Question about Polaroid PDM-0742 Portable DVD Player
Polaroid lcd tv-combo
My tv went off and now the red light blinks but will not come back on
  • Polaroid Master
  • 19,396 Answers
If the TV goes off completely, then is usually a faulty power board.
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1Theinternal circuits are jammed because of electrostaticcharges accumulating on capacitors, or because of a wrong voltage readby the main chip on your monitor controller board. this started theprotection circuit.
2 The protection circuit detected a wrongvoltage or abroken contact, identified an internal fault and kicked in, starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Payparticular attention at inverter and power board, power board can beinspected looking for bulged or leaking capacitors, then tested with amultimeter. The inverter is more difficult to test , there is need toread voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on Apr 19, 2009
The infrared receiver light just keeps blinking red and TV won't power on. Tried unplugging for a little while but didn't help.
kindly count the blinking led to diagnose where the fault came from..
also try the initial check....open the back cover and inspect the power supply board for any bulged capacitors inside..
Jan 18, 2012 | Polaroid 4241-TLXB 42 in. LCD Television
I have a Polaroid flat screen TV 32 inch lcd W Red Light Plz HELP
blown cap in the power supply it will be domed on the top where it vented
Sep 16, 2009 | Televison & Video
Polaroid LCD TV Model 3200 - Will not turn on
you have a power supply problem.. I have fixed serveral tvs with this problem. normally you have to replace busted capacitors in the power supply board.
Nov 10, 2008 | Polaroid FLM-3232 Television
Tv doesnot power on
two options _bad backlight inverter or the main board ;eed to be change.
Oct 23, 2008 | Polaroid TDA-03211C 32 in. LCD HDTV
Akai tv turned itself off and now only have a red blinking light-tv will not turn back on model no. lct2701td tv is 2 1/2 yrs old
try looking at the board inside the TV for bulged capacitors see polaroid thread. this is the problem on the polaroid could be the same here.
Sep 16, 2008 | Televison & Video
Change the time
Went to Polaroid.com and they had the instructions online-for free!
Mar 10, 2008 | Polaroid FDM-0700A 7 in. TV/DVD Combo
Polaroid PDM-0742 Portable DVD Player Logo
159 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
