Question about NEC Computers & Internet
RAID driver I unable to establish which RAID driver needed. Uses Intel Matrix Storage Manager option ROM v7.5.0.1017 ICH9R. NEC c5200-042 RD38xxxx..... Intel Chipset C33
  • mike_rusling Jul 19, 2008
    This is a preinstall, no os disks, XP Pro.
    Machine does not have a floppy either.
    I have only just located a board tha appeas to have similar characteristics as the NEC dog I am working on. Hope that provides some sort of solution..
  • 84 Answers
Best way to set up raid is using a floppy drive . What are you trying to instal it on XP or Vista ? Vista has much better raid support than XP does
Posted on Jul 19, 2008
I need a diagnostic tool for RAID falure code 0. Initial boot indicates degraded condition. DISK scan does not seem to remedy the issue. Did the drive actuually fail? Is there a fix? Primary disk still...
It looks like you have two arrays here. The first one being a mirrored RAID array and has only one disk. This means that the other disk has failed in some sort. This does not mean that the drive is bad, just the RAID failed for some reason. You will need to rebuild the RAID if you want to maintain the same level of redundancy.
You can just attempt a rebuild the RAID to the same drives but if this fails you will want to replace the bad drive. In order to do this you will need to make sure you can tell which drive is which. You do not want to mirror the bad drive to the good one.
If attempting a rebuild to the existing drive does not work or is not an option (because the failed drive could really be bad), you will need to determine which physical drive needs to be replaced. You may be able to hot-swap the drive but if you can power things down, that is always safest. Once the new drive is installed, you can rebuild to it and all should be well after that.
Jan 04, 2011 | Dell Dimension 9100 PC Desktop
What is intel(R) matrix storage manager
Yes you need it. document.write("The files below contain the Intel® Matrix Storage Manager.
This driver provides support for high-capacity & fault-tolerant Serial ATA (SATA) RAID 5 arrays and high-performance & fault-tolerant SATA RAID 10 arrays on select Intel® 5 Series, 4 Series, 3 Series, 965, 975X, 955X and 945 chipset-based platforms. It provides support for high-performance SATA RAID 0 arrays & redundant SATA RAID 1 arrays on select Intel® 5 Series, 4 Series, 3 Series, 965, 975X, 955X, 945, 925, 915 chipset-based platforms. It also provides AHCI support on select Intel® 5 Series, 4 Series, 3 Series, 965, 975X, 955X, 945, 925 and 915 chipset-based platforms, as well as on Mobile Intel® 915/910 chipset-based platforms.
Note: Intel® RAID Technology requires the Intel® ICH9R/ICH9M-E/ICH10R/PCH/PCHM SATA RAID controller hub, Intel® 82801HR I/O controller hub (ICH8R), Intel® 631xESB/632xESB I/O controller hub, Intel® 82801GR/GH I/O controller hub (ICH7R/DH), Intel® 82801FR I/O controller hub (ICH6R).
DISCLAIMER: This software is provided by Intel only for the convenience of its customers. THIS SOFTWARE IS PROVIDED \"AS IS\" WITH NO WARRANTIES WHATSOEVER, INCLUDING ANY WARRANTY OF MERCHANTABILITY, NON-INFRINGEMENT, FITNESS FOR ANY PARTICULAR PURPOSE, OR ANY WARRANTY OTHERWISE ARISING OUT OF ANY PROPOSAL, SPECIFICATION OR SAMPLE. This software is furnished under license and may only be used or copied in accordance with the terms of the license. The software is subject to change without notice. Intel assumes no responsibility or liability for any errors, incompatibility issues, inoperability or inaccuracies that may appear in this software.
See the Installation Instructions page for a list of system requirements and considerations.
Note: Before installing this application or requesting technical support from Intel, it is suggested that you first contact your system manufacturer. They may provide software which is specifically configured for your system.")The Intel® Matrix Storage Manager.
So don't delete it.
Mar 10, 2010 | Computers & Internet
RAID-1 failure on Dell Dimension 9100 Desktop
Since you are using RAID 1 (Mirroring) you will only need to send one drive for data recovery.
Since the Dimension 9100 uses SATA HDDs yes you can increase the storage capacity up to a matched pair of 650GB drives. I'd suggest you use the most current BIOS revision, but SATA controllers seem to be much more agreeable to large HDDs vs the EIDE ones before them.
RAID is redundancy, but it is not a data backup, as you have learned. Important data should be backed up to DVDs monthly/quarterly etc. and you can even do critical backups weekly.
Jan 06, 2010 | Dell Dimension 9100 PC Desktop
Where can i fiin the drivers to instal windows xp to my averatech All-In-One Intel Desktop PC - Intel Core 2 ??
If you mean the third party Intel drivers then what you need is Intel Matrix Storage Manager.
Read the information and download the right drivers for your machine here >>>>
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2101
Please make sure you read all the information about Matrix Storage Manager as you have to get this right for it to work whether you choose the floppy method or the 32 - 64 MB flash/USB method.
Good luck.
Aug 18, 2009 | Averatec D1002UHCE-1 All-In-One Intel...
Can't create RAID
It sounds like you have created an install disk. It also sounds like you pressed F6 to install additional drivers. Your install disk probably has 2 drivers on it. You must install them separately. So--you will have to tell the install program twice to install each driver in turn. Once you do that, it should work.
Jun 03, 2009 | Intel Motherboard
Virus (need to wipe cpu)
What you have to do is make a floppy disk with sata drivers on it and get a usb floppy drive, because its intel you need the matrix storage manager. get it from here:
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2101&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go!
Download the matrix storage manager and the read me file on instruction on how to install xp with extra drivers.
Any problems post back
Good luck
Jan 08, 2009 | Compaq Evo D500 PC Desktop
Unable to find Mass Storage Controller Driver
Hi koolkeef, your KT7A-RAID uses the KT133A chipset. You can find drivers for that chipset located at VIA's web site.
http://www.viaarena.com/default.aspx?PageID=2&OSID=1
Happy hunting & good luck!
Mike
Apr 01, 2008 | Abit KT7A-RAID Motherboard
Wont Install
Ofcourse you will need it..Get your DVD writer's brand and model...
Oct 27, 2007 | Intel DG965WH Motherboard
Computers & Internet Logo
355 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
