Question about Maytag Performa LAT2500A
THE WASHING MACHINE IS LEAKING A OIL LIKE FLUID UNDER THE MACHINE?
We are finding oil like fluid under the machine on a Maytag model LAT2500A washing machine that is about 5-6 years old I hate to pour a bunch of service call dollars into the machine if the problem is not solveable for a long term basis. Any suggestions?.
  • 734 Answers
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Dec 12, 2008
Maytag PAV2300AWW has oil in dust cap.
There is alot of oil in a transmission it could last another 4 or 5 years. the only problem is the oil eats the belts up.
Feb 14, 2013 | Maytag PAV2300 Top Load Washer
Red fluid leak in maytag washer la712
Sounds like gear case oil. Dark Red? Did you tip the washer over?
Sep 03, 2012 | Maytag Washing Machines
I have a maytag model A312 washer that has worked fine for almost 30 years. Wash cycle works with water pouring in but the barrel will not spin. I cannot even force it to spin around. Any suggestions...
Hello, Awesome Maytag washing machine. Sound like that wonderful Maytag transmission has finally gone to transmission retirement center. I think they might have rebuilt transmission for your Maytag washing machine. Check with your local Appliance Repair Shop---Maytag---. Ask them if they have a transmission but I am thinking here, it could be belt driven. If it is belt driven, empty the washing machine and be careful when turn over your washing machine. There is two concrete block that hangs on a self leveler to keep you washing balanced during the spin cycle.
Also, check for oil under your washing machine and if there oil then your washing machine has a transmission and it is leaking. Well, Tracy you can try the few thing that I mentioned here. But remember I am only suggesting you try these thing and if you don't fell like you can't handle it. Then get your neighbors and friends to help you, please. GB...stewbison
Sep 07, 2011 | Maytag Washing Machines
Oil is leaking from under washing machine. Looks like motor oil but has no odor. Is this fixable and if so, approx. how much would it cost ?
The only device holding oil under your washer is the transmission. If your washer still has agitate and spin cycles the transmission has not failed but being that there is a leak it will fail soon. Depending on the washer a transmission can be from about 180.00 to 230.00 if you buy the part yourself and do your own labor. If you feel like wrestling with it the front cabinet is held on with two clips under the control panel.
Jul 18, 2011 | Maytag Washing Machines
The washing machine leaks a yellow oil
not good at all, transmission seal is leaking most likely due to a failed bearing in the washer tub
Feb 03, 2010 | Maytag Performa LAT2500A
Oil leaking on kenmore model 110
This is probably transmission fluid leaking out. You can fix it. Depending on the age of the unit and how much you are willing to spend on a unit that age. Call us for parts. 972-859-0929. We ship next day air and nationwide. Hope this helps you.
Aug 28, 2009 | Kenmore 24032\24036 Top Load Washer
Machine is usually very noisy ( like it was out of balance, but isnt) 90 percent time very noisy in the final expell of water, also some oil on the floor under center of machine ? this is a top load...
oil on the floor means your gear box is leaking
if it has been leaking. if it has been leaking for a while, it may have done major damage,and would be cheeper to replace the machine second hand than to fix.
if noise is happening while you are pumping , it may have a bra under wire or small coin in the water pump.
if it is sounding like it is out of balance it may have a support or spring broken or unhooked
as the tub is usually suspended by springs
May 05, 2009 | Maytag MAT12CSD Top-Load Coin Operated...
Oil/Grease under washer machine
Nash, your unit appears to be made by Whirlpool. (Kenmore doesn't manufacture anything, they purchase from major manufacturers and put the "kenmore" name on them) If, as I suspect, it is made by Whirlpool... the top transmission seal is failed allowing small amounts of water to enter the tranny. The water, being heavier than oil, will displace the oil through the top of the tranny... out through a "weep" hole. The weep hole is not designed to allow fluid to escape, it's designed to allow air to enter and exit the transmission housing, compensating for the heat expansion and contraction of the lubricant that should be contained within. Regardless of the manufacturer, you have a main drive system failure on your hands. It'll only get worse from here. Most manufacturers put a 5 year warranty on their drive-trains, you should call them immediately. If it's over 5 years old, it's a very expensive repair.
Aug 30, 2007 | Kenmore 22642 Top Load Washer
Washing Machines Logo
1,457 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
