Without having the actual washer make the sound so I can hear it, my guess is that the timer (which is the part connected to the dial you turn to select a cycle) may need to be replaced. Squeals can also come from the belt that connects from the motor to the drum. If you are at all handy and can open the back, a broken belt is obvious. If you are not familiar with tools then someone will most likely have to be called to diagnose the problem.
