Question about Sony Xplod XM-554ZR Car Audio Amplifier
Power my amp has power goin to it but the light is not coming on and my subs are not working. please help!!!!!
  • wrestleboy29 Aug 18, 2008
    my power protection light is red and i can't figure it out
  • slckjij Dec 09, 2008
    Same problem, Sony1200 w. hooked up as high level input with 2 speakers (subs) All wires hooked up, got power to the bus bar on the amp (12v. & remote hooked to a 30amp fuse in the panel, proper gound) but no light.
    I have an 800 w amp in my truck & the remote ain't even hooked up & it works.
    Idunno????
First thing to do is make sure none of your wire going from amp to sub are crossing or touching. Also if its not a mono block amp, which means it has two or more sets of outputs for speakers, you have to make sure those arent hooked up with eachother unless you are bridging the amp. bridging is useing both terminals to power one speaker. if this isnt done right it wont work and the red light will come on. Also make sure ur ground wire is atached properly.
Posted on Aug 25, 2008
  • 631 Answers
Have you checked the on-board fuses?
Did you confirm (with a multimeter) that you have voltage on the B+ and remote terminals of the amplifier?
Did you have the black meter lead on the ground terminal of the amp when you checked the voltage?
Posted on Jul 19, 2008
Rockford Fosgate P3002 stopped working
push down and up on your subs and see if they make a starching noise, if they do then they are blown. take a test light to the amp, on the power and the remote and see if it lights up. if it does then turn the amp down and with a small speaker plug it in to the speaker outs on the amp and see if it plays if not then your amp is bad.
Nov 26, 2013 | Rockford Fosgate Punch P3002 Car Audio...
Why is the red light that says protect on? my amp turns on but it dosent work, i have a sup hooked up & it dosent work. the red light that says protect is on.
first thing check all ground and power wires and make sure ur rca wire make sure it isnt cut in anyway. after that unplug ur sub and unplug the negative wire from ur amp, while its out check the fuses on the amp if all is well put all fuses back if not get new. then plug the negative wire back in if protect goes off check for heat and if no heat inspect the wires from speaker out put all the way to the sub, look for any wire touching another this is were most problems are even the smallest wire can trip a protect. if u still cant find the problem. an amplifier specialist is in order.if its trashed go on ebay and buy a powerbass there goin cheap right now. hope i could help
Oct 12, 2010 | Lanzar VIBE266 Car Audio Amplifier
I have the sony str de485. When i turn it on the display doesnt turn on only some buttons light up so there is power. There is no sound coming from speakers only very faintly through sub woofer. Whats goin...
some important steps 1)check speakers & components connected correctly 2)check that MASTER VOLUME control is not set to VOL MIN 3)check muting 4)may be protective device may be activated to prevent short circuit
Feb 21, 2010 | Audio Players & Recorders
I have kikcer amp 1500.1 is workin good for one year whith 4 memphis 15'' and one day just goin in the protection mode when i turn the radio up can you help me please
sounds like your amplifier does not have the power that your subs need check the rms out put on your amplifier and check how much rms your subs can handle if your amplifier has less rms power then your subs theirs probaly your problem that what happens when it kicks in to protection you could in up fring your out put chips in your amplifier not trying to say that the problem but check your rms power make sure the amp and subs can handle the same power
Oct 31, 2009 | Car Audio & Video
Protection light goes on and off
test subs you may have blown the voice coil
Jan 18, 2009 | Rockford Fosgate Punch P4004 Car Audio...
My amp
Check your speakers with an ohm meter. They should have some resistance but not totally shorted. Its prob the amp that got fried. Connect the amp to the battery with no speakers attached to it if the protection light still comes on then the amp is blown.
If the amp is blown you can send it to people on ebay and get it fixed pretty cheap. Good luck!
Aug 18, 2008 | JBL GTO75.4 Car Audio Amplifier
Amp light flickering
do you have a capacitor its like an extra battery, if you turn the volume way up with cvr's pullin big power, it cuts out because theres not a steady flow of power.... hope this helps
Jun 30, 2008 | Alpine MRP-M450 Car Audio Amplifier
Minimal sound from subwoofer
MAKE SHURE YOU HAVE TOLD THE AMP YOU HAVE A SUB IN THE SET UP MENU UNDER SPEAKER SETTINGS.
IFF YOU ARE USEING SMALL SPEAKERS THEN SET THIS IN THE MENU AND OUT PUT BASS 2 SUB ONLY ,SET XOVER ON AMP IFF U CAN 2 120HTZ, ALSO CHECK THAT YOU HAVE THE SUB CABLE PLUGED INTO SUB OUT ON BACK OF YOUR AMP ,AND NOT THE 6 CHANNEL INPUT.
HOPE THIS HELPS.
CABLE GUY.
Apr 05, 2008 | Yamaha HTR-5650 Receiver
Vibe cbr1 subwoofer
Might not be eathed properly. Check the earth on the battery as well. Theres more juice goin through there now so it might need a bigger earth or ground.
Jan 08, 2008 | Vibe CBR10 Car Subwoofer
Sony Xplod XM-554ZR Car Audio Amplifier Logo
130 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
