Greetings,
UNPLUG and Remove the two screws from lower front panel...pull panel up and out to remove...
There will be four screws to remove front drum support. This is where you slip belt over drum and reinstall front drum support. The belt goes with the belted side up..The next step is to route belt around pulley and loop onto motor shaft. There will be tension when on correct,...reinstall front
