Question about LG Dishwashers
I am installing a LG Dishwasher model LDF6810ST and cannot determine where to connect the power cable. Does it connect through the back or the front?
The power box is in the front right corner behing the access panel. (right side when you are looking at it from the front. The water inlet is in the front left.)
Posted on May 11, 2009
LG LDF6810ST won't power up there is power going to dishwasher
the main control board is fried from what you've described, you will need to dismantle it and remove the board (there will likely be visible signs of damage if there was a burning smell) relatively easy and cheap to replace
Jan 01, 2017 | LG LDF6810ST Stainless Steel Built-in...
How to replace door springs on lg model LDF6810ST
Found advice from another post for same prob..not tried yet says its not springs but spring cable, part #4933DD 3001B and 2 needed. Poster seem to know what he was talking about
Mar 02, 2013 | LG LDF6810ST Stainless Steel Built-in...
I am getting error code PF on my LG LDF6810ST, what does that mean?
PF means power failure. You are having a power supply problem. Check to make sure that the plug is connected properly. Check the junction box on the lower right corner behind the kick plate to make sure the wires are connected properly. If your dishwasher is 5 years or older, remove the front door panel and check the wire harness in the door liner for any broken wires. Good luck
Jun 17, 2011 | LG LDF6810ST Stainless Steel Built-in...
I just installed the dishwasher and do not turn on
On the LG LDF6810 model, you should be able to open the door and press the power button (right side of the top of the door.) It should wake up and you should see lights.
If that fails to happen, trace the power from under the dishwasher to where it is plugged in to the wall. If it is under the sink and you have a waste disposal, it is very possible that both outlets are switched on/off by the disposal switch. I would find a known-good table light or something similar and plug it in to the outlet and see if the light turns on when I switch it on. Electrician is needed to separate the top/bottom outlets so the dishwasher is always on and the disposal is properly switched.
If the dishwasher is not connected to an outlet, rather directly connected via electrical wire, have an electrician confirm the hot, neutral and ground wires are properly connected under the dishwasher and check the circuit breaker/fuse for that circuit.
Please report back what you find, OK?
May 20, 2010 | LG LDF6810ST Stainless Steel Built-in...
LG Dishwasher
I can't say for sure, but it is possible this unit is deeper than previous units. The only way to tell for sure is to measure the previous unit and compare to this one.
I would be suspect there may be something simple preventing the dishwasher from going all the way back into the cavity of the cabinets. Maybe the water line is in the way, the power plug, etc. are in the way. You would have to pull the dishwasher out and look it all over to determine if his comments are true or not.
Jan 23, 2009 | LG LDF6810ST Stainless Steel Built-in...
LG dishwasher model #LDF6810ST doesn't DRY DISHES.
ok ...first the average dishwasher will only heat the water 1 degree per mintue,,,now if your starting out with very cold water the dishes will never get clean check your water temp,,at start up..if you have 90 to a 100 degrees thats ok..that means we have problem in heater circuit...also turn up your jet dry level...keep me posted onthejob,,incase we have to look at heater circuit
Dec 31, 2008 | LG LDF6810ST Stainless Steel Built-in...
LG LDF6810ST Won't Turn ON
If you are still having the problems you describe and especially is you are getting a leak from the lower left door panel, please provide the model number and the serial number.
There IS help available if you provide the info.
Please report back. Thanks!
Dec 27, 2008 | LG LDF6810ST Stainless Steel Built-in...
Dishwashers Logo
74 people viewed this question
Top LG Dishwashers Experts
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
