Question about Oster 76076-010 Hair Trimmer
I tried to clean the blades but now it wont cut and also it sounds tremendously loud
Help! i cleaned the blades for my hair trimmer, but when I tried to put them back, it looked normal but when I turned it on, it makes an awful sound, really really loud and it doesnt cut either.
Please help, am I missing something?
Ive tried to put them in so many different positions, and it will always make the same sound... thank you
  • Anonymous Mar 21, 2014
    I took the blade off to clean it and now when I put the blade back on it makes a wierd buzz sound and doesnt work?
Are all the screws tight? Sometimes my screws on my blades come loose and I can't tell until all of a sudden they fall apart in a clients hair
Posted on Jul 29, 2008
My husbands clippers won't cut
Blades are NOT moving HOW TO Fix a broken Hair clipper ...
? 2:42
https://www.youtube.com/watch?v=DX4Xc47F_IE
Mar 29, 2015 - Uploaded by You can Fix It!!!!
... blade fix how to won't cut by adjusting the blade adjusting the play with the motor so ... Blades trimmer trim trimming cut cutting cutter trimmers barber ... dog clippers shear shears shearing shave shaver shaving buzz cut ...
My clippers hum like their working but dont cut - Fixya
www.fixya.com/.../t3222969-clippers_hum_like_working_but_dont_cut
Jul 25, 2008 - my clippers hum like their working but dont cut - Wahl Designer 6 (8355100) question. ... hair clippers repair. Apr 22, 2013 ' Shavers ยท 1 Answer ...Clippers jam and won't cut when trying to use attachments. Jan 11, 2009 ...
Clipper Maintenance - Rapid Edge
www.rapidedge.com.au/cat/maintclip.html
Clipper won't cut cleanly or easily. Lack of oil and dirty. Sometimes a hair gets caught between the blades. Lubricate and clean your Clippers regularly.
Dec 21, 2015 | Health & Beauty
Won't cut anything
we have had this problem many times with our hair clippers
take off the outer blade and make sure it is all clean and there is no hair within the working when rebuilding add a little regular household oil
on the side of the trimmers there is usually a little plastic screw built into the casing this is the motor adjustment turn it until the trimmers become noisy then turn back half a turn so it lowers the noise out put hence the motor speed hopefully this should work
Dec 14, 2011 | Conair HC117 Hair Trimmer
I have an Andis outliner II I purchased a year ago. I recently changed the blade but it won't cut my hair. Do you kow why?
Sometimes the new blades from Andis are not sharpen enough to get that clean cut. also all trimmers need to be readjusted for power and alignment, plus sharpening the blade, it look like you need a complete sharpen & service on your Andis trimmer. check out Manny's Sharpening they have a Mail Order service, the service they provide is fast and they will sharpen make all the adjustment and give your trimmer more power and the blade will cut clean. They will even adjust the blade at your request on how you want that blade to be set at. Line Ups or Fade Cuts and even shave set. Manny's Sharpening been around for over 20 years and they have a very good rating on the net. Check it out Manny's Sharpening
May 21, 2011 | Andis Outliner II Hair Trimmer
When i turn on my shaver it just hums. no cutting sound.
Possible that the blades are clogged with hair or dirt and the motor is jammed . Use the fine brush that had come along with the shaver to clean and free the blades, Use some light oil on the blades to free any signs of dirt or rust on the blade set.
After shaving it is important to clean and keep the blades dry.
Dec 08, 2010 | Andis T-Outliner Hair Trimmer
The trimmer is not cutting the way it should, the bottom blade seems out of place and I cannot put it back in place
Conair trimmers are only good for about a year and they are hard to put back once you have messed with them. does your blade pop off or does it have two phillips screws holding it in? If you take the blade off completely you should see two arms that are in there, you have to place the blades back on correctly and hold them together while putting the screws back in. be very careful not to tighten the screws too much. Oil your blades with 3-1 oil and then turn them on. adjust the trimmer and see if everything is level, if it is try cutting withem and see what happens. If the motor sounds good but the blades are pulling your hair rather then cutting it then you need to replace your trimmers because your blades are daul.
Oct 05, 2010 | Conair HC100RCS Hair Trimmer
Have not cleaned the clippers ever since I bought them. What do I need to do to clean and oil the clippers
There should be 2 screws on the bottom where the (Blades) are just unscrew them and and put them in a spot where you will not lose them and then take both blades off and use the little brush that it came with and brush the hair out. When you are done and have put them back together, make sure the bottoom blade is straight, when that is done turn on your trimmer and put a small drop or two of on the blades when it is running and it should be all set.
Jan 18, 2010 | Conair HC117 Hair Trimmer
My clippers are running and the blades are moving but they are not cutting the hair
make sure it is cleaned and before putting it back together put a drop of clean oil between the blades. Also make sure it it adjusted properly.
Aug 04, 2009 | Andis 01690 Hair Trimmer
Oster 76076-010 Hair Trimmer Logo
290 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
