Question about Acer Computers & Internet
Connection for front header on a acer m5630 - Acer Computers & Internet
  • 129 Answers
More information required. Problem not clear
Posted on Jul 18, 2008
Acer Aspire M5630 Series Original Desktop Motherboard Eg31m reboots
hey there, i know that problem u need to apply a new bios u can find it here : m5630
Nov 23, 2013 | Acer Aspire M5630 Series Original Desktop...
What to restore my Acer Aspire M5630, alt +F10 doesnt load any restore options?
try alt +F4 or just F4 this should kick in the recovery boot up or if hold alt + tap on F10
Feb 11, 2012 | Acer Aspire Computers & Internet
Hi, I own an Acer Aspire M5630 Standard desktop
A branded computer uses Original Equpment Manufacturer (OEM) version of Operating System, hence if you change any hardware it will go to the trial version of OS automatically. Hence, you have to use the full system recovery disk to reinstall the OS.
Thanks and regards,
Anil.B.R
Oct 27, 2010 | Acer Aspire 5610-4648 Notebook
I have an Acer desktop M5630 with a wireless keyboard KG0750 when I push space bar computer turns off...when I type @ letter 6 appears also when I type shift calculator appears......any ideas??
ya....this is joke from your friend...so what you have to do is go to control panel select keyboard and reverse all the changes made there
Oct 06, 2010 | Acer Computers & Internet
WANT TO SEE DIAGRAMS OF A T650-8B7H ASPIRE COMPUTER COMPONENTS ie the inside parts motherbody ,power suply,processor,hard drive and sound and video cards
This is a PDF Service Manual for the Acer Aspire T650 series desktop computers, from Acer Support,
http://support.acer.com/acerpanam/manuals/acer/0000/servicemanuals/S.G_AS650_E500APF5_BOOK.book.pdf
After you click on the link you won't see anything happening for up to 30 seconds. The file is downloading in the background.
If you see the first page, and the file is still downloading, let the file download all the way before looking though it.
(Should the Service manual link not work for you, state so in a Comment)
Proper computer speak for motherboard is Mainboard. The mainboard is shown on Page 15.
Connections to the Headers on the motherboard, are shown on Page 19.
Orienting the motherboard so the Processor is to the top, and Ram Memory slots to the right, the Front Panel header is on the bottom right of the motherboard.
PANEL 1.
The Front Panel header, is where the various cables from the Front Panel of the computer go.
(Front Panel being the plastic panel in the front of the computer. For this computer, the Power On button, two USB ports, Speaker/Headphone jack, and Microphone jack are in the front panel)
To the left, and down a little bit, of the processor socket is the 4-pin ATX +12 Volt header.
Square in shape, white in color, 4 socket holes.
This is where the 4-pin ATX +12 Volt power cable plugs into. (Two Black wires, two Yellow wires)
This is power for the Processor. If it isn't hooked up, the Processor won't turn on. No power.
Below the Processor socket's left corner is the header for the System Fan. The computer case fan. You will see there are 4 pins.
One for 12 Volts.
One for Ground.
One for detecting the RPM's of the fan. (Revolutions Per Minute)
One for varying the RPM's of the fan. This is the sensor connection.
To the upper right of the motherboard is another small white header. (Connector) This one has 3 pins. This is where the Processor (CPU) fan plugs in.
The long white connector below the CPU fan header is a 24-pin ATX main power connector.
The 24-pin ATX main power cable plugs in here.
The Front Panel header, or PANEL 1, is on the very bottom right.
Has two rows of pins.
Starting from the left side going right, there are 4 pins, NO pin, then 3 pins on the Top row.
Starting from the left going right, there are 7 pins across the bottom.
The pins on the Bottom are numbered Odd.
Starting from the left going right, the pins are numbered,
1, 3, 5, 7, 9, and 13.
The pins on the Top are numbered Even.
Starting at the left going right the pins are numbered,
2, 4, 6, 8, NO pin, 12, and 14.
1) Pins 2 and 4 are for the MSG LED
(Pin 2 is for the + positive connection)
2) Pins 1 and 3 are for the HarDDrive activity LED
(Pin 1 is for the + positive connection)
3) Pins 5 and 7 are for the Reset switch. (Button)
(Pin 7 is for the + positive connection)
4) Pins 6 and 8 are for the Power On switch.
(Pin 6 is the + positive connection)
5) Pins 11 and 13 are for the ODD LED
(Pin 11 is the + positive connection)
6) Pins 12 and 14 are for the LAN LED
Page 116 shows an exploded diagram of the inside, of the T650.
Acer doesn't give info as to who made the motherboard for them. (All pre-built computers have their parts made by someone else)
Due to it's square shape it's a Micro-ATX form factor motherboard.
9.6 inches by 9.6 inches, or 244mm by 244mm.
(The Micro-ATX form factor can be as small as 171mm by 171mm.
The following will give you more information,
http://en.wikipedia.org/wiki/Motherboard_form_factor )
Information about the Aspire T650 motherboard from me,
1) Motherboard chipset:
The motherboard chipset, is what determines what components are supported on a motherboard.
(Chip and Chipset are slang terms for I.C. Integrated Circuit)
The motherboard chipset is the Northbridge and Southbridge chip.
The Northbridge chip determines what Processors, and Ram Memory are supported, as well as what High Speed graphics are supported.
(The Northbridge chip handles the faster processes of the computer.
AGP and PCI Express are high speed graphics.
Any graphics card inserted into a PCI slot, is low speed graphics. This is handled by the Southbridge chip. It's a slower process. Integrated graphics are also handled by the Southbridge chip.
You may wish to view this motherboard diagram,
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
CPU stands for Central Processing Unit, or for short - Processor)
The Aspire T650 motherboard has an LA 775 processor socket.
The Northbridge chip is an ATI RC410
The Southbridge chip is a ULI M1573
Underneath the processor socket is the Northbridge chip. It's sitting diagonally, and has an aluminum heatsink sitting on top of it.
Below the Northbridge chip is a PCI-Express x16 slot used for a graphics card.
Below the PCI Express x16 slot is a PCI Express x1 slot. White in color, much shorter than a PCI slot.
There are two white PCI slots below the PCI Express x1 slot.
To the right of these white PCI slots is the Southbridge chip. ULI M1573
To the right of this chip are 4 SATA headers.
Below the 4 SATA headers is the Front Panel header.
(PANEL 1)
Are you having problems connecting components?
Do you need to know what components you can upgrade to?
(Processor, Ram Memory, graphics card, power supply, etc)
If so, simply state what information you need in a Comment.
May 03, 2010 | AcerPower FE PC Desktop
I want to copy from computer to a usb storage flash
You can connect tour flash drive to any usb port and you copy all your data.
Thanks, Prem
Mar 22, 2009 | Acer Aspire™ T180 PC Desktop
CD-ROM will not read CDs in ACER M5630
Update Acer drivers. I lost 1 USB on my Acer. This resolved the issue. After fixing it change settings to allow automatic updates.
May 03, 2017 | Acer (91.AB264.001) CD-ROM Drive
Problem with microphone
most of the old motherboards dont support the audio and mic port to work both in back side(back panel header) and front side (front panel header)simultaneously...
most of the old motherboards dont support multi streaming so you cant make both the back panel header and front panel header to work at a time ie i mean you cant connect both panel header at a time ...
you can just refer to your motherboard manual for the detailed information about it ..
in your motherboard if there is any option to connect the front panel header to the motherboard other than the back panel header you can connect it to that the detailed pin information will be given in the motherboard manual ..
if you dont have the option in the motherboard to connect the front panel header seperately then you must remove the pins connected from the back panel header and you must insert the front panel header pins .
this will disable your back panel audio ,mic,linein functionalities but you will be able to connect in front panel header , this front panel header will work ..
if the motherboard is not compatible then the system assembler will leave the front panel wires not connecting to motherboard ..
like this only one panel can work at a time ,
but in the latest motherboards the multi streaming technology has been introduced so both the panels can work at a time and can play different audio on 2 different panels ...
thank you
bye
any doubts you can reply me
i am always here to assist you
please rate my solution
have a nice day
Aug 10, 2008 | ASUS P5VD2-MX SE Motherboard
Display problem
YOUR COMUTER GRAPHICS CARD PROBABLY NEEDS A UNGRADE, VIDEO GAMES PUT A LOT OF STRESS ON THE PROC NEED TO CLEAN OT THE PROCESSOR AND THE VIDEO CARD TO DELIVER GAMING PERFORMANCE. SINCE YOUR SYSTEM WASN'T DESIGN FOR GAMING IT MAY CAUSE A LOT OF MEMORY CONFLICT WITH THE RAPID TRANSFERRING OF INFORMATION FROM THE PROCRSSOR TO THE RAM, TRY UPGRADING YOUR RAM AND VIDEO CARD AND U SHOULD HAVE BETTER PERFORMANCE WITHOUT SHUTDOWN. U MAY DUST OUT THE COMPUTER DUST ON THE PARTS CAN MAKE THEM OVERHEAT AND SHUT DOWN
Jul 23, 2008 | Acer Aspire™ T180 PC Desktop
Computers & Internet Logo
37 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
