Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
Zenith E44W46 Audio works - intermittant picture
I'm trying to fix my Aunt's tv, and she attempted to send it to a repair man, but he died unfortunately. But what is wrong with it is that its only turns on sometimes and when it does (I'm just reading this off what she wrote to the repair guy) Comes on sometimes-Audio is always there-intermittant picture. As said above the guy never got to fix it, but he thought it was the digital board, but I am not 100% sure if that is the actualy problem. My aunt has replaced the bulb once already. Also, she said that when it turns on al there is is just blue. So any help (even straight out guesses) would help. Thanks.
I hava a Zenith Model # E44W46LCD telivision. There is a light blue line about an inch or 2 wide running across the bottom of the screen. The TV is about 4 years old. It doesn't get a lot of play probably less than 10 hours a week. can you help me
Posted on Nov 08, 2008
Very dim picture
Ur tv have been in use for at lest 4 or 5 hours a day the last 1 1/2 or 2 year?The projection bulb life it over.Require a new bulb.
May 27, 2010 | Zenith E44W46LCD 44" Rear Projection...
My zenith e44w46 turns on have sound but cant see the picture
Please tell me if you hear any clicking noise while turning on the set. If not tell me what is the status of the stand by/timer light at the front. Does it blink? If yes then how many times does it blink in between each pause. Let me know this info so that we can continue the diagnosis.
Jan 03, 2010 | Zenith E44W46LCD 44" Rear Projection...
Zenith R49W36 Convergence issue
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2009 | Zenith R49W36 49" Rear Projection HDTV
Orange light on the front of the TV
Replaced bulb for zenith e44w46 lcd but the orange light is still on how can I reset the bulb timer on my own without throwing down another 85.00 for a repair guy to reset my T.V.
Jan 26, 2009 | Zenith E44W46LCD 44" Rear Projection...
Turned on and blue all over picture zenith b50m88w
sounds like you may need repair man. convfrgnce circuit problem.  intergrated circuit resistors. not easy repair.
Dec 08, 2008 | Zenith B50M88W 50" Rear Projection...
Junk TV & Poor service
zenith agreed today to replace mine.
Mar 12, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
Picture focus getting worse & worse; now sound becoming intermittent
You are most likely getting bad capacitors in the main power supply as well as the sweep power supplies. Looking at the age of this unit, the cost to replace the power supply, it will cost you about 350 to 450 to repair this set. You MAY ALSO need to replace the High voltage/ sweep board as well. The best way to properly tell would be to call out a factory authorized Zenith repair center. They should have all the boards available to test the TV with. That would also be a bit more to repair. In my opinion, the cost would not justify the repair. Good Luck with your TV set.
Jan 15, 2008 | Zenith IQB55M90W 55" Rear Projection...
Zenith A32B43W color problem
Classic symptoms! Most of the last TV's made by the old, original Zenith company (Rauland division) had bad picture tubes even when new. This probably had something to do with their going out of business and being taken over by a much better Korean company (LG Electronics AKA Goldstar). Another lovely thing they did before biting the big one was to only sell a complete chassis as a repair part. If your TV is older and has a small white paper tag inside somewhere on the picture tube (usually near the larger brand and type number label) with the code "EIA 1101" on it, discard it. I have NEVER seen one of these work correctly! If the CRT is made by someone else, there may be slight hope. Even if the TV is not very old, if it was really made by Zenith, and not LG, the possibility of repair is slim simply because of the change of ownership. I was sad to see Zenith die such a horrible death. They used to be fairly good, but somehow never made the transition to color TV. After 1954 they were essentially moribund.
Oct 15, 2007 | RCA F32450 32" TV
Zenith TV E44W46LCD Picture Problem
The PIP module is bad or the video processor circuit. Most likely a main board replacement will be neccasary. Good Luck
Mar 31, 2007 | Zenith E44W46LCD 44" Rear Projection...
My Zenith B27A11Z Does not display a Picture or audio sound only a load pitch sound apon turning on
The best thing I can recommend is to seek an estimate as we cant teach ya how to fix the set as your aware of and second is if its gonna cost alot then buy a new one . Sorry couldnt be of more assitance man. Good Luck
Jun 13, 2006 | Zenith B27A11Z 27" TV
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
100 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
