Question about Casio Exilim EX-Z40 Digital Camera
Wont turn on
Got a new battery but when i put in on the charge cradle i only get a yellow light
Same here. i think it is an issue with the dock that it has to sit in to do anything. I'll never buy another camera that has to sit in a dock to charge and/ or load pictures.
Posted on Nov 05, 2008
2 Suggested Answers
vortash
  • 431 Answers
SOURCE: My battery wont charge.
Hi I am Vortah The red light is usually an indicator that the battery is charged however in this instance as you are saying it isn't the battery has possibly gone short and you will need to replace the batteries . They have a type of internal memory and only charge a certain amount of times before they no longer accept charge and merely overheat during charging .. But I have to say it may be possible the charger is faulty as if the internal rectifier that charges the battery has gone short that may also bring the red light on in some chargers .. so try the battery or as I would do take it along to your nearest dealers and get them to check it . it may save you money in the long run you could be buying a battery you still cant use when you actually need a charger .. Hope this helps regards Vortash
Posted on May 29, 2009
My Casio Exilim EX-S880 wont turn on. Battery is dead but the camera wont charge on the charger. The red charger light is flashing when then camera is placed on it. This red light used to stay on...
I found this while trying to solve my exact same problem.. It worked for me after about 7 times. Some other people on the site said it worked for them after 20 times. Good luck!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Aug 05, 2009 | Casio Exilim EX-S880 Digital Camera
PL-CS55 headset lifts receiver but only get buzzing sound in
Try a system reset:
1. Lift the headset off of the charging cradle (the base).  Make sure the headset is turned off.  The green light on the base won't be on if the headset is turned off. 2. Hold down the call answer button on the headset at the same time as mute button.  The mute button is found on the little black wheel on the top of the headset.  Use the tip of your finger to push it straight in. 3. Hold both buttons until you see a green light on the headset flash.  It will be right below your thumb.  Hold both buttons until the green light flashes for a series of 2 flashes.  Then let go of both buttons. 4. Put the headset back on the charging cradle and wait 30 seconds.  Lift it back off and try again. 5. If this doesn't work repeat the process once more or try a resubscription.
Resubscription procedure:
1. Put the headset back onto the charging cradle.  Make sure the red light on the base is on and the yellow light is flashing. 2. On the back of the base there are two buttons for the microphone adjustment that can be pressed down.  Press both of those down until the red light and yellow light on the front of the base start flashing. 3. While the headset is still on the charging cradle press and hold the mute button until the red light on the base goes solid, and the yellow light stays flashing. 4. Unplug the power to the base and then plug it back in. 5. Wait 20 seconds and try.
Apr 22, 2009 | Plantronics PL-CS55 Wireless Headset
Phone wont charge
Stevey-
The sidekick ID charging port can go bad like the sidekick 3's. An easy workaround is to get an external cradle that has a spare battery charging slot.
The trick is that the sidekick 3 and sidekick ID batteries are the same so the sidekick ID battery can be charged by the external cradle. An extra battery is a good idea as well so you can have ine charging at all times.
Check the cradles out here.
Sidekick ID external Battery Charger
Sep 10, 2008 | T-Mobile Sidekick ID Cellular Phone
Camera Won't Charge
my finepixz3 got wet. but after a few days it worked! but when the battery ran out it wont charge. is it the battery? it turned on a few sec when its in the cradle but it wont last after a few seconds it would turned off. is it the battery or the camera itself?
Sep 01, 2008 | Fuji FinePix Z3 Digital Camera
Help please!
hialeahnero
probably not. If your phone will not turn on at all with a charged battery then the charging cradle won't help. When you try to turn it on, you get no lights or anything?
Check to see if the prongs for the battery connection point are good. Try pushing down on the battery and powering up the phone. Try this with both batteries if you can.
Let me know how that goes and we will try to figure this out.
GrinningFool
Jun 24, 2008 | T-Mobile Sidekick® 3 Cellular Phone
My sidekick wont work
It seems your charger port is broken, it hapfens often on cellphones, wear and tear. Check to see if its under warranty, and it can be replaced. Check my profile if you need more help.
Jan 24, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Camera Wont turn On: Is it stuck in USB mode? How do i fix it?
I was able to get past this problem by removing and reinserting the battery. This caused, in effect, a hard reset of the camera, which let me power it up fresh and take pictures again. Of course, it's not exactly reassuring that the problem arose in the first place,
Jimmo
Nov 04, 2007 | Casio EXILIM Card EX-S770 Digital Camera
It won't turn on, bt the battery still charging
Another way I've found to do this is to press the power button and reset button at the same time. Then when you get the message to clear all data press cancel. I get this every time I re-charge my axim in the cradle. Doesn't anyone have a better solution? When it happens I have to reset my time. It's usually a day behind.
Sep 14, 2007 | Dell Axim X50v Pocket PC
Casio Exilim EX-Z40 Digital Camera Logo
62 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
