Question about D-Link AirPlus G Wireless Range Extender DWL-G710 (dwlg710) Repeater
Wireless repeater I am trying to setup a D-Link DWL-G710 with my 2Wire HW1700 wireless modem as a repeater. I am unable to access the D-Link setup page on the web with my 2Wire router to setup the D-Link. Because of this I can't even get started adding it as a repeater. Any help will be appreciated.
  • Burrow Phipps Jul 19, 2008
    I can get to the setup page of my router without any problem but I cannot get to the setup page for the D-Link DWL-G710. Evidently my router and it are not working together and I don't know where to go from here.
    Thanks. I will do this. I had not thought about that being the problem.
    Brigadier General:
  • 6,966 Answers
Might it be that your problem exist because both the 2Wire HW1700 wireless modem and the D-Link DWL-G710 have their DHCP features enabled? During the setup, use static IP adds, disable the DHCP function of the HW1700, follow setup instruction/procedures of the DWL-G710.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 19, 2008
    Genius:
  • 3,422 Answers
Please enter 192.168.1.1 on your browser and you will get a window asking for user name and password.The username is admin and the password is password.
After entering these two you will see the setup page of your router.
Let me know the result...
Please don't forget to rate or accept the solution.
Posted on Jul 18, 2008
  • D-Link Master
  • 6,487 Answers
You just need to connect the devcie to one of your computer via cat5 cable and set a static ip on your pc this how to set static ip:
To set a static IP address:
Open Windows Start menu.
Open Control Panel.
Classic view: Open Network Connections
Category view: Select Network and Internet Connections, and then Network Connections.
Double-click on your active LAN or Internet connection.
Click Properties.
This opens the Local Area Connections Properties window.
In the General tab, highlight the Internet Protocol (TCP/IP) item, and click Properties.
This opens the Internet Protocol (TCP/IP) Properties window.
In the General tab, click Use the following IP address, and enter: - IP address. The static IP address you want to assign to this computer put 192.168.0.2
- Subnet mask. Subnet mask used by your router that should be automatic
- Default gateway. IP address of your router's default gateway. use 192.168.0.1
In Use the following DNS server addresses, enter all the IP addressses for the DNS servers your router uses.
Click OK.
Then:
Click OK to close each window.
Restart your computer.
Then, check your IP address again, to make sure that the changes were applied.
Then now access the expander setup page by typing 192.168.0.30 on the address bar of your Internet explorer and configure it from there.
Hope that helps........
  • Mark Gil
    Mark Gil Jul 18, 2008
    When you already access the setup page of the repeater input all the wireless settings of your 2Wire HW1700 wireless modem
    Good luck
  • Mark Gil
    Mark Gil Jul 19, 2008
    There's a possibility that your router is on a different IP range like 192.168.1.1 and your repeater is on 192.168.0.30 so follow the steps that I posted earlier so you can access the repeater setup page...
    Good luck.........
    President:
  • 357 Answers
Hi there
Getting Started
Setting up a Wireless Infrastructure Network
Pleaseremember that D-Link AirPlus G wireless devices are pre-configured toconnect together, right out of the box, with their default settings.Fora typical wireless setup at home (as shown above), please do thefollowing:
1) You will need broadband Internet access (a Cable or DSL-subscriber line into
your home or office)
2) Consult with your Cable or DSL provider for proper installation of the modem
3) Connect the Cable or DSL modem to the DI-524 Wireless Broadband Router
(see the printed Quick Installation Guide included with your router.)
4)If you are connecting a desktop computer to your network, install theD-Link AirPlus G DWL-G510 wireless PCI adapter into an available PCIslot on your desktop computer. You may also install the DWL-G520, orthe DWL-520. (See the printed Quick Installation Guide included withthe network adapter.)
5) Install the D-Link DWL-G630 wireless Cardbus adapter into a laptop computer.
(See the printed Quick Installation Guide included with the DWL-G630.)
6)Install the D-Link DFE-530TX+ adapter into a desktop computer. The fourEthernet LAN ports of the DI-524 are Auto MDI/MDIX and will work withboth Straight-Through and Cross-Over cable. (See the printed QuickInstallation Guide included with the DFE-530TX+.)
Using the Configuration Menu
Whenever you want to configure your network or the
DI-524, you can access the Configuration Menu by
opening the web-browser and typing in the IP Address
of the DI-524. The DI-524 default IP Address is shown
bellow:
-Open the web browser
-Type in the IP Address of
the Router (http://192.168.0.1)
Note: if you have changed the default IP Address assigned
to the DI-524, make sure to enter the correct IP Address.
-Type admin in the User
Name field
-Leave the Password blank
-Click OK
TheHome>Wizard screen will appear. Please refer to the QuickInstallation Guide for more information regarding the Setup Wizard.
Home > Wizard
Thesebuttons appear on most of the configuration screens in this section.Please click on the appropriate button at the bottom of each screenafter you have made a configuraWireless repeater - 066a66b.jpg.
Home > Wireless
SSID-Service Set Identifier (SSID) is the name designated for a specificwireless local area network (WLAN). The SSID’s factory default settingis default. The SSID can be easily changed to connect to an existingwireless network or to establish a new wireless network.
Channel-6 is the default channel. All devices on the network must share thesame channel. (Note: The wireless adapters will automatically scan andmatch the wireless setting.)
WEP- Wired Equivalent Privacy (WEP)is a wireless security protocol for Wireless Local Area Networks(WLAN). WEP provides security by encrypting the data that is sent overthe WLAN. Select Enabled or Disabled. Disabled is the default setting.(Note: If you enable encryption on the DI-524 make sure to also enableencryption on all the wireless clients or wireless connection will notbe established.)
WEP Encryption- Select the level of encryption desired: 64-bit, or 128-bit
Key Type- Select HEX or ASCII
Keys 1-4- Input up to 4 WEP keys; select the one you wish to uWireless repeater - 94836c8.jpgr />Home > WAN > Dynamic IP Address
  • Dustin Ellse
    Dustin Ellse Jul 18, 2008
    Host
    Name- The Host Name is optional but may be required by some ISPs. The
    default host name is the device name of the Router and may be changed.
    MAC
    Address- The default MAC Address is set to the WAN’s physical interface
    MAC address on the Broadband Router. It is not recommended that you
    change the default MAC address unless required by your ISP.
    Clone
    MAC Address- The default MAC address is set to the WAN’s physical
    interface MAC address on the Broadband Router. You can use the “Clone
    MAC Address” button to copy the MAC address of the Ethernet Card
    installed by your ISP and replace the WAN MAC address with the MAC
    address of the router. It is not recommended that you change the
    Home > WAN > Static IP Address
    Static IP Address- IP Address-
    Subnet Mask- ISP
    Gateway Address- Primary
    DNS Address- Secondary
    DNS
    Address- Choose Static IP Address if all WAN IP information is provided
    to you by your ISP. You will need to enter in the IP address, subnet
    mask, gateway address, and DNS address(es) provided to you by your ISP.
    Each IP address entered in the fields must be in the appropriate IP
    form, which are four octets separated by a dot (x.x.x.x). The Router
    will not accept the IP address if it is not in this format.
    IP Address- Input the public IP Address provided by your ISP.
    Subnet Mask- Input your Subnet mask. (All devices in the network must have the same subnet mask.)
    ISP Gateway Address- Input the public IP address of the ISP to which you are connecting.
    Primary DNS Address- Input the primary DNS (Domain Name Server) IP address provided by your ISP.
    Secondary DNS Address- This is optional.
    Home > WAN > PPPoE
    *** Please be sure to remove any existing PPPoE client software installed on your computers.
    Choose
    PPPoE (Point to Point Protocol over Ethernet) if your ISP uses a PPPoE
    connection. Your ISP will provide you with a username and password.
    This option is typically used for DSL services. Select Dynamic PPPoE to
    obtain an IP address automatically for your PPPoE connection. Select
    Static PPPoE to use a static IP address for your PPPoeE connection.
    PPPoE- Choose this option if your ISP uses PPPoE. (Most DSL users will select this option.)
    Dynamic PPPoE- receive an IP Address automatically from your ISP.
    Static PPPoE-you have an assigned (static) IP Address.
    User Name- Your PPPoE username provided by your ISP.
    Retype Password- Re-enter the PPPoE password
    Service Name- Enter the Service Name provided by your ISP (optional).
    IP Address- This option is only available for Static PPPoE. Enter the static IP Address for the PPPoE connection.
    Primary DNS Address- Primary DNS IP address provided by our ISP
    Secondary DNS Address- This option is only available for Static PPPoE. Enter the static IP Address for the PPPoE connection.
    Maximum
    Idle Time- Enter a maximum idle time during which Internet connection
    is maintained during inactivity. To diable this feature, enable
    Autoreconnect.
    MTU- Maximum Transmission Unit-1492 is the
    default setting-you may need to change the MTU for optimal performance
    with your specific ISP.
    Auto-reconnect- If enabled, the DI-524
    will automatically connect to your ISP after your system is restarted
    or if the PPPoE connection is dropped.
    Home > LAN
    LAN
    is short for Local Area Network. This is considered your internal
    network. These are the IP settings of the LAN interface for the DI-524.
    These settings may be referred to as Private settings. You may change
    the LAN IP address if needed. The LAN IP address is private to your
    internal network and cannot be seen on the Internet.
    IP Address- The IP address of the LAN interface. The default IP address is: 192.168.0.1.
    Subnet Mask- The subnet mask of the LAN interface. The default subnet mask is 255.255.255.0.
    Local Domain- This field is optional. Enter in the local domain name.
    Home > DHCP
    DHCP stands for Dynamic Host Control Protocol. The DI-524 has a built-in DHCP server.
    The DHCP Server will automatically assign an IP address to the computers on the LAN/
    private network. Be sure to set your computers to be DHCP clients by setting their TCP/
    IP settings to “Obtain an IP Address Automatically.” When you turn your computers on,
    they will automatically load the proper TCP/IP settings provided by the DI-524. The
    DHCP Server will automatically allocate an unused IP address from the IP address pool
    to the requesting computer. You must specify the starting and ending address of the IP
    address pool.
    DHCP Server- Select Enabled or Disabled. The default setting is Enabled.
    Starting
    IP Address- The starting IP address for the DHCP server’s IP assignment
    Ending
    IP Address- The ending IP address for the DHCP server’s IP assignment
    Lease Time- The length of time for the IP lease. Enter the Lease time. The
    default setting is one hour
    Advanced > Virtual Server
    If you would like to view more of this manual please CLICK HERE
    Thank you for using FixYa. Have a nice day and please remember to rate this solution as FixYa if it helps you.
How Can I access the installation Wizard? When I type http://192.168.0.30 in URL, it redirects me to non accessable page.
Before accessing wizard make sure that the device is connected directly to your computer with the use of the Ethernet cord (yellow cord)
Feb 25, 2013 | D-Link AirPlus DWL-800AP+ 802.11b Wireless...
Configurar modem dwl-2100 ap speedy
To configure the modem properly, you should refer to the user manual. It has all the settings detailed as well as a troubleshooting list:
Link DWL 2100AP user manual
Jun 24, 2012 | D-Link AirPlus Xtreme G DWL-2100AP...
Can I use the dwl-g700ap as a repeater?
Yes, the DWL-G700AP can be setup as an AP or a repeater as long as your current wifi router is also 802.11g/b.
You can find instructions here: http://www.docstoc.com/docs/2583739/How-do-I-configure-repeater-mode-on-DWL-G700AP
Regards, Chris
May 18, 2011 | D-Link DWL-G700AP 802.11g/b Wireless...
Is there any limit for wireless D-link DWL-2100 AP ?
D-Link AirPlus Xtreme G DWL-2100AP Wireless Access Point provides speed upto 108Mbps, which is the maximum wireless signal rate derived from IEEE Standard 802.11g specifications. However, the actual speed depends upon the wireless network environment, setup and devices.
For further details please refer to DLink Official Product Description
Nov 26, 2010 | D-Link AirPlus Xtreme G DWL-2100AP...
Connect D-Link DWL-G700AP to dreambox decoder
you can connect to your box via FTP via a crossover cable. If you can’t, you might want to read up on that before attempting this.
Now, what we’ll need is…
Ethernet cable (crossover or patch)
Router
Modem
We’ll also assume that you have a router (wireless or not) and that your modem is connected to the ‘Internet’ or ‘WAN’ port.
If you have a free port on your wireless router, you can connect your dreambox to this. Use the ethernet cable (crossover or patch, most modern routers will accept either) connect one end to your dreambox and one end to a free port on your router. You don’t need to change any settings on your router or PC.
Over to the dreambox. Navigate to the networking page on your dreambox.
Setup -> Expert Setup -> Communication Setup
Dec 09, 2009 | D-Link DWL-G700AP (S2984376) 802.11g/b...
Is the DWL-520 Wireless Adapter compatible with the 2701 HG modem
The 802.11b and 802.11g Wi-Fi networking standards are generally compatible. An 802.11b router / access point will work with 802.11g network adapters and vice versa.
There is no such conflict reported with the above devices. But as suggestion use an 802.11g wireless card with the Bell as it would give you better performance
Thanks for using Fixya
proton
Jul 27, 2009 | D-Link Air DWL 520 802.11b (DWL-520)...
DHCP option is disabled when LAN IP is Dynamic on DWL-G700AP
that is right the access point does not have a dhcp server. that will give an ip address to all of your computers or device connected to it wireless. If you have a modem with a dhcp server there will be no problem with the IP but if the modem does not you must have a router and now an access point.
Aug 07, 2008 | D-Link DWL-G700AP 802.11g/b Wireless...
DWL_ G710 unit. unable to access 192.168.0.30 in the URL box
IThe Dlink DWL -G710 t's a peice of ****. Throw the friggen thing out and get a real access point.
Jul 24, 2008 | D-Link AirPlus G Wireless Range Extender...
Setup range extender
Access pointe bağlanmak için öncelikle bilgisayara elle ip adresi vermek zorundasınız daha sonra cihazı ethernet yoluyla bağlayarak ayarlayabilirsiniz.Ancak modeme bağlarsanız ip adresini ayarlamak gerekmez.Kolay gelsin.Good By
Jul 18, 2008 | D-Link AirPlus G Wireless Range Extender...
D-Link AirPlus G Wireless Range Extender DWL-G710 (dwlg710) Repeater Logo
1,837 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
