Question about Sharp AL-1642CS Copier
Prints and scans fine, but copies are all black
Our Sharp AL-1642CS prints fine from the computer, and scans fine into the computer, but when we try to copy something everything is too dark--even the blank area around the item to be copied is dark black.
The charge wire is clean, and everything in that area is good. The green drum is clean. The toner needed light is on, but that isn't causing this problem. We're stumped!
Could it be in the firmware? This is the one thing that doesn't go through the computer.
Would changing the firmware to a later model help? Can you download that and install it from the computer?
  • John Waaser Jul 29, 2008
    I checked with Tom, who actually owns it, and he says 6000 copies.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Firmware is only available from a technician if there is any.
    How many copies do you think you have ran on it?
Easy problem, the mirrors in the optics area are dust or dirt covered. Remove the plastic cover from the top right side (2 screws) lift up the glass, move the scanner bar towards you and clean all of the mirrors.
This is a common problem in ALL copiers in a dusty environment, or even in a clean one after a while. the mirrors just tend to collect dust.
Posted on Aug 30, 2008
  • 62 Answers
Hold down the auto expsoure key the the lights will began to blink light copies then push it again to hold lighter expsoure.
Posted on Aug 14, 2008
Need driver for Sharp al 1642 cs with windows 64-bit
Please communicate with me through my email then i will send driver to you. thanks
Nov 05, 2012 | Sharp Al-1642cs Print/scan/copy
I have a Sharp AL 1642 CS. It prints black copies. It came out of no where so I know it isnt dust on the lens. Even after adjusting brightness settings it prints pitch black pages. The bulb on the scanner...
Problem on three things.
1.OPC drum cleaning blade is very old,so lost her activities.
2. Laser unite very dirty,so you need clean.
3. setup or configure exposure control.
# Press Auto key three second
when exposure light indicate now position,select way lighter side.
Jan 20, 2010 | Sharp AL-1642CS Copier
Prints blank sheets of paper, code is L 1, can't find manuel
Blank pages means the Drum becomes bad, Change the Drum.
Jun 17, 2009 | Sharp AL-1642CS Copier
Sharp AL-1642CS
Hello sir; I believe that's drum cartridge problem try to change that see what going to happen.
Jan 22, 2009 | Sharp AL-1642CS Copier
Printing problem on Sharp Copier Al 1642CS
it would have spilled toner on the laser unit glass which can be accessed after removing the developer & drum units. Its on the upper part inside the machine in the drum chamber.
Nov 28, 2008 | Sharp AL-1642CS Copier
Sharp 1642CS shared printer
You can go into your print driver and change the Driver. I dont think there is a difference between Home or Prem drivers. There is how ever a difference between 32 bit and 64 bit Vista?
When you set up the printer and share it from a PC, The printer attached to that PC can Control the Configurartion of the printer. PC's can either pull the driver from the sharing PC or you can select your own.
I would first check that the correct drivers are installed, (64bit or 32bit)
I would check the computer that is trying to print. replace the driver with the correct one.
You can open the print server -open the printers and fax folder, right click in a white area in that folder, a menu should pop up. Select Print Server from there you will see tabs, try to replace the driver from there.
Or Open the Printer Properties and there you will see Driver-Update in there.
This is a link to an explanation
Thou it was made for XP but the basic Infomation is the same.
-->Print a test page from The Printer Properties), if it works the Computer is fine, if you try to print from a program and it prints with errors. it is in the program..
http://www.fixya.com/support/r1173318-print_driver_location_pc_print_test_page
Nov 05, 2008 | Sharp AL-1642CS Copier
Scan to pdf
TRy reloading printer driver if this doesnt work try to scan using adobe photoshop
Jan 12, 2008 | Sharp AL-1642CS Copier
"Scanning in progress" reported even when I'm not scanning anything
You need to install the print driver and Sharpdesk before you connect the USB cable.
Dec 10, 2007 | Sharp AL-1642CS Copier
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
