Question about Samsung WF337AA Front Load Washer
Dn error code came up? Won't drain or anything else
I have a warranty , machine is 11 months old, is taking 1 1/2 weeks for repair guy to come, hopefully they can fix it! model # is WF206BNW if I could fix myself I would, pretty sad when I have a new machine and i am going to laundromat.
I have the same problem with mine. Any solution?
Posted on Jul 31, 2008
Whirlpool duet fw95hedco washer won't spin at max speed & leaves all clothes wet. No error codes during tech diagnostic visit. Washer only 18 months old.
Possible Defective washer transmission. Do you overload the washer with heavy items like towels or blue jeans very often? That can cause early failure.
Feb 16, 2017 | Whirlpool Washing Machines
I have a Samsung front loader. It has been stopping with the error code 5E (filter problem ) for a few months now. Turning the machine off then on again after 20min gets it going again. The fault always...
The 5E error mean:
Pump won’t empty - not draining
As usual with these error codes for not draining the first thing to do is check the pump filter but, on Samsung washing machines, the drain pump itself is often faulty. You can find how to fix this problem on youtube, just text it "Samsung washing machine 5E error".
May 16, 2017 | Samsung WF520ABP - 5.0 cu. ft. Steam...
My 5 WEEK OLD nokia e63 won't turn on. the d-pad lights up along with the screen (black) but it won't do anything else... HELP!
This is easy ... it is still under warranty ... take it back ... do not do anything to it as you will void your warranty.
Take it back straight away and have it repaired or replaced.
Simple
Thank you for your interest in FixYa.com
Aug 26, 2011 | Cell Phones
THE WASHER WILL STOP BEFORE THE CYCLE IS DONE AND WATER SETS IN THE TUB AND WON'T DRain
Mine does this all the time... the first time i had the repair guy out, he showed me where you take off the front cover and open the drain and sure enough, lots of fuzz from rugs was clogging the drain of the machine, $108 to show me how to unscrew the drain cover!!! It is happening again, just 5 months later and i have found no fuzz in the drain, so i had repair man out today and now it's my water pressure switch is out, BECAUSE i used too much soap! I use half the recommended amount!!! Switch won't be in till next week! Did i mention how much i hate this machine!!! I want my old top load back!!!
Feb 22, 2011 | GE WSXH208A Front Load Washer
My asko washing machine is leaking it is just over two months old can someone help.. cause it is going to take weeks the repair people say... as they cant get out here for 2 weeks
I hate to say it, but if it's that new, then it's probably a manufacturing fault. You can take the top off the machine and look inside, there may be a loose hose or connection. But remember if you do this and the engineer sees that you have tampered with it, you may have breached the warranty and the visit may become chargeable. It's a real pain, but if the leak isn't disasterous, then towels to soak up the leak and leave it to the guy doing the warranty work is by far the best way forward
Feb 09, 2011 | Washing Machines
Brand New Whirlpool Duet 9450 Error Code PF
This is a problem I've seen before, or something similar. I think you've got a bad connection on the neutral wire. Either in the plug or at the panel. Have electrician check the neutral wire back to the panel from the plug.
Jul 25, 2009 | Dryers
Error light flashing - wash & drying lights flashing.
My machine would not always set properly and various lights went on and off without reason or stayed flickering. I phoned Hotpoint as like you my warranty was finished. They told me to switch off the machine and unplug at the mains. Leave for 10 minutes then plug back in and switch on. It re-booted the control panel and last night I was able to set it properly. If it doesnt work for you I suggest you phone Hotpoint customer service (number of website) and ask if there is anything else you can do to solve the problem yourself before you pay for another service call. Failing that buy a new one!!
May 31, 2009 | Hotpoint 24 in. FDW60 Free-standing...
My 3 month old bosch 300 series washer isn't draining completely and errors at the start of the rinse cycle with E13 falshing along with the rinse light. Help!
the E-13 error code is a drain timeout code. This means the pump has run a certian amount of time without fully draining itself. This could be anything from a clogged drainline in your home to a clogged drainline in the machine, your pump is clogged, pump is burned up, no power to the pump, bad board etc. Most of the time its either something jammed in the pump, or its burned up (from something being jammed in it). Just have to take her apart to find out for sure.
Aug 10, 2008 | Bosch Washing Machines
Whirlpool duet front loader
Sounds like you have a board problem. If the machine is only 1 month old, you should really have a warranty agent look at it. You don't want to do anything that could void the warranty.
Oct 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Samsung WF337AA Front Load Washer Logo
321 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
