Question about Linksys Wireless-G Broadband Router
Change passport I cannot get connected to my laptop, it says enter password, I never made a password to begin with..So how do i fix that?
    Scholar:
  • 43 Answers
Are you talking about it asking for a Network Key or are you trying to login to the web interface of the router to configure it?
At any rate, if it's a network key you're looking for and you do not remember it I would connect your laptop to the router using a network cable and log into the web interface to reconfigure the key. All you need is the IP Address of the router which you can find by going to a command prompt (START MENU | RUN | Type CMD | Click OK) and typing IPCONFIG. Hit Enter and you will find the "DEFAULT GATEWAY". This IP Address is the address fo the router.
Put the ip address in your address bar in internet explorer or whatever browser you use. Log into the router. If you never created a password the default for most LINKSYS routers is a blank username and admin as the password.
You can go to the wireless security section and change the security key.
Hope this helps.
MO
Posted on Jul 19, 2008
How to retrieve Cisco router password without losing configuration?
You can't, otherwise there would be no point in having a password would there!
Dec 24, 2016 | Cisco Computers & Internet
Reset bios password on an acer laptop
To reset BIOS password, you must have the password to begin with. If you have that, enter the setup and navigate WITHOUT changing any setting, until you find "Change password."
That's a blind guess, but educated.
Dec 03, 2016 | Acer Computers & Internet
I will like to chang
If you are talking about your windows password and you are using Windows 7 I have found a good step by step set of instructions at http://pcsupport.about.com/od/windows7/ht/change-password-windows-7.htm. Follow steps 1-10, if you require further assistance I can certainly clarify any of those steps.
Oct 25, 2012 | HP Performance Laptop NC6400, Top Rated...
Remove toshiba password from bios satellite 3000-x4
The Basic Input/Output System (BIOS) password is not set by default on Toshiba laptops. When set, the BIOS password must be entered every time you turn on your Toshiba or wake your system from Standby mode. If you forget the password, you cannot boot your system. Prevent having to enter a password or the results of forgetting the password by removing the BIOS password from your Toshiba laptop. Other types of passwords can be set, such as a Windows password, to prevent unauthorized access to your machine.
1. Turn off your Toshiba laptop.
2. Wait 30 seconds and turn your laptop back on.
3. Press "F2" repeatedly as soon your Toshiba laptop begins booting until the BIOS menu screen appears.
4. Enter your existing BIOS password and press "Enter."
5. Press "F2" again to enter the BIOS, if prompted.
6. Use your arrow keys to select the "Security" tab in the BIOS menu.
7. Use the arrow keys to select "Set User Password."
8. Press either "F5" or "F6," depending on your Toshiba laptop model, to open the Password section.
9. Enter the current password into the "Old Password" prompt and press "Enter."
10. Press "Enter" when the "New Password" prompt appears. Do not enter any text in this box.
11. Press "Enter" again to confirm the new password.
12. Press "F10" to save your changes and exit.
I hope you find it very helpful. Best regards.
Aug 16, 2011 | Computers & Internet
My passport WD has a password hint. how can i change ma password and turn off password hint?
IF U FORGOT URPASSWORD THEN SEE HERE WELL DEAR IF U FORGOTUR PASSWORD WHEN U WANT TO LOGIN INTO WINDOW THEN RESTART UR COMPUTER PRESS F8GO INTO SAFE MODE JUST WAIT FOR A WHILE
AFTER ENTER ADMINISTRATER THEN GO To
CONTROL PANEL THEN
USERACCOUNT THEN
REMOVE OR WHT EVER U WANT TO DOO. other method
Click on START -->RUN.
Type compmgmt.msc & press enter.
In the left pane, select COMPUTER MANAGEMENT--> SYSTEM TOOLS--> LOCALUSERS AND GROUPS--> USERS.
Then in the right pane, select the user name whose account you want to change.RIGHT CLICK and then click on SET PASSWORD from the pop-up menu.
Enter the new password. Click on OK.
There you have it. You have changed the user's password
Feb 26, 2011 | Computers & Internet
I got a toshbia satellite laptop and when i turn it on it ask for the hdd/ssd password how do i fix this
You need to remember what the password is or take it to a Toshiba dealer who can fix it for you.
Feb 19, 2011 | Computers & Internet
Good afternoon sir,i am sachin patel and my friend lost his passport so pls give advise for getting passport number from online way.
1st step : A memory aid can help remind you of your password. If you have entered a password hint in your user account, you can access the hint on the Welcome screen. To display the hint, click the question mark (?) that is next to your user account.
2step: How to set a password hint as a precaution
  1. Log on to your computer.
  2. Click Start, and then click Control Panel.
  4. Click your user account, and then click Change my password.
    1. Enter your current password, enter a new password, and then enter the new password again to confirm it.
    2. Enter the password hint, and then click Change Password.
      1. The change will take effect the next time that you log on.
      Note If you want to keep your existing password, you must enter it as the current password, enter it again as the new password, and then enter it one more time to confirm the password.
      Thanks and regards Chetan Patil
Dec 25, 2010 | Computers & Internet
Forgot my password
During the boot up process you will see on the screen press delete to enter set up
Press delete during the boot up process to enter BIOS scroll down to set user password you can change or remove your password from there
hope this helps
Sep 29, 2010 | Western Digital Passport WDXML800UE...
Hi, I need to unlock my belkin N router because I have misplaced the password and can not connect my ipod or any other technology to it... Can you please help?
Restoring the Factory Defaults
Press and hold the “Reset” button for at least 10 seconds, then
release it. The lights on the Router will momentarily flash. The
“router” light will begin to blink. When the “router” light becomes
solid again, the default restore is complete.
Then, use your Setup CD and go though the setup wizard and you'll be back up again soon!
Mar 12, 2010 | Belkin F5D8236-4 Router
Im forget mein passport
f you cannot boot the ThinkPad, you will have to reset the IBM ThinkPad password via hardware.
If only the power-on password is set, do the following to remove the power-on password.
1. Power off the computer
2. Remove the DIMM cover on the bottom side of the computer.
3. Short-circuit the two password pads or put a jumper on the contacts to short the circuit.
4. Under the short-circuit condition, power on the computer and wait until the POST ends. After the POST ends, the password prompt does not appear. The power-on password is removed.
5. Reinstall the DIMM cover.
If both the power-on password and the supervisor password are set, do the following to remove the passwords:
1. Power on the computer by pressing and holding F1.
2. Enter the supervisor password. The Easy-Setup menu appears.
3. Click on the Password icon.
4. Click on the Power on icon.
5. Enter the supervisor password and press the Space bar.
6. Press Enter twice.
7. Click on Exit; then click on Restart.
Please rate my response.
Feb 17, 2009 | IBM ThinkPad T20 Notebook
Linksys Wireless-G Broadband Router Logo
62 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
