Question about D-Link AirPlus G Wireless Range Extender DWL-G710 (dwlg710) Repeater
Setup range extender
I am trying to setup a D-Link DWL-G710 as a range extender with my wireless network. I have a 2wire HW1700 wireless modem and have tried to setup the D-Link using it but it does not let me get online to the D-Link setup wizard so I cannot even get started.
Recommendations please.
  • Smith Emily
    Smith Emily Dec 01, 2017
    Call Us +1-888-274-2621 to get instant support for Kaspersky Support Number, our experts are here to provide all kind of Kaspersky Antivirus support & help.
    Kaspersky Support
I found the solution. first reset de DWL-G710, change the ip 192.168.0.30 to 192.168.1.253 (obiously change your IP of LAN card for 192.168.1.252 example) in the G710 go to network and in the gateway put 192.168.1.254. go to wireless Site Survey, select your 2wire net, connect, select the channel of your 2wire, select your security, write your key and apply and ready to connect :D. Later but secure :)
Saludos from mexico
Posted on Jan 17, 2009
What you need to do is connect a rj-45 cord from your pc 's lan card to the DWL-710 then set the pc ip address manually to
192.168.0.30
subnet 255.255.255.0
Gateway 192.168.0.30
DNS 192.168.0.30
then you will be able to access the DWL-710 web interface to configure your settings
Posted on Dec 23, 2008
Access pointe bağlanmak için öncelikle bilgisayara elle ip adresi vermek zorundasınız daha sonra cihazı ethernet yoluyla bağlayarak ayarlayabilirsiniz.Ancak modeme bağlarsanız ip adresini ayarlamak gerekmez.Kolay gelsin.Good By
Posted on Jul 19, 2008
Trouble logging into a D-Link DWL-G710 Wireless
Let me try to get the info straight:
Your computers IP address (manually configured): 192.168.1.4
D-Link Range Extender IP: 192.168.0.30
If this is correct, you will need to change your IP to something like:
192.168.0.X (make sure it's not in use on your network already)
otherwise you will not be able to connect to it with your comptuer.
Apr 03, 2010 | D-Link AirPlus G Wireless Range Extender...
Wireless repeater
Hi there
Getting Started
Setting up a Wireless Infrastructure Network
Pleaseremember that D-Link AirPlus G wireless devices are pre-configured toconnect together, right out of the box, with their default settings.Fora typical wireless setup at home (as shown above), please do thefollowing:
1) You will need broadband Internet access (a Cable or DSL-subscriber line into
your home or office)
2) Consult with your Cable or DSL provider for proper installation of the modem
3) Connect the Cable or DSL modem to the DI-524 Wireless Broadband Router
(see the printed Quick Installation Guide included with your router.)
4)If you are connecting a desktop computer to your network, install theD-Link AirPlus G DWL-G510 wireless PCI adapter into an available PCIslot on your desktop computer. You may also install the DWL-G520, orthe DWL-520. (See the printed Quick Installation Guide included withthe network adapter.)
5) Install the D-Link DWL-G630 wireless Cardbus adapter into a laptop computer.
(See the printed Quick Installation Guide included with the DWL-G630.)
6)Install the D-Link DFE-530TX+ adapter into a desktop computer. The fourEthernet LAN ports of the DI-524 are Auto MDI/MDIX and will work withboth Straight-Through and Cross-Over cable. (See the printed QuickInstallation Guide included with the DFE-530TX+.)
Using the Configuration Menu
Whenever you want to configure your network or the
DI-524, you can access the Configuration Menu by
opening the web-browser and typing in the IP Address
of the DI-524. The DI-524 default IP Address is shown
bellow:
-Open the web browser
-Type in the IP Address of
the Router (http://192.168.0.1)
Note: if you have changed the default IP Address assigned
to the DI-524, make sure to enter the correct IP Address.
-Type admin in the User
Name field
-Leave the Password blank
-Click OK
TheHome>Wizard screen will appear. Please refer to the QuickInstallation Guide for more information regarding the Setup Wizard.
Home > Wizard
Thesebuttons appear on most of the configuration screens in this section.Please click on the appropriate button at the bottom of each screenafter you have made a configuration change.
Home > Wireless
SSID-Service Set Identifier (SSID) is the name designated for a specificwireless local area network (WLAN). The SSID’s factory default settingis default. The SSID can be easily changed to connect to an existingwireless network or to establish a new wireless network.
Channel-6 is the default channel. All devices on the network must share thesame channel. (Note: The wireless adapters will automatically scan andmatch the wireless setting.)
WEP- Wired Equivalent Privacy (WEP)is a wireless security protocol for Wireless Local Area Networks(WLAN). WEP provides security by encrypting the data that is sent overthe WLAN. Select Enabled or Disabled. Disabled is the default setting.(Note: If you enable encryption on the DI-524 make sure to also enableencryption on all the wireless clients or wireless connection will notbe established.)
WEP Encryption- Select the level of encryption desired: 64-bit, or 128-bit
Key Type- Select HEX or ASCII
Keys 1-4- Input up to 4 WEP keys; select the one you wish to use.
Home > WAN > Dynamic IP Address
Jul 18, 2008 | D-Link AirPlus G Wireless Range Extender...
Range Extender DWL-G710 & Wireless N Router DIR-615
Try to configure your new router and you have to reconfigure the Range extender to tally with the new router. The IP Address that the range extender should have should depend on the DHCP server of your router that provides the IP Address.
Jan 12, 2010 | D-Link AirPlus G DWL-G710 Wireless Range...
Got a DWL-G710 wireless extender that will not
First I would try a reset, as this extender should would with your default settings of your network.
I would suggest just giving your router a reset. Here are the procedures for your particular router:
Reset Procedure
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
make sure to setup your wireless security again and make sure to set an admin password on your router after the restart.
Oct 31, 2009 | D-Link AirPlus G DWL-G710 Wireless Range...
Range Extender
Both router and range extender must be setup with the same SSID, encryption key and same FIXED channel assignment.
Jan 22, 2009 | D-Link AirPlus G Wireless Range Extender...
DWL-G710 keeps disconnection from router
sounds like it isn't working anymore.
try resetting it and configuring it again with the network cable
Dec 26, 2008 | D-Link AirPlus G DWL-G710 Wireless Range...
No internet connection via DWL-G710
Your extender may not be able to talk to the router. Make sure you have set default gateway in extender to IP of the router. Turn off encryption first. Check the router if extender shows up in active client list or active mac address list.
Oct 18, 2008 | D-Link AirPlus G DWL-G710 Wireless Range...
DWL-G710 and DWL-700AP compatibily problem
when using the AP you have to make sure you set the SSID, channel & wireless key in the AP the exact same as the router and make sure when configuring the Ap that you set the default gateway as the IP address of the router.
Nov 03, 2007 | D-Link AirPlus G DWL-G710 Wireless Range...
D-Link AirPlus G DWL-G710 WIRELESS EXTENDER
the IP address must be different on the router & extender but use the same subnet mast. The extender has to have the gateway set as the IP address on the router.
Sep 16, 2007 | D-Link AirPlus G Wireless Range Extender...
LAN problems with the router
Are you using the correct cable type. If it is a CAT5 type cable it could be you are using a patch cable rather than a straight through type or vise versa.
May 23, 2007 | D-Link AirPlus G DWL-G710 Wireless Range...
D-Link AirPlus G Wireless Range Extender DWL-G710 (dwlg710) Repeater Logo
1,871 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
