Dryers Logo
Anonymous Posted on Jul 18, 2008
My cabrio dryer is not drying my clothes, but it has some kind of heat to it, just not enough to dry my clothes and the display reads AF.
  • Anonymous Mar 13, 2014
    WILL NOT HEAT
  • Anonymous Mar 17, 2014
    Not enough heat to dry
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 24, 2013
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2561
Points
0
My Whirlpool Cabrio dryer throws out heat but does not dry my clothes
Anonymous
Level 1:
  • Posted on Nov 25, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2561
Points
Whirlpool cabrio electric dryer
model number wed6400swi
My cabrio dryer wont heat up to dry clothes it does everythging else but dry
The heating coil is most likely burned out. Since you did not post the make and model that is all I can tell you
Mar 16, 2018 • Dryers
Dryer not drying-the sceen has af flashing please help..whirlpool cabrio
An "AF" code means there is a low airflow condition and the clothes may not dry properly. To remedy this, check to make sure the lint screen is cleaned off and that there is no blockage in either the vent duct that runs from the dryer to the wall or the vent hood on the exterior of the house.
Thanks for using FixYa.
When I put the dryer on it does not dry the cloths are still wet. and where it says how much more time is left to dry it is blinking AF what does this mean. I dont know where the book is could you help...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
On the screen of my dryer where it tells me how long I have till the cloths are dry keeps flashing AF and it takes me all day to dry one load of cloths.
The AF stands for Low airflow condition. We had it too. Check the lint trap first as it is the easiest. Then check the dryer hose ductwork make sure its not crushed or blocked. You may need to clean the line from the outside too.
My Whirlpool Cabrio dryer takes forever to dry anything (3 hours for just a couple shirts!). There is a code AF flashing on the display window, but i have checked all the airflow issue places and nothing...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
1helpful
I have a whirlpool cabrio dryer and it is showing AF on the display and it isn't drying. what could be the problem?
AF Error Code for the Whirlpool Cabrio Dryer is a Air Flow problem. Check your dryer vent and the outside exhast vent.
Jan 13, 2010 • Dryers
2answers
Not drying - indicator show AF
you might need to replace the heating element
Sep 05, 2009 • Dryers
6helpful
The gas maytag neptune intellidry gas dryer does not dry clothes. It does not have enough heat. It will take about 5 cycles to dry 1 load.
how do i set this dryer to dry my clothes??? what is the right setting?? should i use the time dry setting or the more dry/less dry setting?? Clothes never dry???????????????????????????????????????????????????????
Whirlpool cabrio dryer
af on your cabrio dryer means clean your air filter
Top Whirlpool Dryers Experts
Virgil Watts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Eager
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
