43H60 43" Television
Power light blinking
My power light will blink when pushed but no picture appears
Can you suggest any troubleshooting I may be able to perform?
The light is blinking a code to alert a tech as to the cause of the fault protection being activated, I recently repaired a panasonic, after tracking down a service manual to get the code definitions I found them printed on one of the circuit boards when I got the back cover off. Seems the most common cause is the convergence ICs, in this instance there is likely a short in one of the chips that is throwing voltages off so much that it won't let it power up at all, to prevent further damage. I have the same set and need a schematic, that's how I got here...
Posted on Jul 31, 2008
NO POWER
Need to know how many times the led is blinking.
Re: tv kdl-55ex620 red light blink 8 times Do a Power Reset. 1. While the TV is off, unplug the power cord of the TV from the electrical outlet. 2. Let the TV remain without power for 60 seconds. 3. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.) 4. Turn on the TV. 5. When the TV powers on and a picture is displayed, reset the TV to factory default settings.
  • If the Reset message does not appear and the TV turns off and on, begin again from step 5.
  • If the standby light begins blinking eight times, return to step 1.
6. After the Reset message appears, allow the TV to reset. Do not press any buttons on the remote control or on the TV and do not make any other adjustments for 1 minute. 7. Unplug the power cord from the electrical outlet. 8. Allow the TV to remain without power for 10 seconds. 9. Plug the power cord back into the electrical outlet. 10. Turn on the TV.
  • The initial setup screen displays if the above procedures were performed correctly.
11. Follow the on-screen instructions to complete the initial set up. 12. Perform a system software (firmware) update.
Sep 04, 2012 | Sony KDL55EX620 55 inch BRAVIA 1080p LED...
Fisher Paykel DS605i single dishdrawer with a user-supplied integrate panel. There are three buttons on front. The left-hand button is power button; the center button is start/pause; and the right-hand...
Hello, Thank You for using FixYa. I will be helping you today.Are any of the cycle lights lighting up like rinse and normal and is the light on front blinking and pausing if so how many times is it blinking? Try turning the power off too the unit for five minutes and back on, because if the lid was open some or was stuck it can stop the unit from running.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jun 29, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Power light comes on for about 30 secs, something clicks and both power and ocp lights start blinking contineously. the screen does not light up
I have this model of the sharp tv.Happen to me very often the Power and OPC LED light indicators blink continueosly.Not the power supply board,it the Tuner board that take in the comming broscast signal that have the problems.You still can used this tv.Push the power button sometime the tv it will work right away.Not,each time POWER and OPC lights continueosly blinks.Just push the power button again each time the POWER and the OPC continueosly blinks.Just have push power button again about 4 times each time Power and OPC blinks recycles,it will finally show the backlight and picture come on.My guest,if u do this by pushing power button to recycles about 10-12 times each time the POWER and OPC blinks it time to change the Tuner signal board.
Jun 03, 2010 | Sharp LC-C4655U 46 in. LCD TV
The power light blinks and the tv doesn't turn on
you should perform the initialization to factory defaults.
May 24, 2010 | Sharp LC-32SB23U 32 in. LCD TV
Power surge-no picture or sound, just red blinking power light
Any malfunction associated with a blinking redlight usually indicates a circuit problem or defective component. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Sep 13, 2009 | Panasonic CT-36HL43 36" TV
Blinking green reset light
Can you please supply us with the make and model as well as the blink count of the green light. That count should be indicating the problem circuit. Once that info is posted, we should be able to give you more details and possible solutions.
Dan
Jun 19, 2008 | Televison & Video
No Picture, already replace lamp. model RCA HD50L PW62AYX6
What model set do you have. I also work as a tech at another place that probaly has your troubleshooting guide for your light engine
Jan 17, 2008 | Televison & Video
Toshiba TP43H60 43" Television Logo
116 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
