The fuse of Nissan cars are in a box, and it is located under the dashboard of the passenger side of the front seat in Your car. If You intend to replace a blown fuse or check the fuse, please follow the steps below:
Start by turning off the car. Locate the main fuse box under the dashboard of the passenger compartment of your Nissan.
Pull the cover down to open and towards you to remove it. Read the inside panel of the fuse box to figure out the location of the fuse you must replace.
Use the fuse puller inside to remove the appropriate fuse. Look at the wire in the middle of the fuse to see if it's burnt.
Replace the blown fuse with a new one of the same rating. Verify the fuse's rating against the inside cover of the fuse box. For example, the 2006 Nissan Sentra has a 10 amp mini fuse.
Push the fuse in and close the cover. Check the fuse once the car is started.
I run into the snag, there are about 7 fuses that look fine but I get nothing on the test light, neither side. These fuses are my high and low beams for passenger and driver, ARL, rear defog and heated side mirrors.
Your best bet have a qualified technician check it out .
All of these functions are working just fine even though the fuse panel says different. Any ideas, anyone?
Your looking at something wrong , fuse's without power ,the componet won't work . The headlamps fuse's get battery voltage from low beam relay an high beam relay which are controlled by the BCM - body control module . Without service repair info. your just guessing an will never fix the problem . Factory wiring diagrams an the knowledge of electrical diagnostic's . Electric Testing Techniques You Need to Know
