Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Water pressure can get water out but all of a sudden it became very slow could it have anything to do with fridge?
    Scholar:
  • 50 Answers
If you have a water filter, the filter might be too old and plugged. If you've replaced the filter or don't have one, I would check the water supply to the frige. You might have a kinked line. Also if you used a self piercing saddle valve on your plumbing supply it may be blocked. You would need to turn the water off to the house and replace it with a saddle valve that would require you to drill a hole in the water supply line. Also most friges have a tank in the frige to keep the water cold. If the frige is too cold it could freeze the tank. The average frige temp should be 35-36 deg.
Posted on Jul 19, 2008
Slow ice production on maytag fridge
Replace the water filter. If you replaced your water filter, depending on the fridge, they have two filter models. One is a fast fill filter (has less media and takes out less contaminants). The other filter is a better filter and takes out more contaminants (because it has more media) and will slow down the water pressure.
Feb 03, 2013 | Maytag MSD2756G Side by Side Refrigerator
Water dispenser is slow
3 possibilities.
1. Water pressure is low going into the fridge- the way to test this is turn the water off, remove the line from connection in the back of the fridge and put it in a bucket to see the flow. The water should be shooting out with good pressure. If it is not, then you have a plumbing issue, likely at the valve under your sink.
2. Water filter is clogged- If your model has a water filter, it should be changed every 6 months.
3. Bad water valve. The solenoid valve in the fridge, right at the back where the water connects could be going bad and not opening all the way.
May 11, 2012 | Kenmore Refrigerators
Slow water flow from water dispenser
Hi.
Either low pressure from the line, or blockage in fridge water hoses going to the dispenser.
If water pressure is OK, then the problem is often given by a blockage caused by water freezing in the fridge's hoses. Try doing a complete defrost.
If defrost does not help you will need to find blockage accessing the hoses, start from the inlet at the back of the fridge.
Do defrost first.
Regards.
Ginko
Apr 19, 2011 | Frigidaire Refrigerators
We have a Pure Source Plus model, no manual as it came with the house we purchased a year ago. Things worked fine then. A few months ago the water pressure lowered and temp changed(became warmer) for the...
the ice maker slows as the tempt in freezer gets warmer . icw cream get softer ect . ck for ice build up in back of freezer and the evap fan motor may be running to slow causing poor air flow . ck these first . mm
Aug 10, 2010 | Frigidaire FRS3R5EMB Side by Side...
Hi My fisher payel fridge with the under freezer has a built in ice maker and it has stopped working. What do I need to do to fix it?
Tell me more, why did it suddenly stop? What did you change? Did you turn off electric? Get anything water wise that is new? Did you lower the water pressure coming into your home? Where do you live - house, apartment?
I can't say why it quit, unless you left it running on "make a lot of ice" (some fridges have this option), were out of town and had some electrical issues, went through a big storm or changed the water coming into the fridge. These are the obvious reasons why you'd have an issue.
A little more detail, Please?
Mar 21, 2010 | Fisher and Paykel E522B Stainless Steel...
Low water flow after changing the water filter in a gf profile re
Just a suggestion, you could try installing a filter on the water supply line to the fridge. A nice one should dramatically lessen the frequency of replacing the one in the fridge. As for your the pressure being low, look for a kink or pinch in the water supply line.
Sep 08, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile Performance - No water dispensing or ice making
NOT ENOUGH WATER PRESSURE AT WATERLINE OR WATER VALVE IS BAD AND NEEDS REPLACED
Jul 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Amana fridge water dispenser real slow
u m,ay have to change the filter tubing as well
Mar 15, 2009 | Amana ARB8057CSL Bottom Freezer...
Ice maker too slow
Ice makers will only drop cubes about every two hours. There is nothing you can do to speed it up. However, if you have low water pressure to the fridge, then you will have slow production. You need a minimum of 30-40 pounds (constant) of water pressure to the fridge for the ice maker to work properly. Things I typically see causing low pressure are: Self piercing saddle valves on the water line (need drill type), and reverse osmosis systems connected to the fridge. In some rare cases a very old water filter or limed up supply line.
Jul 06, 2008 | Samsung RB215LASH
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
77 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
