Question about Cameras
Camera can i bay the part to my camera where it holds the batterys
  • Anonymous Dec 20, 2008
    Where can I buy the small plastic part that holds the battery in the cammera? It is not the door to the compartment, just the small plastic, spring loaded clip that holds the battery in the compartment.
Try smashing it
Posted on Oct 11, 2008
How do I get a repair part?
Get a hold of the manufacturer and see if they have replacement parts. or Check E-bay.
Dec 01, 2015 | Cameras
Won't stay on - starts, lens extends, then automatically switches off before I can do anything else...
How old is the battery? The camera will exhibit this behavior if the battery voltage is too low. The battery is likely undercharged, old and unable to hold a charge or the contacts are dirty. Carefully clean them with a pencil eraser, taking care not to leave debris in the battery bay.
Sep 02, 2013 | Pentax Optio M50 Digital Camera
Battery won't hold a charge in camera, but batteries are new
Hello Sonja, Try a firmware update for the CX7430 available at Kodak website listed under SUPPORT, be sure to get the firmware download for your model camera ONLY !!!!! If this does not help, some of these batteries that come from China are very low quality and have had them discharge sitting on the shelf !!!! Try Duracell or Other name brand battery, watch out for some sold on E-Bay as many are very low quality.
Best Regards, Russell
Dec 11, 2012 | Kodak EasyShare CX7430 Digital Camera
Battery for Sharpixels SP-5160HD
There might be good aftermarket batteries on e-bay or if you have a local battery specialty store. I found cameras on e-bay that are listed with xtra batteries so others may be selling just batts.
Sep 14, 2012 | Video Game Consoles & Games
Where is the battery?
Removing a Battery
CAUTION:
Before performing these procedures, disconnect the modem from the telephone wall jack.
Ensure that the computer is turned off and disconnected from the electrical outlet.
Slide and hold the battery-bay latch release on the bottom of the computer, and then remove
the battery from the bay.
Installing a Battery
Ensure that the computer is turned off. Slide the battery into the bay until the latch release clicks.
This is copied from the users manual for your laptop computer. Hope this answers your question.
Aug 22, 2012 | Dell Inspiron 1200 Notebook
Kodak Easyshare camera C195 Getting a message saying that the internal memory is full. The card only has 10 pics on it.
Your Kodak camera has a limited amount of internal memory storage space which is the reason for the few pictures. What you need to purchase is an external memory card , an SD card with a maximum of 32GB, which you can insert within its battery bay. This card can hold hundreds and even thousands of pictures, depending on how many megapixels you set your camera on. For more information, go to this link: http://support.en.kodak.ca/app/answers/detail/a_id/19314/kw/c195/selected/true
Mar 17, 2011 | Kodak C195 Digital Camera
Luminox camcorder Model LXDVC3130 won't start!
Hi lianehinds,
I have the same Luminox camcorder Model LXDVC3130. I bought mine some months ago, but tried it for the first time yesterday. I found that from time to time the camera locked up in such a way that the battery had to be removed. I think the answer to your problem is probably the same as the answer to mine.
The battery is very sloppy in its battery bay and what I'm guessing is that the battery is moving away from the three contacts at the top.
My suggestion to you is:-
1/ Lightly wipe the battery contacts with a tissue.(Do not use any liquids!)
2/ Physically hold the battery up against the 3 contacts in the battery bay,so you know the battery contacts are pressing against the three pins at the top. Whilst doing this try pressing the on button and see if the camera springs to life. I hope so!
If it does then probably the best thing to do is find something non metallic to place at the bottom of the battery to nudge it up against the three contact pins. I'm going to try a small piece of sticky foam in the bottom of the battery bay rather than on the battery, so the battery can still be placed in the charger. I hope this works for you.
Michael Parkyn
Jan 27, 2010 | Video Cameras
Cannot find batteries that work. I have replaced the batteries with different brands and it still wont turn on. What is the problem.... Its not reliable.
It is possible that there is a small amount of corrosion on the contacts in the camera. Use the eraser end of a common pencil to clean these contacts. Also, make sure you are using the correct batteries. It shows here that you have the polaroid i830. this camera uses two AA batteries: Open the battery door, located on the underside of the camera (use your thumb to slide the door outwards). Install the two AA batteries into the battery bay. Install the SD card into the slot located next to the battery bay. Close the battery door.
  1. Step2Press the power button located on top of the camera. Locate the "Playback" button on the rear of the camera, under the "W" button; this button switches the camera between "Capture" and "Playback" modes. Set the camera to "Capture" mode.
  2. Step3Press the button on the bottom right of the rear of the camera to open the mode selection window. Use the navigation buttons to select "Still Image" mode. Press the button labeled "Set Disp" to confirm your selection.
Nov 02, 2009 | Polaroid i830 Digital Camera
Memory Card
Did you format the card in the camera?
Jan 11, 2007 | HP Photosmart R707 Digital Camera
Cameras Logo
21 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
