How to replace or fix caliper in toshiba lcd tv 52 inch wide screen
I have a black screen what is the problem
Posted on Nov 22, 2008
A Toshiba Flat Screen (52"
U tries check the power source and unplug,replug the tv back like about an hour later.For the tv to do a resetting itself back to the factory setting.No,fans in LCD or Plasma flat tvs.If this tv a LCD flat screen tv than the tv have power supply board problems,this tv doesn't have fan design into it.After it goes off the tv power LED light indication on the tv bazel frame are blinking?Yes that the tv have a power supply board can't sustance power voltages to the tv anymore.The tv power supply board that the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.Or have the tv service by a athorized LCD tvs and Plasma tvs shops.
Aug 17, 2011 | Toshiba 52HL167 52 in. LCD HDTV
I got multiple thin colors on the middle of the screen
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display issue (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further updates will be on my Facebook page.
Aug 17, 2011 | Toshiba REGZA 52RV530U LCD TV
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
Toshiba regza 52xf550u has a 6 inch multi colored line in the middle of the screen...what is the problem
If it flickers and changes colors like my 52" did, I removed the back panel cover, tore off the cheap foil on top and removed the t-con board. Used a head gun as I seem to fix alot of things with it now adays since lead free solder is cheap, heat the points up for about 2 minutes, replace it and throw some air circulation. I also noticed the top of my lcd has two main boards the are supposed to match up a platic pin and slide into place, the boards were warped and wouldn't stay down. I used a dremel polishing wheel, cut it in half and wedged them down and tv is running clean again.
May 15, 2010 | Toshiba 52HL167 52 in. LCD HDTV
I have a 52 inch SONY Bravia that has been stuck in zoom mode since last night. iI am unable to see the writing and/or tops of heads on top of screen. any help available?
Press the "WIDE" button on the TV remote a few times to change the TV wide mode settings until you get it to "FULL". If that does not fix it, look on your Cable box remote for an "Aspect" or "Format" button and press it a few times. I hope this helps.
Apr 19, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
I have an 8 inch wide yellow vertical band in the picture of my 52 inch LCD Samsung TV, what is this? I just moved into my new house a couple of weeks ago and purchased a new 52 inch TV, We are without...
If the band is there within the menu then the screen has a fault. If not then possible signal ghosting issues and a proper aerial should fix that.
Jun 30, 2017 | Televison & Video
I have a black line going across my 52' samsung lcd tv.
If you can see this line with the unit off you have what is called delamanation.The only fix for this is panel replacement.This is a common problem with Samsung LCD panels.
Jan 12, 2009 | Samsung LN52A630 LCD TV
Samsung 52 Inch LCD 120hz. 3 inch wide vertical line on screen
This is a problem with the LCD panel. If the tv is out of warranty, I would call Samsung and see if they will pay for the panel and you pay for the labor. The panel is not cost effective to repair. If Samsung will not do anything you will need to buy a new tv.
Nov 16, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
