Hi there!
Try to access the Advance booting option by press F8 continuesly when start up boot and run the safe mode. Your computer will run on mini drivers loaded and low VGA graphic and uninstall software or hardware that corrupted your operating system or run virus scan if virus attacked your computer.
Try also to run system restore to bring back your old configuration but back up your files before doing this. Go to start menu, choose accessories, choose system tools, choose system restore and choose the date with with good configuration settings.
Effective way to repair your black screenis to put Windows installer CD or system back up disc into the CDROM drive and run the repair mode. This will fix the errors in your computer.
I hope it helps you.
If its only 3 mnths old should still be under WARRANTY take it back
if its not under warranty
Turn Off the computer now as soon as you hit the power button, keep on holding Alt key & keep on tapping F10 key ie: Alt+F10, it will open the recovery console select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
During the boot process you will see on the screen to press a certain key to enter setup usually delete or the F2 key this will differ depending on which bios you have
Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope it helps
