Question about Lands Phones
I droped my phone in the water - Lands Phones
Most likely it will not work anymore. But if you are lucky, it can. Let it dry on a towel in a window sill for a day. If it doesn't work, save the SIM card memory stick (etc.) and get a new phone; or you can try again. The same thing happened to me. Three days later it worked again.
P.S. Don't get a Motorola RAZR. They break easily and get all kinds of problems.
Posted on Jul 18, 2008
Droped in the water cant use keys what can do or how reset
You can't reset a water damaged phone but try putting it in some rice over night. The rice will soak up
The water
Jul 05, 2014 | Samsung SGH-x427
My phone droped in water , seperted the battery from cellphone, 2 days latter all it show is charging but wont come on?
take phone apart and put all pieces in rice for 24 hours it will suck out any moisture
Mar 22, 2013 | Cell Phones
Nokia 1650 set on but no function still light on otherwise not set re off
Dear customer
If your mobile was droped by you or it is drown in water then open it by T-6 screw driver with vary carefully.Open your mobile and check it and wash by toothbrash with PCB cleaner and give some hot air by hecco machin.If it is not droped or drown in water then FLASH your mobile by softwere HWK flasher with new version
May 21, 2010 | Audiovox Bosch 718 World Cellular Phone
I just droped mi fone in the bath
If it is droped in the bath, DON'T TURN IT ON! Let it thouroughly dry for 2 days before attempting to turn on this device. Otherwise the circuits will burn out
Aug 05, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
I droped it in sea and the phone in sea and it is dead
hi, sir how r u??
to be honest that the water has inserted in the IC of mobile and it does not work the best is you must have to check the repaire..
May 30, 2009 | Nokia N73 Cellular Phone
I droped my fone in water and its in a screen and all it says is emergency download and im wonder how to exit it i took out my batter and put it bak it but it gose bak to the same screen pls pls help
take the battery out and let it dry for a couple of days should restart, but it has to be dry. if it is dry you should follow any directions it say to reload the phone...hope it helps.....
May 28, 2009 | LG Vu CU920 Cellular Phone
Fell in the floor and into the water
These kind of problem cannot be solved unless the phone is examined. Some part of the board might be short circuited due to the entry of water. You will have to give the phone to the authorised service center to get the stuff repaired. Thank you!
Mar 10, 2009 | Cell Phones
Droped my phone into water while back trying to fix it now and goes to blue screen and says bootloader usb init
if you did not take the battery out as soon as you pulled it out of the water it is probily no good because the circuit board was fried from the electric current that the battery was feeding the phone. but for future ref. if droped in the water remove batt asap and take phone apart and dry with a q tip and put back to gether and let it sit for a bout a day to let all the water get out of the phone and then place the batt back in it and turn it on.
Feb 20, 2009 | Motorola Mobility RAZR V3
Razr v3
take the phone to a mobile repair center and have them service the phone for you and see if that helps.
Mar 31, 2008 | Motorola Mobility RAZR V3
Droped
hi,
    this might be because the water has entered in the inbuilt software of ur phone..so do one thing open ur phone as much as  as u can..put it in sunlight for 2-3hrs continuously ..it will dry up all the water/moisture  from ur phone and then try  & if it doesnt work than u need to go to service centre.
Thanks
gizmo1
Oct 17, 2007 | Sony Ericsson S710a
Lands Phones Logo
61 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
