Question about Canon FaxPhone L75 Plain Paper Laser
Vertical blank strip
On faxes sent, or fax confirmations that a fax was sent, there is a blank strip to the middle left of the page all the way down the page (vertical).
Faxes received are fine.
Obviously it is the scanner, which I have cleaned.
(We also changed the cartridge just for fun, that didn't help either of course).
  • 2 more comments
  • debatortho Jul 18, 2008
    That did not do anything. It's not faxes we receive, it's faxes we send, or if we "copy".
  • debatortho Jul 21, 2008
    I've already cleaned the glass.
  • debatortho Jul 22, 2008
    Actually - since this was going nowhere - and we needed our fax - I threw it in the garbage and bought a new one!!!! I had paid $250 for the L75 5 years ago, and got an L80 for $89 (with a $100 rebate). So I guess it worked out okay! Thanks for all the info.
  • 3,037 Answers
Sounds good, good luck with the new one and thanks for using Fixya
Posted on Jul 22, 2008
  • Canon Master
  • 2,794 Answers
If cleaning doesn't help, the optics should be inspected to see if there is something serious going on with the mirror or the ccd unit.
Posted on Jul 21, 2008
  • Canon Master
  • 19,396 Answers
You may need to replace the lamp.
Posted on Jul 19, 2008
    Master:
  • 848 Answers
White Line: clean the glass above the scanner unit. a common problem with this is that tip-ex dries on it when not letting the tipex dry fully before sending/copying
Black Line: This could be a number of thisg: Cartridge, Fuser, Dirt on the laser unit. If you have a spare cartridge lying around even if its near empty try that and see if you get the same problem. If its still showing a line then i suggest using a can of compressed air to clean the inside. If a toner has leaked then sometimes it finds its way onto the lens of the laser unit.
Posted on Jul 18, 2008
  • gopinath pasupathy Jul 22, 2008
    check th ccd unit properly .......
    Scholar:
  • 101 Answers
Clean the scanner components as outlined in these instructions. Hope this helps.
  • Jerrod J
    Jerrod J Jul 18, 2008
    Sorry that link didnt work, Here is what it says...
    1. Disconnect the power cord from the machine.
    2. Use both hands to gently open the operation panel (it only opens partially).
    3. While holding the operation panel open, clean these components:
      Separation guide and separation roller:
      Wipe with a clean, soft, dry, lint-free cloth.
      White sheet and scanning glass:
      Wipe with a clean, soft, lint-free cloth moistened with water, then wipe with a clean, soft, dry, lint-free cloth.
      • If the scanner components are dirty, the documents you send or copy will also be dirty.
      • Be sure to use a soft cloth to avoid scratching the components.
      • Do
        not use tissue paper, paper towels, or similar materials for cleaning;
        they can stick to the components or generate static charges.
    4. Clean the underside of the operation panel (shaded area in the illustration).
      • Dirt
        and dust particles that collect on the underside of the operation panel
        affect the quality of the documents you copy or send.
    5. Use
      a clean, soft, dry, lint-free cloth to wipe any paper dust from the
      areas surrounding the separation roller (shaded area in the
      illustration).
    6. When you are finished, close the operation panel by pressing it down from the center.
      • Be sure to close the operation panel until it locks into place, or the machine will not function properly.
    7. Reconnect the power cord.
  • Jerrod J
    Illustrations:
    Genius:
  • 1,847 Answers
Clean the roller and the cartridge head with alchol.
How can I get a FAX Confirmation printed out on the HPJ4680?
If you require printed confirmation that your faxes weresuccessfully sent, follow these instructions to enable fax confirmation beforesending any faxes. The default fax confirmation setting is Off. This meansthat a confirmation report is not printed for each fax sent or received. Aconfirmation message indicating whether a fax was successfully sent appearsbriefly on the control-panel display after each transaction. NOTE: You can include an image of the first page of the faxon the Fax Sent Confirmation report if you choose On Fax Send or Send &Receive, and if you scan the fax to send from memory To enable fax confirmation
1.Press the (Setup) button.
2.Press right arrow to select Print Report, and then press OK.
3.Press right arrow to select Fax Confirmation, and then press OK.
4.Press right arrow to select one of the following, and then press OK. Off Does not print a fax confirmation report when yousend and receive faxes successfully. This is the default setting. On Fax Send Prints a fax confirmation report for every faxyou send.
OnFax Receive Prints a fax confirmation report for every fax you receive.
Send& Receive Prints a fax confirmation report for every fax you send andreceive
Jan 10, 2011 | Office Equipment & Supplies
The faxes being sent print out with vertical lines down the middle
There is a little scanner in the fax machine that reads the page so it can be sent out. You should be able to open the top, similar to changing the toner, and locate the scanner. This should have some glass over top protecting it. Just take a damp cloth and clean that piece of glass. There is most likely a small piece of dirt on the glass, but when it scans paper it looks like a big streak.
Jan 10, 2011 | Samsung SF-560 Plain Paper Laser Fax
Outgoing fax was received as blank
Make sure that you sent the fax face down.
If all your faxes are sent blank, there may be a problem with the scanner. Try making a photo copy placing the page face down, if your copy comes out blank then the scanner is finished.
If your photocopy does not come out blank then the problem is on the other end and not your machine.
Thanks,
Pat
Aug 16, 2010 | Brother IntelliFax-2820 Laser Fax
Unwanted verticle line on fax copies
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page. If this is the cause you will also find that faxes you send to other people will also have this line (although faxes you receive are not affected by this problem with your machine).
To fix the problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Feb 22, 2010 | Brother IntelliFAX 560 Plain Paper Fax
Receive coversheet followed by blank pages.
Confirm that the sender did not insert the pages to be sent upside-down in their fax machine. This will give you blank pages. Otherwise your fax may have a memory problem.
Feb 18, 2010 | Brother IntelliFax-1860C Plain Paper...
I have a black line showing up on my faxed documents. I have opened it up, changed the film and re- set it, but the problem persists. The machine is about 5 years old.
If this is your problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Feb 07, 2010 | Brother IntelliFAX 775 Plain Paper Thermal...
2" black horizontal line appears on paper when I fax, print,
Check the wondow where the paper passes to be scanned. You will probably find some debris or white out stuck on the glass. That is usually the cause of vertical lines on sent faxes.
Sep 17, 2009 | Office Equipment & Supplies
Vertical line appears on the faxed page sent to
This sounds like a dirty scanning glass in the adf feeder. clean the glass with a soft cloth. if this doesn't solve the problem, there might be dirty optics under the scanning glass.
Aug 03, 2009 | HP LaserJet 3050 All-In-One Printer
I get a dark line in the middle of the pages
Dust in the scanner, clean the scanner line inside the refill  compartment
Mar 06, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Faxes only top of page center is blank
change your resolution from fine to super fine and make a copy to verify your fax machine"s scanner operation.
Mar 21, 2008 | Brother IntelliFAX 1840C Plain Paper...
Canon FaxPhone L75 Plain Paper Laser Logo
154 people viewed this question
old marine
old marine
