Question about HP Photosmart C6180 All-In-One InkJet Printer
Copys come out blank
Printer head moves back and forth but does not transfer ink ?
  • Anonymous Jul 22, 2008
    I have the same problem and when you call HP, they cannot help you. "Never heard of the problem" - they only give you crappy adwise and tell you to do all the things you probably have already tryed.
    Guru:
  • 1,049 Answers
A couple things can cause this you may not have tried yet.
  1. First in your printer driver properties, select the highest dpi setting and the correct paper setting for your type of printer.
  2. Run a print head cleaning cycle. Run up to five cycles in sequence. Print a nozzle check pattern after every one or two cleaning cycles to see if you have made any progress. On most printers, after approximately every fifth cycle, the printer will perform a more powerful head cleaning routine.
  3. Clean the capping station The capping station is a rectangular flat sponge surrounded by a raised gasket. When the print head is in the “parked position,” at the right side of the printer carriage, the gasket of the cap presses against the print head, sealing it. One purpose of this is to keep the print head from drying out due to air exposure. Instructions: (1) push the “ink change” button to move print head off the cap. Unplug the printer (2) Look inside the printer case, below where the print head was originally sitting, to find the cap or caps. A cap is a rectangular piece, approximately 1” high by 2” wide(3) Look at the cap, using a flashlight if necessary. It should be horizontal, not tilted at an angle. If it tilted, there may be a problem with the fixture supporting it. (4) Clean the cap. Sometimes you may notice a buildup of residue or liquid in the cap or on the gasket; other times you will not. Use a drinking straw to deposit warm water, or use the tube from the inside of a bottle of Windex to deposit Windex, onto the sponge. Use your finger to dispense only two or three drops of liquid at a time. The liquid will remain in the cap for a few seconds, but will soon drain out. Repeat this several times. Try not to let the Windex or water spill around the cap, and into the printer. (5) Fold a paper towel into a 4”x4” (10cm X 10cm) pad. Press the towel gently on the sponge to dab away ink and water or Windex. As you push on the sponge, push down and slightly to the right, to protect the spring-loaded mechanism that supports it. (6) Dip a cotton swab (Q-Tip) in water, and use it to wipe gently around the edge of the capping station gasket, to remove dirt buildup there.
  4. Ink flow problems can occur if the air channels on the top of the cartridge become blocked. Check to make sure the cartridges that their is not bits of machined plastic on the top that was not properly removed.
Posted on Aug 07, 2008
Epson printer error codes
The error code E-90 appears when the print head is not able to move back and forth freely.
If the ink cartridge cover is not completely closed, the print head may have trouble moving back and forth. Follow these steps to close the ink cartridge cover:
  1. Turn off the printer
  2. Lift up the scanner.
  3. Press down on the ink cartridge cover to make sure it is completely closed.
  4. Close the scanner and turn the printer back on.
- or, If the packing materials are not removed, the print head will be unable to move and the error code E-90 may appear on the control panel display. Follow these steps to remove the packing materials:
  2. Lift up the scanner to access the printer area.
  3. Remove the tape from the ink cartridge holder.
  4. Close the scanner.
  5. Turn the printer back on
epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-0.jpg epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-2.jpg epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-5.jpg
Sep 01, 2014 | Epson Stylus DX6050 All-In-One InkJet...
Printer does not print but on screen message is "printer cradle cannot move". Print would move back & forth @ one end, moves to the other end to repeat the back & forth movement and then stop with...
This generally occurs when the tracking ribbon becomes dirty and the print head travel cannot be tracked. Open the cover as you would to change your ink cartridge and locate the clear plastic strip behind the print head. Very gently wipe the ink residue from the strip using a cloth damp with water. You should be able to move the print head manually enough to clean the entire strip. Again be very careful as the strip hooks on the left side and is very difficult to reattach.
Aug 11, 2009 | HP DeskJet F380 All-In-One Printer
Black ink won't print
check printer preferences and settings.
May 31, 2009 | HP PSC 1350v All-In-One InkJet Printer
Printer output is a blank page
hi,
* Please check with the ink level in the Catridge.
* Be sure that catridge nozzle is not dry or dirty.
* Check wheather ink nozzle is clogged/ damaged if so use rubbing alcohol to clean them.
* Try printing by replacing new catridge.
Thanks,
Appereciate to rate as "FixYa"
May 23, 2009 | HP PSC 2210 All-In-One InkJet Printer
Ink jam in Epson 2200 printer
First try to print something. You never know it might work. Also you might try very carefully applying a small amount of sewing machine oil on the bar the print head is attached to then again very carefully and slowly move the head back and forth along the bar. It might just be that the bar is dirty and dry and needs a little bit of lubrication.
Dec 06, 2008 | Epson Stylus 2200 InkJet Photo Printer
Paper comes out blank
Chances are the ink cartridges are stopped up with dried ink. These printers have this problem if you don't use them often and just let them set up. Try folding a couple of paper towels so they will be several thicknesses, then wet the paper towels with water and place in microwave and heat them up really hot. Take you ink cartridge and place the ink exit area on the paper towel and rub it back and forth. This will wick the dried ink out of the cartridge exit. Put back in printer and try it. You may have to do this several times to get it back to good condition. Hope this helps.
Nov 20, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Hi, I haven't used my Canon S330 printer for some months, and when I plugged it in just now, it wouldn't print. I replaced both cartridges, and still no printing. The cartridge moves fairly quickly back...
in the print head there are hundreds of minute holes from where the ink of the cartridge comes out when you remove the head check whether the ink is coming from the holes in the head .if the ink is not coming the head may be dry and if the very less ink is coming then some of the holes are blocked. the ink has to come out from that holes for printing.
thanks.
Sep 18, 2008 | Office Equipment & Supplies
Printer not printing at all
Though there was no message to indicate toner issues, I changed the cartridge anyway. That must have been the problem. It works now. The old cartridge was 3 years old and, though barely used, may have outlived its quality. Thanks for writing back.
Aug 11, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Cannon MP 830 Print Issue
sounds like your print drivers on computer are corrupted..try this link for new ones(you may need to completely uninstall the old ones, first, though).
Mar 18, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Both colored & black ink tanks are new but nothing comes out
I have had this problem before. Try removing print head and cartirdges. get warm water in bowl and swirl head in water until water remains clear. Need to empty and refill water a few times. Pat dry with absorbent paper. Re-install head and cartridges and do a clean.
Dec 27, 2007 | Canon i80 InkJet Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
127 people viewed this question
Ben Johnson
