Question about Refrigerators
Substances are freezing in the fridge - Refrigerators
  • mdoherty41 Aug 19, 2008
    GE Profile, is freezing everything in the bottom bins , used for veggies and fruit. I have tried setting the fridge and bottom freezer higher but bins still freeze food solid
  • Anonymous Dec 28, 2008
    Same problem---ice forming inside back wall of Sub Zero side by side.
The back wall of my sub zero side by side refrigerator develops ice. I need to defrost like an old school freezer. Help
Posted on Jul 18, 2008
Do freeze-dried foods taste as good as they did before the freezing process?
Freeze-dried foods taste almost the same as they did before with a minimal loss of taste or smell, moreover the freeze-dried process doesn't shrink or deform the substance therefore maintaining the structure of the substance.
Aug 09, 2012 | Camping, Backpacking & Hiking
Stench from back of fridge
Sounds like a regrigerant leak. Have it checked by an appliance tech.
May 26, 2012 | Siemens Bosch Neff Integrated Fridge...
Green substance on floor behind fridge
It's just corrosion that has dripped off of the copper pipes of the fridge. Typically it's caused by humidity. As long as the fridge is still cold, you should have nothing to worry about.
Thanks, and a vote/feedback is always appreciated! =)
May 30, 2011 | Refrigerators
Hi. Fridge freezer, bottom of freezer freezes and door stick,s many people have had this problem any cure any cure for this. thank you Mr R Burrell
Check to see if there is any ice forming in the freezer in the bottom. You may have a clogged drain and the water is backing up. Also check to see if the door seal around the freezer door is sticky, if so clean with something that will remove sticky substance. You may have spilled something on it.
Feb 23, 2011 | LG Refrigerators
Fridge freezing up
Check the fridge sensor. On my Hoover HNMF2805AL80 f/f, first I replaced control module - still freezing.
Have just replaced cheap fridge temperature sensor. Part No. 97061619. Trouble is you have to cut into insulation at back of fridge to replace. I just plugged in sensor & placed inside fridge at back at the bottom - so far so good, only lettuce freezing now, everything else v. cold but not frozen. :)
Jun 02, 2010 | Hotpoint RLA50 Refrigerator
I have a mini fridge and it was leaking this bright green substance after I unplugged it for about 3 days, and then when I pluggedit back in, it started smelling really bad. I have know idea what's going...
the bright green substance will have turned black fairly quickly as it is mould from the vent pipe,clean out with clorine bleach and dry before use to clear mould/smell.
Apr 28, 2010 | Refrigerators
Fridge and freezer not getting cold.
Is the yellow substance oil? I need the sears model number also for example 312.65989 That way I can picture just what you have on this end. Sea Breeze
Feb 21, 2010 | Kenmore Refrigerators
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
Water showing mold like substance visible despite 2 new filters
Disconnect the water from the refrig. Get large bowl and turn on water supply. Does water look clear?? Flush real well.
Nov 23, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
193 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
