Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Phillips Magnavox 9P5534 C102 I think 52" dated 3/00
We had a worsening problem with the picture shrinking to nothing then expanding over and over again when it was turned on. This lasted about 3-4 months--it seemed as it "warmed up" it would resolve itself, however, now we have no picture at all. We do not have a local repair service and would like to know if it is cheaper to junk it or try to repair it--and HOW?? do you do it? Thanks
  • joejoe8 Oct 16, 2008
    i moved the working tv to my room and now it dosn't work i get the green light but that is all
  • Anonymous Nov 08, 2008
    THE TV KEEPS FLICKERING AND THE PICTURE GET BIG AND SMALL ON THE TV
  • Philips Master
  • 3,459 Answers
This is a common problem with some of the older Philip Magnavox TV sets.  www.magnavoxhelp.com has a repair kit that fixes this exact problem. Its a faulty IC chip.
Posted on Jul 31, 2008
    Genius:
  • 1,139 Answers
Hello mcat,
What you had was a High Voltage regulation problem, now your High voltage section is completely dead. It will not cost much to repair it. I would venture to say that your HV trippler and or you IHVT (intergrated high voltage transformer) are bad. I would also check the Horizontal output transistor to see if it has shorted or opened.I would not advise you to try to fix this yourself, since you don't have a local repair service center, I would suggest not junking it but taking it to a local vocational school and giving it to them.
Posted on Jul 20, 2008
Philips Magnavox 9P6031C103 projection tv quit working 2 years ago (before, the picture began to shink and expand until it finally quit completely with no audio nor video -- turned it on two years later to...
Based on what you described I would say your TV has the "shrinking and expanding" fault. Its a common problem on that model and the symptoms can range from the video shrinking and expanding or no video or no audio....You can read more about this fix on the site www.TvRepairKits.com
Jan 13, 2013 | Philips Magnavox 9P6034C 60" Rear...
I have a Philips Magnavox 9P6040 C102
Yes the coolant in the CRts need replacement. You can get the Phillips CRT Coolant repair kit at the following link which contains the coolant and instructions.
http://servicemanuals.vstore.ca/
Aug 24, 2009 | Philips Magnavox 9P6034C 60" Rear...
Magnavox 52" widescreen 2003... When you turn it on it takes abou
If you have the following symptoms check the site www.TvRepairKits.com . They have a repair kit for this problem.
Screen shrinks and expands - may or may not correct itself after the TV warms up.
After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
Jan 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
No picture or sound
Put the old chip back in...does the shrinking/expanding problem return? If so the new chip may be faulty.
If the problem stays the same - no audio/video  - check your soldering, cables, etc.
Nov 02, 2008 | Televison & Video
Picture shrinks and expands
Not positive but this sounds like the impending failure of a specific power supply, namely an output providing deflection voltage to the CRTs. This may be simply a circuit on the main supply or could be a separate supply on a different board than the main supply.
If it is not affecting brightness and contrast, it isn't likely to be the primary supply that is failing. I'm pretty sure it will continue to degrade.
Oct 31, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips Projection TV - Model 9P5511C
Common problem with the model. Check the site www.TvRepairKits.com. They have a fix for the shrinking and expanding screen problem.
Sep 07, 2008 | Philips Magnavox 9P6034C 60" Rear...
PHILLIPS 60 IN
Shrinking and expanding or no audio/video is fairly common problem.Goto www.magnavoxhelp.com to see if they have a  repair kit.
Jul 26, 2008 | Philips Magnavox 9P6034C 60" Rear...
9p6040 c102
Visit www.TvRepairKit.com for a repair kit. Its a common problem and an easy fix.
Jan 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
272 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
