Question about Microwave Ovens
Advantium Turntable On and off
Is this an expensive repair by a service person? I am debating if I should attempt to do this myself or hire a serviceperson. Thanks.
  • 2 more comments
  • Lisa98 Jul 19, 2008
    I wanted to test it using your suggestion before I order a part that is $100+. I tried manually turning the turntable, it turns either way for about 30 to 45 degrees and locks up. I tried the same with a pure microwave oven, that one doesn't turn at all. If I open it up, are there other ways to determine if the motor is the culprit?
    Hi
    I did check the price at the link you provide. The was a motor for $112, a motor assembly for $47 and a motor capaci for $18. Not sure which of these parts may be failing in my oven. I will attempt to trouble per your advice. Thanks.
  • Lisa98 Jul 20, 2008
    My model number is zsc2001fss01. Thanks for your patience and help.
  • Lisa98 Oct 30, 2008
    I just got around to ordering the motor and the torx bit to open the panel. I will let you know if I am successful in fixing the turntable. BTW, the part went up $5 since July!
  • Microwave Ovens Master
  • 9,086 Answers
You mean replacing your turntable motor or coupler? It's generally not difficult.
You just want to be sure it's bad. Make sure yours is not shut off via the control panel.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. You may have to cut the motor cover off with snips, then use a screw when reassembling it.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Please reply back here (instead of starting a new thread) if you still need help.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 19, 2008
  • 2 more comments
  • William Miller
    William Miller Jul 19, 2008
    $100 for a turntable motor?? Did you check the price here?
    Be sure to inspect the coupler, and there are a couple of other tests for the motor.
    One way to test it is to remove it, then grip the shaft with pliers and try gently turning it.
    Or remove it and connect 110V to it and see if it runs right.
    You would need to use a "cheater cord" if you have one to test the motor out of the oven. See this page for details of one kind of test cord. Obviously, this type of test can be lethal, so be very careful!
    Hopefully that answers your questions satisfactorily, but if not, please feel free to reply back.
    thoughtful rating of our answers.
  • William Miller
    For models SCA2000BAA03 and SCA2001BSS03 for instance, the turntable motor (ref # 1472) is $47.37.
    The other motor is your hood / exhaust / vent motor, and the motor capacitor goes to that fan. You won't need either of these.
    Just for the record, a technician will likely charge $75 to visit your home and about $75-90 to do the work of replacing the motor, plus the cost of the motor with his markup (making the part cost about $100) or so for a total service call of about $250-275.
    I was trying to help you do this simple job yourself in a safe and cost-effective way.
    What model number do you have? (Avantium 120, etc. is not a model number). I'll look yours up.
  • William Miller
    William Miller Jul 20, 2008
    Sometimes that site doesn't list all the part choices, and unfortunately this was one of those times.
    But the good news is that I was able to find GE part numbers from the GE site, then price them at the Pros site.
    Part # WB26X10073 is the new motor and new RF gasket (important) and it runs only $47.37.
    If you've tested the motor and need to order a new one, just enter that part number
    here.
    Take care.
  • William Miller
    William Miller Nov 01, 2008
I have a GE profile advantium oven 120 that is just over 1 year old the turntable rotates but as soon as I put on the glass or mental tray it will not rotate what is the problem?
Either the coupler is cracked, the motor is defective, or the turntable support ("rotating ring asm") is worn or defective.
The service manual is here and you can find links to helpful exploded view diagrams and order parts here.
Sep 26, 2011 | GE Advantium 120 Convection/Microwave Oven
The handle of my Advantium 120 has broken off. Can this be repaired and can be done by us or a service repair man?
It can be replaced by either a repair person or if you can source the part, yourself as it is part of the frame and not the high voltage electrical stuff inside.
Oct 23, 2010 | GE Advantium 120 Convection/Microwave Oven
Our turn table doesn't turn anymore . . . Please help. thank you!
If the oven is still heating, but the carousel isn't turning, this problem is commonly attributed to a turntable motor that has worn out and may need to be replaced. The motor is attached to the center plastic piece (called a turntable shaft, turntable ring or coupler) under the middle of the glass tray. The following link explains how to access and replace the motor:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
This is a very simple repair, that usually is not expensive. The price range will be determined by the model and manufacturer. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
You can refer to any of the following websites for comparison:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites listed have helpful exploded view diagrams to assist you with locating and properly identifying the part(s) you need.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Jun 11, 2010 | GE Advantium 120 Convection/Microwave Oven
How do you reset the microwave power? Is there an external circuit breaker if the main house circuit breaker did not switch off?
There is an internal cartridge fuse, as well as thermal fuses. It is not recommended that you attempt any internal repairs on a microwave due to the presence of very high voltages and the danger of microwave radiation if not reassembled correctly. Residential microwaves, if not under warrranty, are generally considered disposable. Parts and service are very expensive.
Feb 25, 2010 | GE Advantium 120 Convection/Microwave Oven
GE Spacemaker microwave turntable no longer turns. Microwave still heats, but turntable has stopped working. What are likely causes? And is this something I can attempt to fix myself?
This is a common problem the turntable motor has failed, it can be replaced.. but Microwaves are VERY dangerous. Due to the enormous energy stored in the main Capacitor, this MUST be discharged to earth B4 attempting any repairs. apart from that though should be easy enough. I do recommend a reputable service center/man tho.
Jan 26, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Turn table doesn't turn. The middle peg doesn't move.
The microwave oven does not have a drive belt for the turntable. The component you describe that the carousel plate sits on its called the turntablel shaft or turntable coupler and it is attached to the turntable motor. This problem is commonly caused by a turntable motor that has worn out and needs replaced. The following link explains how to access and replace one:
This is a very simple repair, that usually is not expensive. The motor usually averages about $35 - $40, but the price also depends upon the model. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
You can usually purchase replacement parts at the any of the following websites:
repairclinic.com
The first three sites listed offer helpful exploded view diagrams to assist you in parts location/identification. If you have any questions, please post back with your complete model number and let me know. I hope this helps you.
Dec 20, 2009 | GE Advantium 120 Convection/Microwave Oven
The microwave is not heating. Light comes on, fan comes on and turntable rotates but nothing gets hot.
either your hi-voltage diode,capacitor or magnetron are defective,if your not electrically savvy,don't open the unit up, by hi-voltage i mean the cap can store up to 2,000volts a.c.appx 18 times whats at your plug in receptacle,if you do tackle it,make sure to completely discharge the cap before attempting any repair...gooid luck and be safe
Aug 23, 2009 | GE Advantium 120 Convection/Microwave Oven
Start button intermittent eg press many times (maybe 20) to start
Problem identified as plastic pushbutton on control panel, solution: interchanged with turntable on/off button (nevrer used). Had paid Miele €115 call out (for person who knew nothing about microwaves), Miele operate a closed shop. Local repair service say Miele will not supply parts, Miele designated repair agent will not repair microwaves, Miele will only send "engineer" to customer, no drop off facility. Was forced into buying new microwave oven from Miele as only way of recouping callout charge. Subsequently had a go myself with above positive positive result - now have a spare microwave cooker.
Mar 18, 2009 | Miele M625EG Convection Microwave Oven
GE Advantium Microwave not heating food
If you want it fixed call sears for service. I would not recommend taking this microwave apart if you dont work on them for a living. only because there are 14 million thing that need to be remove to do a simple repair.
Dec 04, 2008 | GE Advantium 120 Convection/Microwave Oven
Arcing
My Advantium was arching at the turntable. Replaced the turntable roller assembely (that hold the metal or glass plate) and the arching went away.
Nov 16, 2008 | GE Advantium 120 Convection/Microwave Oven
Microwave Ovens Logo
119 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
