SOURCE: HP Photosmart C4280
hmmmm...assuming that the cartridge is installed properly, yes? seems that your black ink cartridge may need to go through a 'clean' process, prior to alignment(sure wish that the replacement folks would insist on cleaning out the old heads, before doing an alignment. It's like changing the oil on your car, but using the old filter. Same gunk still in the system.
SOURCE: alignment
Remove both the cartridges from the printer and check the expiry dates on both cartridges, if any of the cartridge is expired then change the cartridge and check the result. If the cartridges are not expired then check the ink levels present in the cartridges from the HP Solution Center. If the ink levels are good then clean the copper contacts of the cartridges with a soft cotton cloth and power cycle the printer.
Now insert the cartridges and align them, after alignment page prints then scan the page.
If it still gives alignment failed message then remove the cartridges and reset the printer and check for the result.
SOURCE: HP PHOTOSMART C4280 PRINTER WONT READ INK CARTRIDGE.
The cartridge is not seated properly and/or the contacts are dirty. Use a cotton swab with rubbing alcohol and gently clean both the copper contacts on the cartridge and inside the cartridge socket. Allow several minutes to dry and then try again.
SOURCE: Install cartridge missing on Deskjet 6940
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier and please try to print a printer self test.
SOURCE: HPPhotosmart C4250 mgs "Printer Cartridge missing or not detected
There may be debris that is blocking the communication between the cartridge and the printer, especially if you are using a remanufactured cartridge. Remove the cartridge and unplug the printer from the power supply. Take a little bit of rubbing alcohol on a cotton swab and wipe off the contacts on the cartridge as well as the contacts inside of the printer. Allow both to dry for a few minutes before plugging the printer back in and re-installing the cartridge. This should clear up any miscommunication between the two.
