Question about Canon Elura 65 Mini DV Digital Camcorder
Zoom issues the zoom is random, sometimes it works fine, other times it slowly zooms in, when it does that, I can either: by pushing the button in the "zoom out" direction, stop it from zooming further or it may zoom out slowly, but upon letting go of the zoom slide it will continue to zoom in. it's been doing this for more than a year.
  • clvrs3 Jul 21, 2008
    I tried cleaning the lens, to no avail. it still slowly zooms in unless I push the zoom slide to "zoom out" then it either: only stops it from zooming in or slowly zooms it out.
    I forgot to add before that the photo button (to snap still shots) doesn't work all of the time either. it will usually either: just focus and not snap the picture or it will just snap the picture and not focus.
    I tried the solution, but removing the cover of my tape door doesn't expose the zoom slide (zoom control lever). the back of the zoom slide is closed in and permanently connected to the top cover. I pried on the zoom lever from the top (outside) but could not see a way to pop it off without breaking it.
  • 1,183 Answers
Te problem that you are facing with camera would require it to be serviced at the authorised repir centre. The problem with the camera could either the ZOOM motor is defective or the ZOOM controller IC is bad.
Support option:
  • For toll-free technical support, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 8:00 a.m. - 12:00 midnight. EST, Saturday 10:00 a.m. - 8:00 p.m., excluding holidays).
  • Toll-free TDD Support Line for the Hearing Impaired Monday - Saturday (excluding holidays) at 1-866-251-3752
  • Technical Support for Customers in Canada at 1-800-OK-CANON
Thanks
Proton
Posted on Jul 22, 2008
    Genius:
  • 1,665 Answers
Select product type at link below and see if you can get support.
( http://www.canon.com.au/support/service_agents.html )
Posted on Jul 21, 2008
  • 4,234 Answers
As a servicer of camcorders for over 20 years, the info given by Marked is not correct. The zoom on these cameras is controlled by a motor driver IC and a small motor. These are not accessible from the tape compartment, the camera must be disassembled. This is not a repair that I would suggest a novice attempt. The most likely cause of this problem is that the lubricant in the optical assembly has gummed up a bit or has accumulated enough dust and grime to cause rough operation of the assembly. The motor itself may be a bit weak or have a bad spot. WIthout testing the motor and looking at the camera internals, it is difficult to state for sure what the problem really is. I would suggest that you bring this camera to a service center. The repair should not require any parts other than the motor if it has dead spots.
Check around for a shop that repairs camcorders.
Keep us posted.
Dan
  • ABRsvcs Jul 21, 2008
    Forgot to add. Under NO circumstances should you spray anything into the camera. This is a sure way to cause more harm.
    Dan
    Sergeant:
    Champion:
  • 347 Answers
Hello clvers3.
I browsed on cannon's website and they say there is no trick or simply fix to that problem.
If you want, you can go to this link and search if there are any cannon repair shops near.
http://www.usa.canon.com/consumer/controller?act=ServiceLocatorAct&fcategoryid=227&modelid=9933
Good luck,
Dahaka
  • Santiago Vallejo
    Santiago Vallejo Jul 21, 2008
    clvers3,
    If you dont have experience opening cameras, i strongly recomendy you to go to a local repair shop, (preferably cannon) because cameras are a lot of technology all compacted in small chips and cables.
  • Canon Master
  • 6,487 Answers
First: remove the plastic cover from the tape compartment. This is held by two screws, one in front of the cover.
BEFORE removing the cover, notice the two pins that holds the plastic cover in the lower part. You need to remember where these goes, so you can put the cover back when you're finish!
Now that you unscrewed the two screws at the top of the plastic cover, you just lift this cover up and expose the guts of the tape compartment door.
Now, for the most difficult part, you need to remove the zoom lever. You'll notice that it has two ears on which it pivots. Use two very small screwdrivers to drag the ears over the litle pins on which they ride. First tried to drag one ear at a time - no luck that way. You have to work both ears at the same time. I aged like 10 years doing this! The ears are very small and fragile. So take care.
Ok, you managed to remove the zoom lever? You found it where it jumped? (don't worry, it has no spring or anything else underneath that could be lost.
Now, what you have to do is to clean the contacts (with "contact spray") of the zoom lever and the actual potentiometer that makes the zoom.
You can actualy see the dirt or watever is on the pic above. Don't rub the contacts to hard. Use contact spray. Don't use sandpaper or any other abrasive! Just contact spray that states it's good to clear contacts and potentiometers.
You finished cleaning the pot? Now put the lever back (it goes easy - it does "click") and plastic cover. You're done.
Hope that helps........
Posted on Jul 18, 2008
    Master:
  • 848 Answers
Your sensor is not working properly .......thats why you are having random zoom ............ clean your lens properly ......
Faulty zoom operation
This is normal. If you hold the zoom for an extended time the lens is slower than the indicated zoom. Forcing the lens to continue to its zoomed direction.
Apr 14, 2014 | Panasonic Lumix DMC-FZ18 Digital Camera
Camcorder zooms by itself.
this is some problem with the panel of buttons is your unit.
this will need some service from the company directly.
Jul 24, 2008 | Sony Handycam DCR-TRV330 Digital Camcorder
Sony Handycam CCD-TRV37 8mm Analog... 2 Problems, maybe more unknown at this time:
This does require disassembly to remedy the problem. There are various possible fixes. The most prevelant I have seen is cold solder connections of the board connector for the fpc cable from the top operation switch block ass'y. All you need is someone who can handle this task, like a professional. The controls that you are experiencing problems with are all linked with one cable and connector. One bad solder joint can cause serveral operation faults. Good Luck, magic seadog
Aug 18, 2007 | Sony Handycam CCD-TRV37 Camcorder
Screen randomly zoom in
Triple click home button then press zoom off
Mar 16, 2014 | Apple iPhone 5
Screen zoomed in zoom out
this is likely a virus, trojan issue... have you done a thorough virus scan with current software???
superantispyyware.com... free
Aug 17, 2013 | Sony Computers & Internet
My camera worked fine for 3 years, when suddenly .... when i'm zooming fast (zoom button pushed down) camera switches of. If i'm zooming slowly everything is ok. Some master said that zoom lens motor...
I would say to check the batteries and their connecting surfaces plus the contacts in the battery compartment. With bad connections on the batteries, when the camera zooms slowly it does not use much power. When zooming fast it uses more power (current) and if the batteries are making a poor contact the camera will shut down due to low volts. Check that first before spending big money. If you are using Duracell batteries, they have a short + pip end which some devices will not work with them due to poor conection. Compair a duracell battery with another brand. see the difference on the + end.
Aug 04, 2010 | Canon PowerShot S3 IS Digital Camera
No zoom function on a kalimar power zoom scope,
larry389's so-called solution is not a solution... just an opinion to which each individual is entitled... even when not correct! I've used a Zeika Opt. Co. Power Zoom Binocular No.25361 for over 25 years since inheriting them from my father who purchased them in early 1970. To say the least, treated carefully and with respect for the delicate instrument that they are, they've been wonderful and still work perfectly fine. Perhaps Larry's experience is based upon handling them like junk and, therefore, reaping what he has sewn.
Jan 21, 2009 | Optics
Casio ex-z750. I have a problem with the zoom on this camera. You can zoom in, but when zooming out it activates the 'Best Shot' scene selection. If you press the zoom button again the scene selection...
Sorry Chris but that is definately an electrical issue that needs to be checked by repairs. I recommend that you send that in so they can check the internal board.
Sep 13, 2008 | Casio Cameras
Picture mode changes to zoom by itself
It sounds like an eeprom issue. But you can try to reset the set. Turn the set off by the main power on the set. wait a minute or two then together push both the main power button and the standby power button. This should resett the tv. If that doesnt work you will need service as the zoom and the various modes are all controled by the eeprom. Only hold the two buttons for a second. sometimes you will hear the crts discharge while resetting.Hope this helps
Jan 03, 2008 | Pioneer SD-582HD5 58" Rear Projection...
FX8 all button frozen
I am not sure if this is a solution. but one time, i turned on my camera when the battery is really drained. usually (when it was broken) it will automatically zoom in. but that certain period when i turned it on, even before it can zoom in, the battery drained and the camera went off. i charged the battery and when i put it back and turned on the camera, it works fine. it is still working fine. good thing i didnt had the repair center fix it, because they charge really high price.
Nov 11, 2007 | Panasonic Lumix DMC-FX8 Digital Camera
Canon Elura 65 Mini DV Digital Camcorder Logo
135 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
