Question about Refrigerators
Maytag mtb1950gr freezer fan
The freezer fan on the model mtb1950gr refrigerator is not working. Is this a ralatively easy fix? Other forums said it was the condenser or evaporator fan and it happens often(every 2-4 years) with the Maytag's. Any advice? My freezer is wet on top and it's about 90 degrees out!
  • 958 Answers
SOURCE: Maytag MTB2176HRS not cooling
it could be out of gas...can you open the bottom rear cover and feel the air coming out of the condenser blower. if its not warm, you have a leak where refrigerant escapes...
Posted on Mar 28, 2008
SOURCE: maytag refrigerator side-by-side model MSD2756GE
remove the baskets and shelves in the freezer and remove the rear panels after shutting the fridge down. If you see heavy frost on the coils then the defrost model needs replaced. If not, check the that the fans runs, and then that the thermostat works and then that the damper that allows the air to the fridge compartment is opening correctly.
Posted on Sep 05, 2008
Maytag317
  • 1136 Answers
SOURCE: Maytag model (MTB1950GR) tripped off the power switch and smell
Hi, It sounds like the relay onyour compressor. They will smell when it goes bad. Remove the rear panel on the back of the refrigerator and see if the smell is around the compressor.
Please let me know If I can assist you further.
Vic
Posted on May 23, 2009
james3751
  • 614 Answers
SOURCE: Tips on how to clean the condenser coils of a maytag mzd2766
Turn off power. Water hose with sprayer. Soak the coil. Spray with 409 cleaner. Let it ser for about 10 minutes. Spray off coil from top down. Do not use to much pressure or it will bend the damage the fins. Bruch clean indoor coil with nylon brush. Your unit will last a lot longer. Rsuty
Posted on Jun 12, 2009
hiltonjug
  • 612 Answers
SOURCE: Maytag MSD2456GEB fridge section warm
Please remember I am attempting to diagnose your appliance without being there and with very little information.
Sorry but if your freezer is 10 degrees, it is running warm. Freezer is designed to run between -10 and 0 degrees. Reset controls, place them in the middle of the scales. The controls can be confusing. The control that turns the unit on and off is your freezer thermostat and the other is the damper that controls the air flow from the freezer into the fresh food section. What I would think is wrong with your unit is one of two things.
  1. You have a defrost problem.
  2. Your inside fan is not running.
1. Look at the inside back panel of your freezer. If you have ice or frost built up on the panel, you most likely have a bad defrost heater.
2. Check to be sure you have air flow inside your fresh food section coming from your freezer. If not and your control is setting around mid-ways, you have a bad fan or your defrost heater is bad and ice is blocking the air flow.
Please rate solution
Posted on Sep 14, 2009
Model mtb1950gr. Freezer stopped working. Fan is blowing cool air up there, but everything is completely thawed. Refridgerator part below it seems to be working fine. Vaccumed back.No change.
Your defrost may be stuck on. Cool air is not the same as freezing air. Frost free freezers use less than freezing air passed over and through the food to warm any ice crystals and move the moisture out of the freezere.
Apr 03, 2016 | Maytag Refrigerators
Why is my freezer warming up?
Sounds like your heater/defroster went bad and by now there is probably ice build up and fan can not push the cold air to the freezer. Very easy fix but you will have to buy new heating cable ($25-40) and strongly advise to buy a new thermostat as well(around$10) it snaps on heating cable and controls power to heating cable whenever there is ice build up.
Apr 26, 2014 | Maytag MTB2176HR Top Freezer Refrigerator
Maytag fridge works but freezer doesn't
Try the control relay/ condenser thats attached to the compressor and provides a momentary spike to start the compressor start windings prior to the unit going into run mode. reasonable and easy to fix
Apr 04, 2014 | Maytag Refrigerators
2005 Maytag Refrigerator Fan Stopped WOrking
What is the model number and is the compressor kicking on?
Oct 28, 2012 | Maytag Refrigerators
MAYTAG MTB2156GE REFRIGERATOR. NOT GETTING COLD. THE FAN IN THE BACK OF THE FREEZER COMPARTMENT DOES NOT WORK. EMPTIED FRIG AND SHUT IT OFF. NOW THERE IS WATER ON THE FLOOR. DOES THIS HAVE SOMETHING TO DO...
Whatever you do do not run the refrigerator with the freezer fan not working. That Fan is about $70.00 depending who you get it from and easy to change. If you could find someone we could do it without calling service, that is what we are here for. See if you can find someone with a digital meter and let me know when ready, Sea Breeze
Feb 17, 2010 | Maytag MTB2156GES Top Freezer Refrigerator
The refrigerator no longer cools. The freezer
ok take your shelves off
the center air hum, it will take a lil strength but lift the air channel up thaen pull staright out, is should pop right out and give you access to the fan...
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=49270&diagram_id=635220#d635220
makse sure you order the correct part 7
does your fan have a blue and white wire
Oct 22, 2009 | Maytag MTF2156GEW Top Freezer Refrigerator
Vic
May 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer Works Frig Stays at 70
Wow, pay for the Premium Assistance Plan to get a quick solution ! I fixed my issue but thanks for the help ! I went to a FREE online forum and got my fix.
Mar 25, 2009 | Maytag MFD2561HE Stainless Steel Bottom...
Fridge is 64 degrees but the freezer is working fine
You may want to see if you have the issue as described at www.AnyoneCanFixIt.com for this refrigerator where the freezer is cold, but he refrigerator is warm...it talks about how to listen for the fan, if no fan sound from within the freezer, there is the step by step instructions to fix available there at the web site.
Mar 17, 2009 | Maytag MFD2561HE Stainless Steel Bottom...
Maytag french door bottom freezer: Fan not working.
very easy the fan cover snaps into place and make sure you get the new motor that is metal not the plastic one they are the problem
Dec 11, 2008 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
141 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
