Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Ice maker doesn't work
There appears to be no water feed to the ice maker. I removed the back cover and there are 2 small motors there. I assume that these are pumps that get the water to the in door dispenser (yellow) and to the ice maker (orange). Cross wiring them (yellow connection on orange pump) and hitting the dispense button does not get the orange pump to work. I can see that there isn't water in the line with the exception of a small amount near the bottom. Am I correct in assuming that this pump is bad? Is there an easy way to replace it?
  • shzacutie Sep 02, 2008
    I have no ice. Water is dispensing when selected, but with sputters, as if there is air in the line. I've noticed that I don't even hear the water being routed into the ice maker anymore. Is the valve too?
  • 481 Answers
  • yes this is the water valve. it does not pump the water but it does turn it on and off like a faucet.
  •  you can purchase the water valve assembly at any appliance parts store or website.
  • you will need your model number.
  • if you need help just let me know.
Mike
Posted on Aug 08, 2008
Water leaking from connection leading in to inlet valve on SubZero 245RFD undercounted refrigerator. Unit has not been turned on for a while so it's not an issue of freeze up. Turned off due to not ma
Hello Mary;
My name is Peter. I am a retired field service refrigeration technician.
You probably have a stuck spool or a plugged screen in your single solenoid water valve as a result of not running the unit.
You must also be careful, plastic tubing over time exposed to the normal heat that comes off the compressor, will dry out become brittle and crack. This is the tubing from the ice maker solenoid to your ice maker water feed tube, will one day need to be replaced.
I suspect your ice maker is fine. Lets check it out. I have faith that you can do this. Without unplugging you unit, Remove the white square cover on the front of your ice maker. This cover pops off. There are no screws or retainers. You may need a small flat head screw driver (or butter knife) to wedge the cover off.
After the cover is off, you will see what is called the ice maker motor module. In the center of the module is a small white gear. You will see several small holes. At the 5:00 position you will see 2 holes. One hole is marked 'T' and the other hole is marked 'H'.
We are going to force start the ice maker by jumping it. So, we need a jumper.
Make a jumper - obtain a 3" long piece of either 12 or 14 gauge wire. Strip 1/2" off each end to show bare wire. Form this wire into a horse shoe shape. Perhaps your local hard ware store can help you make one.
Now, put one end of the wire into the 'V' hole and one end into the 'H' hole. The white gear will start to turn. After about 3 seconds remove the jumper wire. At this time your ice maker is cycling. There are fingers that rotate and discharge the ice cubes from the ice cube mold. When these fingers reach the 12:00 position your water valve opens. I suspect you will not hear the normal water flow into your ice maker and you will leak water at the valve.
Therefore if the ice maker cycles (No water fill) and the water valve leaks - bad water valve.
I am limited on the length of my response to questions. Post question. Let us change the water valve. The water valve over the internet is about $25.00.
Nov 05, 2014 | Refrigerators
My maytag msd2433he only makes one tray of ice. It has a new filter, plenty of water pressure and no air in the line
Hello Dave;
Lets run a check on your ice maker:
1.) Remove the plastic front cover on the ice maker. Do not unplug your unit and do not remove the ice maker. Having removed the cover you will see a white gear with a plastic shaft in the center.
2.) On the right is a metal wire arm for turning the ice maker on and off. Put the arm in the down position and then lift it up until it locks in place. Did it lock? If not reinsert the wire end into the back of the motor module. The motor module is the assembly with the plastic gear.
3.) Lets cycle your ice maker. On the front of the ice maker there are 2 holes at the 5:00 position off of the dial they are marked 'T' & 'H'. With a short length of about 12 gauge wire, strip about 1" off each end. What you are going to do is put on end into the 'T' hole and the other end into the 'H' hole. A few seconds after the dial starts to rotate remove the jumper. Observe the complete cycle.
Does it fill with water?
4.) Remove the ice maker. There is 1 screw on the bottom - completely remove. There are 2 screws on the top. These are hangers. Back off the screws so you can lift the ice maker up and away from the wall. With a small screw driver wedge it into the wire harness connector to release.
5.) Remove the 3 retaining screws and disconnect the control arm. Inspect the subassembly for burn marks or broken plastic parts.
6.) You may have a bad thermostat. The thermostat is located between the ice maker module assembly and the cast steel ice cube mold. This sensor tells the motor module that the water is frozen. Then the motor module tells the heater which is on the bottom of the
mold, that the water is frozen and for the heater to turn on. Then the module tells the motor to rotate the harvesting fingers. Maybe a bad heater? Maybe the motor module is bad? Parts are available for your ice maker unit.
Nov 04, 2014 | Maytag Refrigerators
Why does my ice maker not get cold enough to produce ice? I have a Samsung RFG297HDRS French Door refrigerator. Everything is functioning except for the ice maker. Water is getting into the ice maker
Ok Randy, Lets fix it.
My name is Peter. I am a retired refrigeration field service technician.
You are not getting cooling air to your ice maker freezer compartment. Once again Samsung - bad design - put a ice maker in the fresh food section.
So, you have a ice maker enclosed next to the fresh food section where the recommended temperature setting is 35-40 degrees F.
Where as your recommended freezer temperature is +2/-2 degrees F.
There is a air damper/vent from the bottom freezer in the back of your ice maker housing. Lets remove the ice maker to check for ice build up. On the left hand side of the housing on the wall there is a long narrow cover plate. This is where you connector harness is located. There are 2 screws holding the front end in and a tong and groove tab in the back. Remove the cover plate.
Now, pull the harness out.
Lets remove the ice maker assembly. There are two screws in the front end securing the ice maker to the top of the casing. These screws are recessed. They are either Philips heads or hex heads (1/4"). If they are hex head, he recessed hole diameter is small. Some hex head hand tools will not fit. A screw gun will work or a small outside out side diameter hex head hand tool.
Remove these screws. In the back in each corner is a tong & groove. Pull forward to release the ice maker. Using a small flat head screw driver wedge the wire harness to release. Set the ice maker aside.
Inspect the air vent/damper for ice build up. Use a hair dryer to defrost.
I do not believe you have a automatic damper controlled by a thermistor (temperature sensor). If you do, Remove the damper assembly. Get your multi-meter. Set your meter to the lowest Ohm reading (Omega on your meter) Touch the two probes on your meter together, you meter should read 1.0. Disconnect the 2 motor contacts. On the motor place one probe on one contact and one probe on the other contact. If the meter still reads 1.0 the motor is bad. If the meter reads 0-50 Ohms the motor is good.
If there is no ice buildup & the damper motor checks out, replace the temperature sensor.
You will find getting the wiring back into the side panel will be a little difficult. As usual, Samsung is not service friendly.
Oct 22, 2014 | Samsung RFG297HDRS 29.0 CuFt French Door...
Shut water off did not shut off ice maker- now ice maker no longer making ice.
Good day,
Assuming the water has been turned back on for a while, and your sure it's getting to the valve on the rear, follow this guide.
It should cover your problem. The freezer must be cold enough. 10 degrees or colder.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Sep 27, 2010 | Amana ASD2622HR Side by Side Refrigerator
We have a Fridgidaire side by side m#FRS6LF7GS4 The ice maker is not making ice. I'm assuming the water is still flowing to it because we can get water from the door still and we do have the medal arm down...
It sounds like the ice maker has burnt out and needs replacing, Try raising the metal bar to shut it off and then turn it back on, you can also remove the front cover from the ice maker and make sure the small motor inside is turning(this should always be turning when the ice maker is on)
Aug 21, 2010 | Refrigerators
Refridgerator ice machine not working no ice
Good day,
There are many reasons an ice maker will not work. I'll assume the freezer is at normal temperature.
Just follow the steps, and it will get you there.
Feb 03, 2010 | Refrigerators
Have a HOTPOINT CTX18GI fridge. Automatic icemaker doesn't work, but don't know if it's the actual ice maker or any of the switches. Water is going to the line from the sink plumbing via a standard small...
Have you tried raising the arm of the ice maker and leaving it for awhile then push it back down and see if it will work? Should be a cover that is over the plug take the cover off and unplug the ice maker, shouldn't be that hard to take off. I believe you have to squeeze the top and bottom together to remove it but Im not positive.
Nov 09, 2009 | Hotpoint 18.2 cu. ft. Top Freezer No-Frost...
Water dispenses, but no ice
there could be two [roblems with the ice make. #1 the line that feeds the water into the ice maker could be frozen inside where it dumps water into the maker. Take a hair dire and gentl thak pout the inlet line tha tthe water feeds into the maker. then reate that maker so that all the blockage is cleared. or #2 tej freezer need to be coolder. Don't rate these solutions unitl your problems are resolved because then i cannot post in the problem any more and also be sure too rate the so]lution after ypour problems are solved and rate accordingly. and gernerouosly. thanks for using FixYa.
Aug 06, 2008 | Samsung RS2534 Side by Side Refrigerator
Ice maker
My wife installed a new filter and didn't purge (AKA flush) it enough. As a result, my ice maker quit. Since there was air in the line, the water feed into the ice maker froze. You should check your water feed. In your freezer, look to the top right part of your ice maker. You will see a short (2 inches or so) black tube that feeds water into a piece a plastic on your ice maker that looks like a small cup. Squeeze the tube to see if frozen. If it is, there is probably also a frozen pool of water in the 'ice maker' cup. You can use a hairdryer but be very careful as you can melt the plastic. My service guy took out the ice maker and ran it under hot water. He used a small screw driver to get the ice out of the black hose. Removing the ice maker looked pretty easy. You can remove the ice maker door (it justs snaps out). the ice maker also just slides out. If you are not comfortable removing the wire connection, there's enough plat in the wire to allow you access to the frozen cup of water. You could pour hot water over the ice maker while it remains connected. When done, cut power to the entire frig for about a minute. This will reset the ice maker. Note that you may have a wait a few minutes to actually hear the ice maker fill with water since it has a timer mechanism.
Aug 03, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice Maker not making Ice
That plastic piece it part of the ice maker module. It's broken. Will need to replace that module and ice maker thermostat (bimetal) for best repair. If you do this repair you will also need food grade silicone grease (glob) to make a good contact between the thermostat and mold. It this sounds to complicated then just replace the whole icemaker and that will fix your problem.
Oct 08, 2007 | Refrigerators
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
82 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
